I've written a sample eeprom application based on the eeprom included in the nRF52 SDK to test the EEPROM we use in a project. The application worked properly about 10 days ago. Now I tried to rebuild the exact same application and debug it on the nRF52 DK. When building, the following CMake warning is displayed:
CMake Warning at C:/Users/Lukas/ncs/v1.9.1/zephyr/CMakeLists.txt:764 (message): No SOURCES given to Zephyr library: drivers__eeprom Excluding target from build.
Code in main.c:
/* * Copyright (c) 2021 Thomas Stranger * * SPDX-License-Identifier: Apache-2.0 */ #include <zephyr.h> #include <sys/printk.h> #include <drivers/eeprom.h> #include <device.h> #define WRITE_BUFFER 8 #define READ_BUFFER 256 #define EEPROM DT_NODELABEL(eeprom_0) /* * Get a device structure from a devicetree node with alias eeprom */ static const struct device *get_eeprom_device(void) { const struct device *dev = device_get_binding(DT_LABEL(EEPROM)); if (!device_is_ready(dev)) { printk("\nError: Device \"%s\" is not ready; " "check the driver initialization logs for errors.\n", dev->name); return NULL; } printk("Found EEPROM device \"%s\"\n", dev->name); return dev; } void main(void){ const struct device *eeprom = get_eeprom_device(); if(eeprom == NULL){ return; } uint8_t write_buffer[WRITE_BUFFER]; for (int i = 0; i < WRITE_BUFFER; i++){ write_buffer[i] = 120; } eeprom_write(eeprom, 0x10, write_buffer, sizeof(write_buffer)); uint8_t read_buffer[READ_BUFFER]; for (int i = 0; i < READ_BUFFER; i++){ read_buffer[i] = 0; } int ok = eeprom_read(eeprom, 0x00, &read_buffer, sizeof(read_buffer)); if(ok < 0){ printk("Error reading from EEPROM; err: %d\n", ok); return; } }
For the EEPROM used in our project I created an overlay device tree with the following code:
&i2c0 { eeprom_0: br24c02@50 { compatible = "atmel,at24"; size = <256>; pagesize = <8>; address-width = <8>; timeout = <0>; label = "BR24C02"; reg = <0x50>; }; };
CMakeLists.txt
# SPDX-License-Identifier: Apache-2.0 cmake_minimum_required(VERSION 3.20.0) find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE}) project(eeprom) FILE(GLOB app_sources src/*.c) target_sources(app PRIVATE ${app_sources})
prj.conf
CONFIG_PRINTK=y CONFIG_EEPROM=y
I can debug the application. However, when I step over the function "device_get_binding(DT_LABEL(EEPROM))" I can see that a NULL pointer is returned.
Do you have any ideas why this problem occurs and how to fix it?
