Failed to build FOTA firmware (nRF 1.9.1)
We have an nRF5340 application that builds fine for our custom board. However, it is not very straightforward what steps need to be performed to enable FOTA updates. I have looked into the "bluetooth/peripheral_uart" example and some tutorials, so I have added the following options in `prj.conf` :
# All below settings included from: https://devzone.nordicsemi.com/guides/nrf-connect-sdk-guides/b/software/posts/ncs-dfu
# Enable mcumgr.
CONFIG_MCUMGR=y
# Enable the Bluetooth (unauthenticated) and shell mcumgr transports.
CONFIG_MCUMGR_SMP_BT=y
CONFIG_MCUMGR_SMP_BT_AUTHEN=n
CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL=y
# CONFIG_MCUMGR_SMP_SHELL=y
# Enable most core commands.
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
# Enable custom SMP request to erase settings partition.
CONFIG_MCUMGR_GRP_ZEPHYR_BASIC=y
CONFIG_MCUMGR_GRP_BASIC_CMD_STORAGE_ERASE=y
# Allow for large Bluetooth data packets.
CONFIG_BT_L2CAP_TX_MTU=498
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_BUF_ACL_RX_SIZE=502
# Ensure an MCUboot-compatible binary is generated.
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_IMAGE_VERSION="1.0.0+0"
CONFIG_UPDATEABLE_IMAGE_NUMBER=2
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
CONFIG_MAIN_STACK_SIZE=4096
But when I build the application, I am getting the following error:
C:\Nordic_ncs\incus\zephyr\include\toolchain\gcc.h:61:36: error: static assertion failed: "Missing partitions?"
   61 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG)
C:\Nordic_ncs\incus\zephyr\subsys\mgmt\mcumgr\lib\cmd\img_mgmt\src\zephyr_img_mgmt.c:26:1: note: in expansion of macro 'BUILD_ASSERT'
   26 | BUILD_ASSERT(IMG_MGMT_UPDATABLE_IMAGE_NUMBER == 1 ||
[304/591] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/smp.c.obj
I have several questions:
1. How to make the project build for multi-image FOTA, BLE updates? Do I need to include the following in the MCUboot configuration?
CONFIG_BOOT_UPGRADE_ONLY - The simultaneous update of multiple images does not support network core image reversion, so you need to disable application image reversion.
CONFIG_PCD_APP - Enable commands exchange with the network core.
CONFIG_UPDATEABLE_IMAGE_NUMBER - Enable support for multiple update partitions by setting this option to 2.
2. I haven't found any nRF samples that demonstrate how to do an FOTA update via BLE, using the nRF5340-DK. Can you please point me to any?
3. The peripheral_uart example uses external flash for the FOTA update. We don't have an external flash chip on our custom board, will there be enough space in the internal flash storage? I read here there may not be enough: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/ug_thingy53.html#external-flash But we do have an SD card which we could use.
Thank you.
  • I was able to update the nRF5340 DK using the peripheral_uart sample and following the steps in DFU over Bluetooth. Here is the sample I used,
    5381.peripheral_uart_ble_dfu_53.zip
    Here is the diff of the changes I applied to peripheral_uart:
    diff --git a/samples/bluetooth/peripheral_uart/prj.conf b/samples/bluetooth/peripheral_uart/prj.conf
    index e5262de64..e055dfb1e 100644
    --- a/samples/bluetooth/peripheral_uart/prj.conf
    +++ b/samples/bluetooth/peripheral_uart/prj.conf
    @@ -48,3 +48,24 @@ CONFIG_LOG_BACKEND_RTT=y
     CONFIG_LOG_BACKEND_UART=n
     CONFIG_ASSERT=y
    +# Enable mcumgr.
    +CONFIG_MCUMGR=y
    +# Enable most core commands.
    +CONFIG_MCUMGR_CMD_IMG_MGMT=y
    +CONFIG_MCUMGR_CMD_OS_MGMT=y
    +# Ensure an MCUboot-compatible binary is generated.
    +CONFIG_BOOTLOADER_MCUBOOT=y
    +# Allow for large Bluetooth data packets.
    +CONFIG_BT_L2CAP_TX_MTU=252
    +CONFIG_BT_BUF_ACL_RX_SIZE=256
    +# Enable the Bluetooth (unauthenticated) and shell mcumgr transports.
    +CONFIG_MCUMGR_SMP_BT=y
    +CONFIG_MCUMGR_SMP_BT_AUTHEN=n
    +# Some command handlers require a large stack.
    +CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    \ No newline at end of file
    diff --git a/samples/bluetooth/peripheral_uart/src/main.c b/samples/bluetooth/peripheral_uart/src/main.c
    index 8a1ca1e50..c1445c13e 100644
    --- a/samples/bluetooth/peripheral_uart/src/main.c
    +++ b/samples/bluetooth/peripheral_uart/src/main.c
    @@ -32,6 +32,10 @@
     #include <logging/log.h>
    +#include <mgmt/mcumgr/smp_bt.h>
    +#include "os_mgmt/os_mgmt.h"
    +#include "img_mgmt/img_mgmt.h"
     #define LOG_MODULE_NAME peripheral_uart
     LOG_MODULE_REGISTER(LOG_MODULE_NAME);
    @@ -76,7 +80,9 @@ static const struct bt_data ad[] = {
     static const struct bt_data sd[] = {
    -	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
    +	BT_DATA_BYTES(BT_DATA_UUID128_ALL,
    +		      0x84, 0xaa, 0x60, 0x74, 0x52, 0x8a, 0x8b, 0x86,
    +		      0xd3, 0x4c, 0xb7, 0x1d, 0x1d, 0xdc, 0x53, 0x8d),
     #if CONFIG_BT_NUS_UART_ASYNC_ADAPTER
    @@ -571,6 +577,10 @@ void main(void)
     	if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED)) {
     		bt_conn_auth_cb_register(&conn_auth_callbacks);
    +	printk("build time: " __DATE__ " " __TIME__ "\n");
    +	os_mgmt_register_group();
    +	img_mgmt_register_group();
    +	smp_bt_register();
     	err = bt_enable(NULL);
     	if (err) {
    Here is the output I got
    *** Booting Zephyr OS build v2.7.99-ncs1-1  ***
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Swap type: none
    I: Bootloader chainload address offset: 0xc000
    I: Jumping to the first image slot
    Starting Nordic UART service example
    build time: Jun  7 2022 14:22:19
    I: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
    I: Swap type: test
    build time: Jun  7 2022 14:24:45
    Fullscreen
    1
    2
    3
    4
    5
    No, if you just want to update the application, you don't need to add these
    Check my attached sample above
    I was able to perform a DFU using the peripheral_uart and the nRF5340 without using external flash (confirmed it by running ninja partition_manager_report from the build folder). However, if your application is large, you might need to use external flash.
    Also, could you change your title and include 'nRF5340', so other people can find it more easily
    Simon
  • Thanks for the prompt reply . I've managed to update the application of the main processor, but I cannot update both the application processor and the network processor at the same time, using `CONFIG_UPDATEABLE_IMAGE_NUMBER=2`. I am getting the `BUILD_ASSERT(IMG_MGMT_UPDATABLE_IMAGE_NUMBER == 1` error when I try that. Is the only option to update one processor at a time? This is not ideal.
    P.S.: I am not sure I can update the title.
  • d.p said:
    Thanks for the prompt reply Simon. I've managed to update the application of the main processor, but I cannot update both the application processor and the network processor at the same time, using `CONFIG_UPDATEABLE_IMAGE_NUMBER=2`. I am getting the `BUILD_ASSERT(IMG_MGMT_UPDATABLE_IMAGE_NUMBER == 1` error when I try that. Is the only option to update one processor at a time? This is not ideal.
    Could you take a look at the machine learning sample and copy the approach there. It supports multi-image update. If this approach doesn't help you, please let me know, and I will take a deeper look at it (I don't have too much experience with multi image DFU currently). Take a look at this page as well: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.1/nrf/ug_nrf5340.html#simultaneous-multi-image-dfu
    I just talked to a developer internally, and got informed that multi img DFU (update netcore and appcore) is not supported without external flash at the moment. My apologies for that.
    I have not tested this, but I think that it should be possible put the secondary slot in the SD card. See https://devzone.nordicsemi.com/f/nordic-q-a/85987/mcuboot-secondary-slot-in-external-spi-flash
    Simon
  • Hi Simon,
    Thank you again for the reply. I finally managed to get past the assert error and successfully build our application with external flash enabled and multi-image DFU support (by following the machine learning example you pointed me to). The problem was: 1) before looking at the machine learning example, I wasn't using an mcuboot configuration file and after that 2) the build system wasn't picking up the `app.overlay` file, which was needed to create the flash simulator for the multi-image DFU.
    So I am at a stage where our app builds successfully and the partitions look like this:
    | 0x0: mcuboot_secondary (0xe0000 - 896kB)       |
    | 0xe0000: mcuboot_secondary_1 (0x40000 - 256kB) |
    | 0x120000: external_flash (0x6e0000 - 7040kB)   |
      flash_primary (0x100000 - 1024kB):
    | 0x0: mcuboot (0x10000 - 64kB)                    |
    +---0x10000: mcuboot_primary (0xe0000 - 896kB)-----+
    | 0x10000: mcuboot_pad (0x200 - 512B)              |
    +---0x10200: mcuboot_primary_app (0xdfe00 - 895kB)-+
    | 0x10200: spm (0xc000 - 48kB)                     |
    | 0x1c200: app (0xd3e00 - 847kB)                   |
    | 0xf0000: settings_storage (0x10000 - 64kB)       |
      otp (0x2fc - 764B):
    | 0xff8100: otp (0x2fc - 764B) |
      ram_flash (0x40000 - 256kB):
    | 0x0: mcuboot_primary_1 (0x40000 - 256kB) |
    | 0x40000: ram_flash (0x0 - 0B)            |
      sram_primary (0x80000 - 512kB):
    | 0x20000000: pcd_sram (0x2000 - 8kB)            |
    +---0x20002000: sram_secure (0x8000 - 32kB)------+
    | 0x20002000: spm_sram (0x8000 - 32kB)           |
    +---0x2000a000: sram_nonsecure (0x76000 - 472kB)-+
    | 0x2000a000: sram_primary (0x66000 - 408kB)     |
    | 0x20070000: rpmsg_nrf53_sram (0x10000 - 64kB)  |
    However, now I am facing another problem: Once I try to do a DFU through the Device Manager mobile app, I see the following error after the binary file transfer completes:
    State: Invalid value (3)
    This occurs no matter whether I try to update the app image, the network processor image or both at the same time. Any idea what it means?
  • Could you enable log in the application (CONFIG_LOG=y) and mcuboot (set CONFIG_MCUBOOT_LOG_LEVEL_DBG=y in the mcuboot prj.conf file) to see if you get any information what is happening on the nRF5340 and if that may be the cause of the failure.
