NRF_ERROR_BUSY at TWI embedded code
Now I am making an original ISP4520(nRF52832) application using ISP4520-examples.
I'm trying to embed LM75B sample code from nRF5_SDK_16.0.0_98a08e2 to Class_A.emProject.
I paste my source code below. To find out where the error occurred, unrelated code is commented out.
// Standards
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
// nRF
#include "nrf.h"
#include "app_error.h"
#include "app_timer.h"
#include "app_scheduler.h"
#include "nrf_delay.h"
#include "nrf_drv_clock.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_twi.h" // Add
// LoRa
#include "board.h"
//logs
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
// LoRaMac
#include "loramachelper.h"
#define SCHED_MAX_EVENT_DATA_SIZE   APP_TIMER_SCHED_EVENT_DATA_SIZE /**< Maximum size of scheduler events. */
#define SCHED_QUEUE_SIZE            60                              /**< Maximum number of events in the scheduler queue. */
#define LORAWAN_APP_PORT            2       /**< LoRaWAN application port, do not use 224. It is reserved for certification */
#define LORAWAN_APP_DATA_BUFF_SIZE  64      /**< Size of the data buffer. */
#define LORAWAN_APP_TX_DUTYCYCLE    10000   /**< Defines the application data transmission duty cycle. 10s, value in [ms]. */
// --- TWI START ---
/* TWI instance ID. */
#define TWI_INSTANCE_ID     0
/* Common addresses definition for temperature sensor. */
#define LM75B_ADDR         (0x90U >> 1)
#define LM75B_REG_TEMP      0x00U
#define LM75B_REG_CONF      0x01U
#define LM75B_REG_THYST     0x02U
#define LM75B_REG_TOS       0x03U
/* Mode for LM75B. */
#define LM75B_MODE_NORMAL   0U
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Buffer for samples read from temperature sensor. */
static uint8_t m_sample;
// --- TWI END ---
// Foward declaration
static void lmh_rx_data_handler(lmh_app_rx_data_t *app_data);
static void lmh_evt_handler(lmh_evt_type_t type, void *data);
APP_TIMER_DEF(lora_tx_timer_id);                                                    ///< LoRa tx timer instance.
static uint8_t m_lora_rx_data_buffer[LORAWAN_APP_DATA_BUFF_SIZE];                   ///< LoRa user application rx data buffer.
static lmh_app_rx_data_t m_lora_rx_data = {m_lora_rx_data_buffer, 0 ,0, 0, 0};      ///< LoRa user application rx data structure.
static uint8_t m_lora_tx_data_buffer[LORAWAN_APP_DATA_BUFF_SIZE];                   ///< LoRa user application tx data buffer.
static lmh_app_tx_data_t m_lora_tx_data = {m_lora_tx_data_buffer, 0 ,0, 0, 0};      ///< LoRa user application tx data structure.
/**@brief Structure containing LoRaWan callback functions, needed for lmh_init()
static lmh_callback_t lora_callbacks = {    BoardGetBatteryLevel, BoardGetUniqueId, BoardGetRandomSeed,
                                            lmh_rx_data_handler, lmh_evt_handler};
/**@brief Function for handling event from the LMH layer
 * @param[in] type  event type
 * @param[in] data  event data
    switch(type)
        case LHM_EVT_NWK_JOINED:
#if (OVER_THE_AIR_ACTIVATION != 0)
            NRF_LOG_INFO("Network Joined");
        case LHM_EVT_RX_ACK:
            NRF_LOG_INFO("Acknowledge received");
        case LHM_EVT_CLASS_CHANGED:
            int new_class = *(int *)data;
            NRF_LOG_INFO("Device class changed to %c", "ABC"[new_class]);
/**@brief Function for handling LoRaWan received data from the server
 * @param[in] app_data  Pointer to rx data
    NRF_LOG_DEBUG("LoRa Packet received on port %d, size:%d, rssi:%d, snr:%d", app_data->port, app_data->buffsize, app_data->rssi, app_data->snr);
    switch (app_data->port)
        case LORAWAN_APP_PORT:
            // Take action on received data
 * @brief Function for handling data from temperature sensor.
 * @param[in] temp   Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint8_t temp)
    NRF_LOG_INFO("Temperature: %d Celsius degrees.", temp);
 * @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            switch (p_event->xfer_desc.type)
                case NRF_DRV_TWI_XFER_TX:
                    NRF_LOG_INFO("TWI TX Done.");
                case NRF_DRV_TWI_XFER_RX:
                    NRF_LOG_INFO("TWI RX Done.");
                    data_handler(m_sample);
            m_xfer_done = true;
 * @brief TWI initialization.
void twi_init(void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_config = {
       .scl                = PIN_TWI_SCL,
       .sda                = PIN_TWI_SDA,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false,
       .hold_bus_uninit    = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
 * @brief Function for setting active mode on LM75B temperature sensor.
void LM75B_set_mode(void)
    /* Writing to LM75B_REG_CONF "0" set temperature sensor in NORMAL mode. */
    uint8_t reg[2] = {LM75B_REG_CONF, LM75B_MODE_NORMAL};
    err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, sizeof(reg), false);
    while (m_xfer_done == false);
    /* Writing to pointer byte. */
    reg[0] = LM75B_REG_TEMP;
    err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, 1, false);
 * @brief Function for reading data from temperature sensor.
static void read_sensor_data(void)
    /* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
    ret_code_t err_code = nrf_drv_twi_rx(&m_twi, LM75B_ADDR, &m_sample, sizeof(m_sample));
// --- TWI END ---
/**@brief Function for handling a LoRa tx timer timeout event.
static void tx_lora_periodic_handler(void * unused)
    uint32_t i = 0;
//    do
//        __WFE();
//    } while (m_xfer_done == false);
//    read_sensor_data();
//    NRF_LOG_FLUSH();
    m_lora_tx_data.port = LORAWAN_APP_PORT;
    m_lora_tx_data.buffer[i++] = 0x03; // 1byte Data Channel:3
    m_lora_tx_data.buffer[i++] = 0x67; // 1byte Data Type:Temperature Sensor
    m_lora_tx_data.buffer[i++] = 0x00; // 2byte 00FA -> 250 -> 25.0C
    m_lora_tx_data.buffer[i++] = 0xFA; //
    m_lora_tx_data.buffer[i++] = 0x05; // 1byte Data Channel:5
    m_lora_tx_data.buffer[i++] = 0x01; // 2byte 0102 -> 258 -> 25.8C
    m_lora_tx_data.buffer[i++] = 0x02; //
    m_lora_tx_data.buffsize  = i;
    m_lora_tx_data.confirmed = 0;
    m_lora_tx_data.nb_trials = 8;
    lmh_send(&m_lora_tx_data);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
    // Initialize timer module.
    err_code = app_timer_init();
    // Initialize timers
    err_code = app_timer_create(&lora_tx_timer_id, APP_TIMER_MODE_REPEATED, tx_lora_periodic_handler);
static void log_init(void)
/**@brief Function for application main entry.
    uint32_t err_code;
    // Initialize logs.
    log_init();
    NRF_LOG_INFO("LoRaWan Class A example started.");
    // Initialize clocks & power
    nrf_drv_clock_init();
    nrf_pwr_mgmt_init();
    // Enable nRF52 DCDC
    NRF_POWER->DCDCEN = 1;
    // Initialize TWI
    twi_init();
    // Initialize LM75B
//    LM75B_set_mode();
    // Initialize Scheduler and timer
    timers_init();
    // Initialize LoRa chip.
    err_code = lora_hardware_init();
    // Initialize LoRaWan
    err_code = lmh_init(&lora_callbacks);
    // Start Join procedure
    lmh_join(OVER_THE_AIR_ACTIVATION);
    app_timer_start(lora_tx_timer_id, APP_TIMER_TICKS(LORAWAN_APP_TX_DUTYCYCLE), NULL);
    // Enter main loop.
    for (;;)
        lmh_process();
        app_sched_execute();
            nrf_pwr_mgmt_run();
Then I got following output at J-LINK RTT Viewer.
<info> app: LoRaWan Class A example started.
<error> app: ERROR 17 [NRF_ERROR_BUSY] at C:\Users\xxx\mydrive\ISP4520\firmware\ISP4520-examples-master\src\lora\boards\ISP4520B-AS\spi-board.c:62
PC at: 0x0000AE35
<error> app: End of error report
It appears that some other function is interfering with the initialization of the TWI.
Is this error related to the spi-board.c shown with the error code?
Please let me know if you have any links to leading information.
tyro
    One serial instance can only be used either as SPI or TWI peripheral at the same time. The GitHub library you linked are using SPI_INSTANCE 0 in the SPI init functions, while you are using the same instance 0 for your TWI_INSTANCE in above code:
    /* TWI instance. */
    You need to select a different instance in one of the codes, or make sure that SPI and TWI are not initialized at the same time.
    Jørgen
  • Hi Jørgen,
    Thanks for your advice, I have verified that the program works correctly with the following modifications.
    #define TWI_INSTANCE_ID     1
    As a beginner, I had read warnings on the blogs of my great predecessors to beware of duplicate instance IDs.
    However, I had let my guard down, thinking that it would not matter to me, as I do not set up complex programs.
    <info> app: TWI TX Done.
    <info> lmh: DevEui=70-B3-D5-7E-xx-xx-xx-xx
    <info> lmh: JoinEui=00-00-00-00-00-00-00-00
    <info> lmh: Send OTAA Join Request, status: OK
    <info> app: TWI RX Done.
    <info> app: Temperature: 29 Celsius degrees.
    <info> lmh: Send OTAA Join Request, status: Busy
    The more complex the program, the greater the opportunity to copy-paste sample code, but I would consider the possibility that the sample program reserves the ID.
    Thank you for your kind advice.
    tyro
