Problems with "Enable debug options"
I am facing a problem with the selection "Enable debug options" when creating a build configuration. I use nRF connect SDK 1.9.1 with VSCode. I create an application from sample aws_iot. Then I make two different build configurations, one with "Enable debug options" checked, and one with the option unchecked. The one that has debug option enabled is not possible to debug (it may work once, but all other debug sessions do not work). But the one that doesn't have the option enabled works fine to debug.
How come there is a difference?
What does "Enable debug options" provide?
Lars
  • Hi Lars,
    Which operating system do you use?
    Dejan
  • Hi Dejan,
    It's Windows 10.
    Lars
  • Hi Lars,
    Could you send "Generate Support Information"? You can find a link to it when you select nRF Connect Extension in VS Code. Alternatively, press CTRL+SHIFT+P and starts typing "Generate Support Information".
    Dejan
  • Hi Dejen,
    Ok, now I have generated support information for both builds. No big difference as far as I can see.
    Have you been able to repeat what I see?
    Lars
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 10 Pro",
        "osKernel": "10.0.19041",
        "vscode": "1.70.2",
        "electron": "18.3.5",
        "node": "v16.13.2"
      "system": {
        "date": "2022-08-29T07:25:42.551Z",
        "vscodeRoot": "c:\\Users\\lars.magnusson.SVEKON\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "138:33:39",
        "osUptime": "138:36:46",
        "cpu": {
          "model": "Intel(R) Core(TM) i7-8665U CPU @ 1.90GHz",
          "speed": "2112 MHz",
          "count": 4
        "memory": {
          "total": "15.82 GB",
          "free": "3.86 GB"
      "workspace": {
        "name": "aws_iot_200",
        "workspaceFile": null,
        "folders": [
          "c:\\Projekt\\nordic\\aws_iot_200"
      "extensions": {
        "internal": {
            "version": "2022.7.242",
            "path": "c:\\Users\\lars.magnusson.SVEKON\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2022.7.242-win32-x64",
            "isActive": false
            "version": "2022.7.21",
            "path": "c:\\Users\\lars.magnusson.SVEKON\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2022.7.21",
            "isActive": true
            "version": "2022.7.36",
            "path": "c:\\Users\\lars.magnusson.SVEKON\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2022.7.36",
            "isActive": true
            "version": "2022.7.24",
            "path": "c:\\Users\\lars.magnusson.SVEKON\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2022.7.24",
            "isActive": true
        "external": {
          "marus25.cortex-debug": "1.6.0",
          "ms-vscode.cpptools": "1.11.5",
          "ms-vscode-remote.remote-wsl-recommender": "0.0.15",
          "ms-vscode.js-debug": "1.70.0",
          "ms-vscode.js-debug-companion": "1.0.18",
          "ms-vscode.vscode-js-profile-table": "1.0.3",
          "josetr.cmake-language-support-vscode": "0.0.4",
          "ms-dotnettools.vscode-dotnet-runtime": "1.5.0",
          "ms-vscode.cmake-tools": "1.11.26",
          "twxs.cmake": "0.0.17"
      "tools": {
        "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.14.1",
        "C:\\Program Files (x86)\\SEGGER\\JLink\\JLink.exe": "7.66a",
        "C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.16.0",
        "nrfutil": "Not found",
        "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\bin\\cmake.exe": "3.20.5",
        "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\bin\\Scripts\\west.exe": "0.13.1",
        "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\bin\\python.exe": "3.8.2",
        "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\bin\\ninja.exe": "1.9.0",
        "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\bin\\gperf.exe": "3.1",
        "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\bin\\dtc.exe": "1.4.7",
        "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\bin\\gn.exe": "2039",
        "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\mingw64\\bin\\git.exe": "2.26.2.windows.1"
      "sdks": [
          "version": "1.6.0",
          "path": "c:\\Projekt\\Nordaq\\v1.6.0"
          "version": "1.6.1",
          "path": "c:\\Projekt\\Nordaq\\v1.6.1"
          "version": "1.7.0",
          "path": "c:\\Projekt\\Nordaq\\v1.7.0"
          "version": "1.7.1",
          "path": "c:\\Projekt\\NordicSemi\\v1.7.1"
          "version": "1.7.0",
          "path": "c:\\Projekt\\NordicSemi\\v1.7.0"
          "version": "1.8.0",
          "path": "c:\\Projekt\\NordicSemi\\v1.8.0"
          "version": "1.9.1",
          "path": "c:\\Projekt\\NordicSemi\\v1.9.1"
          "version": "1.9.0",
          "path": "c:\\Projekt\\NordicSemi\\v1.9.0"
          "version": "2.0.0",
          "path": "c:\\Projekt\\NordicSemi\\v2.0.0"
      "toolchains": [
          "version": "1.6.0",
          "path": {
            "$mid": 1,
            "fsPath": "c:\\Projekt\\Nordaq\\v1.6.0\\toolchain",
            "_sep": 1,
            "path": "/C:/Projekt/Nordaq/v1.6.0/toolchain",
            "scheme": "file"
          "version": "1.6.1",
          "path": {
            "$mid": 1,
            "fsPath": "c:\\Projekt\\Nordaq\\v1.6.1\\toolchain",
            "_sep": 1,
            "path": "/C:/Projekt/Nordaq/v1.6.1/toolchain",
            "scheme": "file"
          "version": "1.7.0",
          "path": {
            "$mid": 1,
            "fsPath": "c:\\Projekt\\Nordaq\\v1.7.0\\toolchain",
            "_sep": 1,
            "path": "/C:/Projekt/Nordaq/v1.7.0/toolchain",
            "scheme": "file"
          "version": "1.7.0",
          "path": {
            "$mid": 1,
            "fsPath": "c:\\Projekt\\NordicSemi\\v1.7.0\\toolchain",
            "_sep": 1,
            "path": "/C:/Projekt/NordicSemi/v1.7.0/toolchain",
            "scheme": "file"
          "version": "1.7.1",
          "path": {
            "$mid": 1,
            "fsPath": "c:\\Projekt\\NordicSemi\\v1.7.1\\toolchain",
            "_sep": 1,
            "path": "/C:/Projekt/NordicSemi/v1.7.1/toolchain",
            "scheme": "file"
          "version": "1.8.0",
          "path": {
            "$mid": 1,
            "fsPath": "c:\\Projekt\\NordicSemi\\v1.8.0\\toolchain",
            "_sep": 1,
            "path": "/C:/Projekt/NordicSemi/v1.8.0/toolchain",
            "scheme": "file"
          "version": "1.9.0",
          "path": {
            "$mid": 1,
            "fsPath": "c:\\Projekt\\NordicSemi\\v1.9.0\\toolchain",
            "_sep": 1,
            "path": "/C:/Projekt/NordicSemi/v1.9.0/toolchain",
            "scheme": "file"
          "version": "1.9.1",
          "path": {
            "$mid": 1,
            "fsPath": "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain",
            "_sep": 1,
            "path": "/C:/Projekt/NordicSemi/v1.9.1/toolchain",
            "scheme": "file"
          "version": "2.0.0",
          "path": {
            "$mid": 1,
            "fsPath": "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0",
            "_sep": 1,
            "path": "/C:/Projekt/NordicSemi/toolchains/v2.0.0",
            "scheme": "file"
      "connectedDevices": [
          "serialNumber": "960055412"
      "deviceProviders": [
        "nrfjprog"
      "config": {
          "topdir": "c:\\Projekt\\NordicSemi\\v2.0.0",
          "toolchain": {
            "path": "${nrf-connect.toolchain:2.0.0}"
          "ozonePath": "C:\\Program Files\\SEGGER\\Ozone\\Ozone.exe",
          "applications": [
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig"
          "welcome": {
            "showOnStartup": false
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [
            "C:\\Projekt\\Svekon\\Nordic\\nrf9160_iot_base"
          "enableTelemetry": false,
          "taskBindings": {},
          "debugging": {
            "backend": "Cortex-Debug"
          "activeAppFollowActiveEditor": true
          "terminalMode": "character"
        "marus25.cortex-debug": {
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "enableTelemetry": true,
          "registerUseNaturalFormat": true,
          "variableUseNaturalFormat": true,
          "dbgServerLogfile": null,
          "showRTOS": false,
          "showDevDebugOutput": "none"
      "environment": {
        "westExe": "west",
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "HOME": "C:\\Users\\lars.magnusson.SVEKON",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\lars.magnusson.SVEKON",
          "Path": "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\mingw64\\bin;c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\mingw64\\libexec\\git-core;c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\bin;c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\arm-zephyr-eabi\\bin;c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\bin\\Scripts;C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;C:\\Program Files\\TortoiseGit\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\ktvisa;C:\\Program Files (x86)\\IVI Foundation\\IVI\\bin;C:\\Program Files\\IVI Foundation\\IVI\\bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\winnt\\agvisa;C:\\Program Files (x86)\\dotnet\\;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\lars.magnusson.SVEKON\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\lars.magnusson.SVEKON\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "ZEPHYR_BASE": "c:\\Projekt\\NordicSemi\\v2.0.0\\zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\zephyr-sdk",
          "PYTHONPATH": "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\bin;c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\bin\\Lib;c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\bin\\Lib\\site-packages",
          "Python3_ROOT": "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\bin"
        "inherited": {
          "HOMEDRIVE": "C:",
          "Path": "C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;C:\\Program Files\\TortoiseGit\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\ktvisa;C:\\Program Files (x86)\\IVI Foundation\\IVI\\bin;C:\\Program Files\\IVI Foundation\\IVI\\bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\winnt\\agvisa;C:\\Program Files (x86)\\dotnet\\;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\lars.magnusson.SVEKON\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\lars.magnusson.SVEKON\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "PATH": "C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;C:\\Program Files\\TortoiseGit\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\ktvisa;C:\\Program Files (x86)\\IVI Foundation\\IVI\\bin;C:\\Program Files\\IVI Foundation\\IVI\\bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\winnt\\agvisa;C:\\Program Files (x86)\\dotnet\\;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\lars.magnusson.SVEKON\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\lars.magnusson.SVEKON\\AppData\\Local\\Programs\\Microsoft VS Code\\bin"
        "toolchainPath": "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0",
        "toolchainBinPath": "c:\\Projekt\\NordicSemi\\toolchains\\v2.0.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
        "toolchainVersion": "2.0.0"
      "terminal": {
        "shell": null,
        "defaultProfile": null
      "platform": {
        "os": "win32",
        "vscode": "1.70.2",
        "node": "v16.13.2"
      "system": {
        "date": "2022-08-29T07:20:12.427Z",
        "vscodeUptime": "138:28:09",
        "osUptime": "138:31:15",
        "cpu": {
          "count": 4
        "memory": {
          "free": "4.15 GB"
      "workspace": {
        "folders": [
      "extensions": {
        "internal": {
            "isActive": false
            "isActive": true
            "isActive": true
            "isActive": true
        "external": {
      "tools": {
      "sdks": [
          "version": "1.6.0",
          "version": "1.6.1",
          "version": "1.7.0",
          "version": "1.7.1",
          "version": "1.7.0",
          "version": "1.8.0",
          "version": "1.9.1",
          "version": "1.9.0",
          "version": "2.0.0",
      "toolchains": [
          "version": "1.6.0",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "1.6.1",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "1.7.0",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "1.7.0",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "1.7.1",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "1.8.0",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "1.9.0",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "1.9.1",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "2.0.0",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
        "nrfjprog"
      "config": {
          "toolchain": {
          "applications": [
          "kconfig": {
          "welcome": {
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [
          "taskBindings": {},
          "debugging": {
          "gdbPath": null,
          "pyocdPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "showRTOS": false,
      "environment": {
        "westExe": "west",
        "westEnv": {
          "HOMEDRIVE": "C:",
        "inherited": {
          "HOMEDRIVE": "C:",
      "terminal": {
        "shell": null,
  • Hi again,
    The above support info-files are for aws_iot from SDK 2.0.0.
    Here I attach support info for aws_iot SDK 1.9.1, where I get the message
    "WARNING: Cortex-Debug has deprecated use of GDB version 8 after July 2022. Please upgrade to version 9+"
    How come something that worked before doesn't work now? I thought that using a specific SDK with a specific toolchain would always do the same thing.
    Lars
    [10:22:32] west build --build-dir c:\Projekt\nordic\aws_iot_191\build_debug_options_enabled c:\Projekt\nordic\aws_iot_191
    [10:22:33] Success.
    [10:22:50] west build --build-dir c:\Projekt\nordic\aws_iot_191\build_debug_options_disabled c:\Projekt\nordic\aws_iot_191
    [10:22:51] Success.
    [10:22:59] west build --build-dir c:\Projekt\nordic\aws_iot_191\build_debug_options_enabled c:\Projekt\nordic\aws_iot_191
    [10:23:01] Success.
      "platform": {
        "os": "win32",
        "vscode": "1.70.2",
        "node": "v16.13.2"
      "system": {
        "date": "2022-08-29T08:23:16.915Z",
        "vscodeUptime": "00:01:22",
        "osUptime": "139:34:20",
        "cpu": {
          "count": 4
        "memory": {
          "free": "3.81 GB"
      "workspace": {
        "name": "aws_iot_191",
        "folders": [
          "c:\\Projekt\\nordic\\aws_iot_191"
      "extensions": {
        "internal": {
            "isActive": false
            "isActive": true
            "isActive": true
            "isActive": true
        "external": {
      "tools": {
        "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin\\arm-none-eabi-gcc.exe": "9-2019-q4-major",
        "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin\\cmake.exe": "3.20.5",
        "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin\\Scripts\\west.exe": "0.12.0",
        "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin\\python.exe": "3.8.2",
        "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin\\ninja.exe": "1.9.0",
        "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin\\gperf.exe": "3.1",
        "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin\\dtc.exe": "1.4.7",
        "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin\\gn.exe": "1977",
        "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\mingw64\\bin\\git.exe": "2.26.2.windows.1"
      "sdks": [
          "version": "1.6.0",
          "version": "1.6.1",
          "version": "1.7.0",
          "version": "1.7.1",
          "version": "1.7.0",
          "version": "1.8.0",
          "version": "1.9.1",
          "version": "1.9.0",
          "version": "2.0.0",
      "toolchains": [
          "version": "1.6.0",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "1.6.1",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "1.7.0",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "1.7.0",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "1.7.1",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "1.8.0",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "1.9.0",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "1.9.1",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
          "version": "2.0.0",
          "path": {
            "$mid": 1,
            "_sep": 1,
            "scheme": "file"
        "nrfjprog"
      "config": {
          "topdir": "c:\\Projekt\\NordicSemi\\v1.9.1",
          "toolchain": {
            "path": "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain"
          "applications": [
          "kconfig": {
          "welcome": {
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [
          "taskBindings": {},
          "debugging": {
          "gdbPath": null,
          "pyocdPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "showRTOS": false,
      "environment": {
        "westExe": "west",
        "westEnv": {
          "HOMEDRIVE": "C:",
          "Path": "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\mingw64\\bin;c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\mingw64\\libexec\\git-core;c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin;c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin\\Scripts;C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\Users\\lars.magnusson.SVEKON\\.nrfconnect-apps\\node_modules\\pc-nrfconnect-toolchain-manager\\resources\\nrfutil-toolchain-manager\\win32\\vcruntime140.dll;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Intel\\WiFi\\bin\\;C:\\Program Files\\Common Files\\Intel\\WirelessCommon\\;C:\\Program Files\\TortoiseGit\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\ktvisa;C:\\Program Files (x86)\\IVI Foundation\\IVI\\bin;C:\\Program Files\\IVI Foundation\\IVI\\bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\winnt\\agvisa;C:\\Program Files (x86)\\dotnet\\;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\lars.magnusson.SVEKON\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\lars.magnusson.SVEKON\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "ZEPHYR_BASE": "c:\\Projekt\\NordicSemi\\v1.9.1\\zephyr",
          "GNUARMEMB_TOOLCHAIN_PATH": "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt",
          "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
          "PYTHONPATH": "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin;c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin\\Lib;c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin\\Lib\\site-packages",
          "Python3_ROOT": "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin"
        "inherited": {
          "HOMEDRIVE": "C:",
        "toolchainPath": "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain",
        "toolchainBinPath": "c:\\Projekt\\NordicSemi\\v1.9.1\\toolchain\\opt\\bin",
        "toolchainVersion": "1.9.1"
      "terminal": {
        "shell": null,
