ble_app_uart peripheral Error 8 (0x8): GATT CONN TIMEOUT
Hello everyone,
I'm testing the example ble peripheral "UART/Serial Port Emulation over BLE" with SoftDevice S112 nRF5 SDK  v17.1.0. My board is MBN52832DK and i'm using the nRF Connect for Mobile app.
I made a change in the function (uart_event_handle) that handles the data received over UART to use a Python Script that send multiples messages. Now data is relayed to the BLE peer using the Nordic UART Service when the size of the string is 22 bytes.
My objective is to use a Baudrate of 460800 bauds. I started using a slower baudrate (115200) and the communication works well, but when I increase the number of messages or decrease the time inter messages it gets disconnected.
NRF_LOG RTT backend saids:
UARTE: Function: nrfx_uarte_rx, error code:pim NRF_SUCCESS.
<error> app: Fatal error
nRF Connect LOG saids:
What could be the problem? How do i get a better NRF_LOG?
Thanks in advance,
Fernando.
  • Hi Fernando,
    The first step should be to add more logging. If you make a debug build you will get the file name, line number and error code printed instead of just "Fatal error". If you are using a SES example project that has "Debug" as a build configuration, just select that. If not, you need to add "DEBUG and "DEBUG_NRF" as defines in your project or Makefile, and test again. What does the log say then? Which function call returns which error code?
    Einar
  • Thank Einar,
    NRF log saids:
    <info> app_timer: RTC: initialized.
    <info> app: Debug logging for UART over RTT started.
    <debug> nrf_ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0.
    <info> app: Connected
    <debug> nrf_ble_gatt: ATT MTU updated to 247 bytes on connection 0x0 (response).
    <info> app: Data len is set to 0xF4(244)
    <debug> app: ATT MTU exchange completed. central 0xF7 peripheral 0xF7
    <debug> nrf_ble_gatt: Peer on connection 0x0 requested an ATT MTU of 517 bytes.
    <debug> nrf_ble_gatt: Updating ATT MTU to 247 bytes (desired: 247) on connection 0x0.
    <debug> app: Ready to send data over BLE NUS
    <debug> app:  38 39 31 37 36 36 37 30|89176670
    <debug> app:  35 33 36 39 39 31 38 38|53699188
    <debug> app:  39 31 34 35 34 33      |914543
    <debug> app:  30 39 35 33 38 36 39 30|09538690
    <debug> app:  39 35 32 30 31 30 34 30|95201040
    <debug> app:  39 35 36 39 38 30      |956980
    <debug> app:  30 30 30 31 32 39 39 32|00012992
    <debug> app:  39 31 35 38 36 33 33 30|91586330
    <debug> app:  33 33 32 39 31 33      |332913
    <debug> app:  30 30 30 32 39 38 30 38|00029808
    <debug> app:  38 34 31 38 33 38 39 31|84183891
    <debug> app:  35 36 38 33 32 34      |568324
    <debug> app:  30 30 30 33 37 39 34 37|00037947
    <debug> app:  31 32 39 32 33 36 32 30|12923620
    <debug> app:  34 31 34 35 31 39      |414519
    <debug> app:  30 30 30 34 39 32 31 30|00049210
    <debug> app:  33 31 35 33 36 38 36 34|31536864
    <debug> app:  30 32 35 39 36 35      |025965
    <error> app: ERROR 1 [NRF_ERROR_SVC_HANDLER_MISSING] at /home/proko/nRF5_SDK/nRF5_SDK_17.1.0/examples/MisProgs/ble_app_uart/main.c:540
    PC at: 0x00022C2D
    <error> app: End of error report
    line main:540 is
    Thanks, this provides a lot of info. There is an error in the UART transaction, and the error_communication holds the value of the ERRORSRC register. NRF_ERROR_SVC_HANDLER_MISSING is not the right name here, but this maps to 1, which in ERRORSRC is OVERRUN. So there has been an OVERRUN error on the UART, meaning that "A start bit is received while the previous data still lies in RXD. (Previous data is lost.)". So data is coming in faster than it can be processed. The first thing I would consider is using flow control.
  • Hi Einar,
    Thanks for clarifying. I'm not sure if flow control is an option due to Hardware. I'm trying to arrive a solution with a double buffer, but I understand that app_uart doesn't support this future.
    How can I enable double buffer for incoming data using directly the driver for uarte?
    The driver supports double buffering by calling nrf_drv_uart_rx() twice. It is briefly mentioned in the driver documentation.
