nRF Connect Installation on macOS (Manual Installation)
I have not been able to create a stable development environment in macOS Monterey using the automatic installation process.
In order to better understand and document the issues, I am going to do four separate installations for comparison.
MacBook Pro 1:  Manual Installation
MacBook Pro 2:  Automatic installation
https://devzone.nordicsemi.com/f/nordic-q-a/88566/nrf-connect-installation-on-macos-automatic-installation/editpost?ContentTypeId=0
Linux Ubuntu:     Manual Installation
Windows 11:       Automatic installation
This thread will cover the first case, the manual installation on macOS. I will create separate support tickets for the other cases and provide links.
  • Hi Al,
    That is good to hear.
    Regarding LE Audio it is simply too new to be part of the previous release, but it is part of the 2.0.0 release that is coming these days. Also, the proper J-Link version to be included in the next nRF Command Line tools release (10.16.0) which is also right around the corner.
  • Hi Einar,
    I completed the manual installation process, but encountered the same issues with installing nRF Connect SDK v2.2.0 as I did with the automatic installation, specifically the installation hanging on the memfault repository stage.
    I followed your guidance to install the universal version of the J-Link software, but I noticed this line in the nRF Connect log file when updating the toolchain after restarting Toolchain Manager:
    2022-06-03T09:55:41.967Z INFO Installed JLink version does not match the provided version (V7.58b)
    Is this the reason why the Open SEGGER J-Link button is not shown for the nRF Connect SDK v2.2.0 release for either the automatic or manual installations please?
    Also there appears to be a stage that is missed in the automatic installation process, as with the manual version I did not get the issue when I launched VS Code and selected V2.0.0 for both nRF Select SDK and nRF Connect Toolchain, I get an error saying Shell initialization conflicts nRF Connect terminal profile with a link to the following information:
    This issue may occur when opening the internal terminal with the nRF Connect profile, which sets the shell environment for the configured SDK and toolchain, but the shell initialization script (e.g. .bashrc) overrides the environment. This can happen if the ZEPHYR_BASE environment variable is set in .bashrc. If there is no need for external terminals to use this variable, we suggest removing this from .bashrc, otherwise it can be moved to .bash_profile or an equivalent script that is only loaded by login shells.
    https://nrfconnect.github.io/vscode-nrf-connect/connect/troubleshooting.html#shell-initialization-conflicts-nrf-connect-terminal-profile
    This didn't occur with the manual installation, perhaps something to look at please?
    Al
  • Hi Al,
    I do not have an answer for this at the moment, but it has been reported and is followed up in this thread, so I recommend you follow that.
    As stated here, you should not set ZEPHYR_BASE (depending on your shell that means it should not be in .bashrc nor .zshrc, for instance).
    Einar
  • Hi Einar,
    Thanks very much, the Install J-LINK for x86 included with the nrf-command-tools-10.15.4-Darwin package installs v7.58b, which is why I've never seen the issue before with previous installations as I used this version rather than the Universal one which installs V7.66b.
    For the second issue, where are .bashrc and .bash_profile located please? I couldn't locate them when searching in Finder. As I commented, this is an issue for the automatic installation, it didn't occur with the manual installation, and I didn't set anything for ZEPHYR_BASE for either install.
    Al
  • Hi Al,
    If I remember correctly macOS Monterey use zsh by default, so then .zshrc is what you are looking fore (and not bash related config files).
    Einar
1 2 3 4 5
