I need to know. How to put the nrf5340 in sleep mode and how can I woke up the device based on interrupt. Kindly, let me know. How can I achieve this.
Thanks & Regards,
Navin
Thanks & Regards,
Navin
You should not get this error if you are not in debug interface mode/emulated system off. Did you disconnect the debugger? Are you logging over UART or RTT? If using RTT, you should disconnect the RTT terminal to prevent debug mode.
Did you make any modifications to the example? Witch version of nRF Connect SDK are you using?
Hi Navin, Where did you get those example code for the sleepmode?
