S130 sd_ble_gatts_value_get block
Hello Everyone
I have an issue when reading the value of an attribute using sd_ble_gatts_value_get, where if the connection has been lost, the call will block for ever. I use the following cleaned snippet.
uint16_t conn_handle;
uint16_t att_handle;
ble_gatts_value_t gatt_value;
get_att_handle(&att_handle);
get_conn_handle(&conn_handle);
gatt_value.len = 2;
gatt_value.offset = 0;
gatt_value.p_value = (uint8_t *)value;
error_code = sd_ble_gatts_value_get(conn_handle, att_handle, &gatt_value);
if (error_code != NRF_SUCCESS)
  //handle error
The characteristic I am reading has a vendor specefic UUID and data is fixed width 2 bytes. I am calling the snippet above in a loop to wait for a specific value. Everything works fine untill the device is disconnected. I have verified that the same thing happen no matter if I use the correct conn_handle or BLE_CONN_HANDLE_INVALID; everything Works fine untill connection is lost, after this the call will block.
Has anyone experienced this before, or perhaps know of a solution?
