I'm using PWM library example using nrf52840 with SDK17.0.2 to run stepper motor, I need to run the motor based on duty cycle so how i able to run based on duty cycle for different time seconds?
You can check out the PWM driver and example:
https://infocenter.nordicsemi.com/topic/sdk_nrf5_v17.1.0/pwm_hw_example.html
You can also find an example showing simple use of nrf_drv_pwm_simple_playback() here:
https://devzone.nordicsemi.com/f/nordic-q-a/28081/is-there-a-simple-example-how-to-set-a-pwm-driver/110654#110654
Kenneth
Thanks for reply
I already used PWM library example to run the stepper motor but the thing is i couldn't able to desire timing for example:-i want to expel the fluid 2ml per second out of 10ml so, the stepper motor expel the fluid with 5seconds so this what happening now for more clarification please find the following codes.
else if(strcmp(DATA,"F1")==0)
proto_flag=false;
kvorun_flag=false;
uint32_t value;
uint8_t target_ml;
nrf_gpio_pin_set(SIP_SENSOR_BOARD_ENABLE);
nrf_gpio_pin_set(SIP_SENSOR_BOARD_ROTATION);
app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(600, SIP_SENSOR_BOARD_PWM_PIN);
app_pwm_init(&PWM1,&pwm1_cfg, NULL);
app_pwm_enable(&PWM1);
rightsensor=opt1;
if(volume_flag==0)
monitor_volume=resist-AUTO_EXP_VOL;
volume_flag=1;
if(resist>monitor_volume)
if(rightsensor!=1)
while (app_pwm_channel_duty_set(&PWM1, 0,50) == NRF_ERROR_BUSY);
nrf_delay_ms(20);
revs_fillback_flag=true;
app_pwm_disable(&PWM1);
revs_fillback_flag=false;
memset(FINAL,0,12);
nrf_gpio_pin_set (SIP_SENSOR_BOARD_ENABLE);
INT_KVO=0;
KVO_FLAG=0;
memset(prcol,0,120);
memset(FINAL,0,120);
proto_flag=false;
kvorun_flag=false;
counter_shark=0;
volume_flag=0;
app_pwm_uninit(&PWM1);
thank you.
The simplest may just be to start a repeated 1ms app_timer. In the 1ms timeout handler you increment a 1ms global counter. You then have two options to use this 1ms counter:
1. You can then either directly in the timeout handler start and stop the PWM based on the 1ms counter value.
OR
2. You can just have a while() loop in your main() that just check the 1ms tick counter value and start and stop the PWM.
Kenneth
Here my stepper motor running with some speed and now for example:- I want to expel the fluid 1ml/sec out of 10ml so, it takes 10sec to complete. so, here I need to change that fluid expel change 2ml/sec out of 10ml I need to complete it with in 5sec. so, I can't implement this by using timer so we need to control the speed.??
please share your thoughts regarding this..
thank you.
Sorry, but I don't have any experience with this. The PWM example show example use of the PWM driver/peripheral, how frequently you want to update the PWM and what duty cycle you want on PWM is fully controllable, but it is up to you how you implement this.
Kenneth
