lack of nrfx_flag32_allocator.c.obj.d and system_nrf5340_network.c.obj.d
Hi ,
IDE: SES
NCS version: 1.9.1
I install the development enviroment following this article. 开发你的第一个nRF Connect SDK(NCS)/Zephyr应用程序 - iini - 博客园 (cnblogs.com)
I use the baidunetdisk to download the NCS v1,9,1. I can compile and run the example except the direction_finding_peripheral.
Here is the error.
What should I do to solve this error ?
    Can you try building with command line or the VS Code extension and see if you get the same error there?
    Please upload the output log from SES. In the output window select "Output" instead of "Tasks":
    Then copy the complete output log and upload it here by going to Insert > Code, and paste the text there.
    Please be aware that the documentation you link to is not official, so we cannot guarantee that the information there is correct. For the official documentation for nRF Connect SDK see https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.1/nrf/index.html.
    Marte
  • Hi Marte,
    I am having the same error that Jackie describes. I have also tried building in VS Code with the same outcome.
    Here is the terminal output from VS Code:
    Building threads
    west build --build-dir c:\StrAPs_fw\ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads\FW\ADC_uSD-StrAPs_prototype\threads\build_strapsprot c:\StrAPs_fw\ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads\FW\ADC_uSD-StrAPs_prototype\threads --pristine --board strapsprot -- -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=On -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DEXTRA_KCONFIG_TARGETS:STRING="menuconfig_ses" -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses:STRING="C:/ncs/v1.9.1/toolchain/segger_embedded_studio/html/configure_nordic_project_menuconfig.py" -DCONF_FILE:STRING="c:/StrAPs_fw/ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads/FW/ADC_uSD-StrAPs_prototype/threads/prj.conf"
    Including boilerplate (Zephyr base): C:/ncs/v1.9.1/zephyr/cmake/app/boilerplate.cmake
    -- Application: C:/StrAPs_fw/ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads/FW/ADC_uSD-StrAPs_prototype/threads
    -- Zephyr version: 2.7.99 (C:/ncs/v1.9.1/zephyr), build: v2.7.99-ncs1-1
    -- Found Python3: C:/ncs/v1.9.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
    -- Board: strapsprot
    -- Cache files will be written to: C:/ncs/v1.9.1/zephyr/.cache
    -- Found dtc: C:/ncs/v1.9.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (c:/ncs/v1.9.1/toolchain/opt)
    -- Found BOARD.dts: C:/ncs/v1.9.1/zephyr/boards/arm/strapprot/strapsprot.dts
    -- Generated zephyr.dts: C:/StrAPs_fw/ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads/FW/ADC_uSD-StrAPs_prototype/threads/build_strapsprot/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/StrAPs_fw/ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads/FW/ADC_uSD-StrAPs_prototype/threads/build_strapsprot/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/StrAPs_fw/ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads/FW/ADC_uSD-StrAPs_prototype/threads/build_strapsprot/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: C:/StrAPs_fw/ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads/FW/ADC_uSD-StrAPs_prototype/threads/build_strapsprot/zephyr/dts.cmake
    warning: BOARD_ENABLE_DCDC (defined at C:\ncs\v1.9.1\zephyr\boards\arm\strapprot\Kconfig:6) was
    assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies:
    BOARD_NRF52DK_NRF52832 (=n). See
    docs.zephyrproject.org/.../CONFIG_BOARD_ENABLE_DCDC.html and/or look up
    BOARD_ENABLE_DCDC in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    Parsing C:/ncs/v1.9.1/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v1.9.1/zephyr/boards/arm/strapprot/strapsprot_defconfig'
    Merged configuration 'c:/StrAPs_fw/ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads/FW/ADC_uSD-StrAPs_prototype/threads/prj.conf'
    Configuration saved to 'C:/StrAPs_fw/ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads/FW/ADC_uSD-StrAPs_prototype/threads/build_strapsprot/zephyr/.config'
    Kconfig header saved to 'C:/StrAPs_fw/ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads/FW/ADC_uSD-StrAPs_prototype/threads/build_strapsprot/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 9.2.1
    -- The CXX compiler identification is GNU 9.2.1
    -- Found assembler: C:/ncs/v1.9.1/toolchain/opt/bin/arm-none-eabi-gcc.exe
    CMake Warning at C:\ncs\v1.9.1\zephyr\CMakeLists.txt:764 (message):
    No SOURCES given to Zephyr library: drivers__serial
    Excluding target from build.
    CMake Warning at C:\ncs\v1.9.1\zephyr\CMakeLists.txt:1687 (message):
    -- Configuring done
    CMake Warning in C:/ncs/v1.9.1/zephyr/modules/hal_nordic/nrfx/CMakeLists.txt:
    The object file directory
    C:/StrAPs_fw/ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads/FW/ADC_uSD-StrAPs_prototype/threads/build_strapsprot/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/./
    has 191 characters. The maximum full path to an object file is 250
    characters (see CMAKE_OBJECT_PATH_MAX). Object file
    C_/ncs/v1.9.1/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    cannot be safely placed under this directory. The build may not work
    correctly.
    -- Generating done
    -- Build files have been written to: C:/StrAPs_fw/ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads/FW/ADC_uSD-StrAPs_prototype/threads/build_strapsprot
    [1/167] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [2/167] Generating include/generated/driver-validation.h
    [3/167] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [4/167] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [5/167] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [6/167] Generating include/generated/offsets.h
    [7/167] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [8/167] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [9/167] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [10/167] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [11/167] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [12/167] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [13/167] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [14/167] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [15/167] Generating linker_zephyr_pre0.cmd
    [16/167] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [17/167] Generating linker_zephyr_pre1.cmd
    [18/167] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [19/167] Linking C static library zephyr\arch\common\libisr_tables.a
    [20/167] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [21/167] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [22/167] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [23/167] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [24/167] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [25/167] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [26/167] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [27/167] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [28/167] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [29/167] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [30/167] Linking C static library zephyr\arch\common\libarch__common.a
    [31/167] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [32/167] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [33/167] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
    [34/167] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [35/167] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [36/167] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [37/167] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
    [38/167] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [39/167] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [40/167] Building C object zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/sdmmc_spi.c.obj
    C:\ncs\v1.9.1\zephyr\drivers\disk\sdmmc_spi.c:30:2: warning: #warning NO SDHC slot specified on board [-Wcpp]
    30 | #warning NO SDHC slot specified on board
    [41/167] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj
    [42/167] Building C object zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/fs_impl.c.obj
    [43/167] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/power.c.obj
    [44/167] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    [45/167] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [46/167] Linking C static library zephyr\lib\posix\liblib__posix.a
    [47/167] Linking C static library zephyr\drivers\disk\libdrivers__disk.a
    [48/167] Linking C static library zephyr\lib\libc\newlib\liblib__libc__newlib.a
    [49/167] Building C object zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/fat_fs.c.obj
    [50/167] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/nrf_clock_calibration.c.obj
    [51/167] Linking C static library zephyr\soc\arm\nordic_nrf\nrf52\libsoc__arm__nordic_nrf__nrf52.a
    [52/167] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/rtt_console.c.obj
    [53/167] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [54/167] Building C object zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/fs.c.obj
    [55/167] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [56/167] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [57/167] Building C object zephyr/drivers/sensor/nrf5/CMakeFiles/drivers__sensor__nrf5.dir/temp_nrf5.c.obj
    [58/167] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [59/167] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
    C:\ncs\v1.9.1\zephyr\drivers\spi\spi_nrfx_spim.c:432:36: warning: 'spi_nrfx_driver_api' defined but not used [-Wunused-const-variable=]
    432 | static const struct spi_driver_api spi_nrfx_driver_api = {
    [60/167] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spi.c.obj
    C:\ncs\v1.9.1\zephyr\drivers\spi\spi_nrfx_spi.c:272:36: warning: 'spi_nrfx_driver_api' defined but not used [-Wunused-const-variable=]
    272 | static const struct spi_driver_api spi_nrfx_driver_api = {
    [61/167] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
    [62/167] Linking C static library zephyr\drivers\console\libdrivers__console.a
    [63/167] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [64/167] Linking C static library zephyr\subsys\fs\libsubsys__fs.a
    [65/167] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
    [66/167] Linking C static library zephyr\drivers\sensor\nrf5\libdrivers__sensor__nrf5.a
    [67/167] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [68/167] Linking C static library zephyr\drivers\spi\libdrivers__spi.a
    [69/167] Building C object modules/fatfs/CMakeFiles/..__modules__fs__fatfs.dir/zfs_diskio.c.obj
    [70/167] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.9.1/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    FAILED: modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.9.1/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    C:\ncs\v1.9.1\toolchain\opt\bin\arm-none-eabi-gcc.exe -DBUILD_VERSION=v2.7.99-ncs1-1 -DKERNEL -DNRF52832_XXAA -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v1.9.1/zephyr/include -Izephyr/include/generated -IC:/ncs/v1.9.1/zephyr/soc/arm/nordic_nrf/nrf52 -IC:/ncs/v1.9.1/zephyr/lib/libc/newlib/include -IC:/ncs/v1.9.1/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v1.9.1/nrf/include -IC:/ncs/v1.9.1/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v1.9.1/modules/hal/nordic/nrfx -IC:/ncs/v1.9.1/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v1.9.1/modules/hal/nordic/nrfx/mdk -IC:/ncs/v1.9.1/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v1.9.1/modules/debug/segger/SEGGER -IC:/ncs/v1.9.1/modules/debug/segger/Config -IC:/ncs/v1.9.1/zephyr/modules/segger/. -Os -imacros C:/StrAPs_fw/ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads/FW/ADC_uSD-StrAPs_prototype/threads/build_strapsprot/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee -imacros C:/ncs/v1.9.1/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -DNRFX_RTC_ENABLED=1 -DNRFX_RTC0_ENABLED=1 -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/StrAPs_fw/ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads/FW/ADC_uSD-StrAPs_prototype/threads=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v1.9.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v1.9.1=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.9.1/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj -MF modules\hal_nordic\nrfx\CMakeFiles\modules__hal_nordic__nrfx.dir\C_\ncs\v1.9.1\modules\hal\nordic\nrfx\helpers\nrfx_flag32_allocator.c.obj.d -o modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.9.1/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj -c C:/ncs/v1.9.1/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c
    C:\ncs\v1.9.1\modules\hal\nordic\nrfx\helpers\nrfx_flag32_allocator.c:93:1: fatal error: opening dependency file modules\hal_nordic\nrfx\CMakeFiles\modules__hal_nordic__nrfx.dir\C_\ncs\v1.9.1\modules\hal\nordic\nrfx\helpers\nrfx_flag32_allocator.c.obj.d: No such file or directory
    93 | }
    compilation terminated.
    [71/167] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/54a3eef58d1853d491bb7cfc08b1508d/mdk/system_nrf52.c.obj
    [72/167] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
    [73/167] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/54a3eef58d1853d491bb7cfc08b1508d/drivers/src/nrfx_ppi.c.obj
    [74/167] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/7d812785dd9e501790071f3b45074c43/src/nrfx_clock.c.obj
    [75/167] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [76/167] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [77/167] Building C object modules/fatfs/CMakeFiles/..__modules__fs__fatfs.dir/ff.c.obj
    [78/167] Building C object CMakeFiles/app.dir/src/main.c.obj
    ../src/main.c: In function 'timer0_init':
    c:\StrAPs_fw\ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads\FW\ADC_uSD-StrAPs_prototype\threads\src\main.c:389:60: warning: passing argument 3 of 'nrfx_timer_init' from incompatible pointer type [-Wincompatible-pointer-types]
    389 | err_code = nrfx_timer_init(&m_timer0, &tmr_config, Timer_0_Interrupt_Handler);
    | void (* (*)(void))(nrf_timer_event_t, void *) {aka void (* (*)(void))(enum <anonymous>, void *)}
    In file included from c:\StrAPs_fw\ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads\FW\ADC_uSD-StrAPs_prototype\threads\src\main.c:12:
    C:\ncs\v1.9.1\modules\hal\nordic\nrfx\drivers\include\nrfx_timer.h:142:56: note: expected 'nrfx_timer_event_handler_t' {aka 'void (*)(enum <anonymous>, void *)'} but argument is of type 'void (* (*)(void))(nrf_timer_event_t, void *)' {aka 'void (* (*)(void))(enum <anonymous>, void *)'}
    142 | nrfx_timer_event_handler_t timer_event_handler);
    ../src/main.c: In function 'init':
    c:\StrAPs_fw\ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads\FW\ADC_uSD-StrAPs_prototype\threads\src\main.c:615:63: warning: passing argument 4 of 'k_thread_create' from incompatible pointer type [-Wincompatible-pointer-types]
    615 | k_thread_create(&th_ledg_blink_id, stack_area, STACKSIZE, ledg_blink, NULL, NULL, NULL, TH_PRIORITY_7, 0, K_NO_WAIT);
    | void (*)(void)
    In file included from C:\ncs\v1.9.1\zephyr\include\kernel.h:5911,
    from C:\ncs\v1.9.1\zephyr\include\zephyr.h:18,
    from c:\StrAPs_fw\ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads\FW\ADC_uSD-StrAPs_prototype\threads\src\main.c:7:
    c:\StrAPs_fw\ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads\FW\ADC_uSD-StrAPs_prototype\threads\build_strapsprot\zephyr\include\generated\syscalls\kernel.h:35:131: note: expected 'k_thread_entry_t' {aka 'void (*)(void *, void *, void *)'} but argument is of type 'void (*)(void)'
    35 | static inline k_tid_t k_thread_create(struct k_thread * new_thread, k_thread_stack_t * stack, size_t stack_size, k_thread_entry_t entry, void * p1, void * p2, void * p3, int prio, uint32_t options, k_timeout_t delay)
    ../src/main.c: In function 'Timer_0_Interrupt_Handler':
    c:\StrAPs_fw\ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads\FW\ADC_uSD-StrAPs_prototype\threads\src\main.c:377:1: warning: control reaches end of non-void function [-Wreturn-type]
    377 | }
    [79/167] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/7d812785dd9e501790071f3b45074c43/src/nrfx_gpiote.c.obj
    FATAL ERROR: command exited with status 1: 'c:\ncs\v1.9.1\toolchain\opt\bin\cmake.EXE' --build 'c:\StrAPs_fw\ecg-python-model-main-FW-ADC_uSD-StrAPs_prototype-threads\FW\ADC_uSD-StrAPs_prototype\threads\build_strapsprot'
    The terminal process terminated with exit code: 1.
    Terminal will be reused by tasks, press any key to close it.
  • Hi Marte,
    I am having the same error as Jackie reports, I have also tried building in VS Code with the same outcome.
    The error I have is: opening dependency file modules\hal_nordic\nrfx\CMakeFiles\modules__hal_nordic__nrfx.dir\C_\ncs\v1.9.1\modules\hal\nordic\nrfx\helpers\nrfx_flag32_allocator.c.obj.d: No such file or directory
  • Additionally, the nrfx\helpers directory only contains the c and header files for the helpers, there are no built obj.d files.
