nrtutil error in __set_prn on RaspberryPi OS and nRF52840 Dongle
I try to DFU on RaspberryPi OS by usb-serial. I put nRF52840 dongle on USB port of RPI4. And press reset button of the dongle.
I got error on nrftuil.
$ nrfutil dfu usb-serial -pkg ~/nordic/nRF5_SDK_17.1.0_ddde560/examples/dfu/secure_dfu_test_images/ble/nrf52840/hrs_application_s140.zip -p /dev/ttyACM0 -b 115200
  File "/home/pi/.local/bin/nrfutil", line 8, in <module>
    sys.exit(cli())
  File "/home/pi/.local/lib/python3.7/site-packages/click/core.py", line 829, in __call__
    return self.main(*args, **kwargs)
  File "/home/pi/.local/lib/python3.7/site-packages/click/core.py", line 782, in main
    rv = self.invoke(ctx)
  File "/home/pi/.local/lib/python3.7/site-packages/click/core.py", line 1259, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/home/pi/.local/lib/python3.7/site-packages/click/core.py", line 1066, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/home/pi/.local/lib/python3.7/site-packages/click/core.py", line 610, in invoke
    return callback(*args, **kwargs)
  File "/home/pi/.local/lib/python3.7/site-packages/nordicsemi/__main__.py", line 1001, in usb_serial
    timeout)
  File "/home/pi/.local/lib/python3.7/site-packages/nordicsemi/__main__.py", line 956, in do_serial
    dfu.dfu_send_images()
  File "/home/pi/.local/lib/python3.7/site-packages/nordicsemi/dfu/dfu.py", line 129, in dfu_send_images
    self._dfu_send_image(self.manifest.application)
  File "/home/pi/.local/lib/python3.7/site-packages/nordicsemi/dfu/dfu.py", line 90, in _dfu_send_image
    self.dfu_transport.open()
  File "/home/pi/.local/lib/python3.7/site-packages/nordicsemi/dfu/dfu_transport_serial.py", line 216, in open
    self.__set_prn()
  File "/home/pi/.local/lib/python3.7/site-packages/nordicsemi/dfu/dfu_transport_serial.py", line 359, in __set_prn
    + map(ord, struct.pack('<H', self.prn)))
TypeError: can only concatenate list (not "map") to list
    nrfutil doesn't work on Raspberry Pi. Don't remember the details, but I believe it is because of some requirements not being supported for the Raspberry Pi processor. I believe you should see some warnings when you try to install it.
    However, we have an unofficial build that you can test if you want to. It requires Python 3.7, but I see that this is what you are currently using. If you at some point update Python to another version, then this will probably not work anymore.
    pc_ble_driver_py-0.16.2-cp37-cp37m-linux_armv7l.zip
    I have not tested it, but feel free to give it a go.
    Edvin
  • By installing pip, v5.2 is installed. I get v6.1.3 from git and replaced. Then nrfutil works on RPI4.
    I run these command for updating nordicsemi python lib.
    $ cd ~
    $ git clone https://github.com/NordicSemiconductor/pc-nrfutil.git
    $ cd /home/pi/.local/lib/python3.7/site-packages/
    $ mv nordicsemi nordicsemi.5.2
    $ cd ~/pc-nrfutil
    $ cp -r nordicsemi /home/pi/.local/lib/python3.7/site-packages/.
