(Q)SPI cleanup when using mcuboot
Hi.
Is it possible to add SPI or QSPI cleanup once mcuboot is done?
I've checked nrf_cleanup.c, but it seems that (Q)SPI is not turned off, which increases the power consumption when the application starts if it does not use the external flash itself.
A simple hack is enable the (Q)SPI in the application, and put it to "power down", but could it be added directly to mcuboot?
Regards
Giuliano
  • Hi Giuliano
    The QSPI cleanup is done in the QSPI Zephyr driver itself (...\ncs\vx.x.x\zephyr\drivers\flash\nrf_qspi_nor.c) instead of in the cleanup file to deal with erratum 122 in the nRF52840 for example. Do you mean that it rather should be put directly into MCUboot, if so why?
    SImon
    It was just a suggestion, as one could expect that mcuboot would shut down all the resources it uses before jumping to the main application.
    That would prevent some strange cases where some higher than expect current consumption can be observed when MCUBOOT is used in a sample that does not use QSPI itself. We've seen about a 2mA leakage because of that.
    Now that I'm writing this answer, one special use case comes to mind: what would happen if the QSPI is only used in the secure part of an application with for example:
    - TF-M using Protected Storage Service
    - MCUBOOT
    - Zephyr
    The QSPI will reside only in the secure part to store the new firmware. MCUBOOT would leave QSPI ON, and the main application will not be able to shut it down (as the application will reside in the NS part).
    Will the Protected Storage Service re-initialize the QSPI and put it to power down?
    Giuliano
  • Hi Giuliano
    I'm not sure if the protected storage service will deinit the QSPI to be honest, and I'll have to ask internally. I'll also forward your suggestion as it might indeed be a good idea. Thanks!
    Simon
