ble_app_multilink_central and ble_app_blinky coded phy
Hi All!
I am using ble_app_multilink_central and ble_app_blinky examples for concurrent connections of 4 devices ( (1)nrf52833 as central and other (4) as peripherals(nrf52833 + nrf52840).
Example programs are working fine when I use their default settings ( BLE_GAP_PHY_1MBPS ).
Now the issue is when I set it for long-range (coded PHY ).
For  ble_app_multilink_central  i set in sdk_config.h
NRF_BLE_SCAN_SCAN_PHY 4
 NRF_BLE_SCAN_BUFFER 255
For ble_app_blinky
adv_params.primary_phy & Secondary_phy  = BLE_GAP_PHY_CODED
adv_params.properties.type = BLE_GAP_ADV_TYPE_EXTENDED_CONNECTABLE_NONSCANNABLE_UNDIRECTED
advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE
But it's not working with that configuration!
2)I am able to work ble_app_uart and ble_app_uart_c to communicate on coded_phy with forum help. Is there any issue related to the NUS or LBS ?
Can you please help me in this regard ?
Thanks In advance!
    You also need to make sure you are passing the correct scan paramaters to the scan module, please see the 'diff' I posted here:
    https://devzone.nordicsemi.com/f/nordic-q-a/75549/coded-phy-for-blinky-peripheral-and-central
    For ble_app_blinky
    This configuration looks to be correct. Does the program crash if you try to run it?
    Vidar
  • Hello @Vidar!
    Thank you so much for the response! No program doesn't crash it remained in the scanning state. I believe the issue is in the scan_init() which you point out in the link. Thank you again I will check it and update you soon!
    Thanks & Regards,
    Muhammad Usman
  • Hi @Vidar!
    I tried with ble_app_blinky but the same issue :(, then I tried another combination (ble_multilink_uart_c_app and ble_app_uart_peri) and make changes according to your instructions and it worked for coded phy.
    Thank you for the help and time
    Muhammad Usman
