Problems with nrf5340 audio example
When I use two nrf5340 audio DK to test the LE audio demo, the handset side always crashes. Especially when I move the DK that is used as the handset.I think that incomplete data reception due to compromised communication can cause a crash problem.
Configuration:
CONFIG_SW_CODEC_SBC=y
Logs:
HL [00:01:39.629,425] <wrn> sw_codec_select: PCM samples dropped
HL [00:01:39.629,425] <err> audio_datapath: Decoded audio has wrong size
HL [00:01:39.629,455] <err> audio_datapath: ERR_CHK Err_code: [-140] @ line: 833
HL [00:01:39.6os: r0/a1:  0x00000003  r1/a2:  0x00000006  r2/a3:  0x00000005
 [00:01:39.629,455] <err> os:  xpsr:  0x41000000d0 r12/ip:  0x00000002 r14/lr:  0x000177ed
HL [00:01:39.629,455] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
HL [00:01:39.629,486] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
HL [029,486] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
HL [00:01:39.629,486] <err> os: s[12]:  0x00000000  s[13]:  0xffffffff  s[14]:  0x00000000  s[15]:  0x00000000
HL [00:01:39.629,516] <err> os: fpscr:  0xffffffff
HL [00:01:39.629,516] <err> os: Faulting instruction address (r15/pc): 0x00006104
HL [00:01:39.629,516] R FATAL ERROR 3: Kernel oops on CPU 0
HL [00:01:39.629,547] <err> os: Current thread: 0x20001648 (AUDIO DATAPATH)
HL [00:01:39.629,547] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
And when use ''CONFIG_TRANSPORT_BIS=y'' same as above.
    In addition to setting CONFIG_TRANSPORT_BIS=y in the prj.conf you will need to go into overlay-headset.conf and overlay-gateway.conf and delete these two:
    CONFIG_LC3_ENC_CHAN_MAX=2
    CONFIG_LC3_DEC_CHAN_MAX=1.
    Please do this, and let me know if it resolves your issue.
    Karl
  • As a side-note: I highly recommend that you make use of the LC3 codec for your evaluation and development wherever possible - it is really a major improvement over the SBC! :)
    Karl
  • Hi Karl,
    I have deleted these two, otherwise I cannot compile code.Obviously,the problems I mentioned occurred during the DK is running.
    Chen
  • Could you provide the full log from the headset side?
    Could you also confirm whether you have any many other modifications to the application other than the BIS configuration + 3 changes for the SBC mentioned earlier?
    Karl
  • All my changes:
    chen@ubuntu:~/ncs/nrf$ git diff
    diff --git a/applications/nrf5340_audio/overlay-gateway.conf b/applications/nrf5340_audio/overlay-gateway.conf
    index 251eea3d7..734572e58 100644
    --- a/applications/nrf5340_audio/overlay-gateway.conf
    +++ b/applications/nrf5340_audio/overlay-gateway.conf
    @@ -41,5 +41,5 @@ CONFIG_BT_MAX_CONN=2
     CONFIG_BT_ISO_MAX_CHAN=2
     CONFIG_BT_MAX_PAIRED=2
    -CONFIG_LC3_ENC_CHAN_MAX=2
    -CONFIG_LC3_DEC_CHAN_MAX=1
    +# CONFIG_LC3_ENC_CHAN_MAX=2
    +# CONFIG_LC3_DEC_CHAN_MAX=1
    diff --git a/applications/nrf5340_audio/overlay-headset.conf b/applications/nrf5340_audio/overlay-headset.conf
    index abff0b37c..1bc0df0ea 100644
    --- a/applications/nrf5340_audio/overlay-headset.conf
    +++ b/applications/nrf5340_audio/overlay-headset.conf
    @@ -19,5 +19,5 @@ CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=n
     CONFIG_BT_MAX_CONN=1
     CONFIG_BT_ISO_MAX_CHAN=1
    -CONFIG_LC3_ENC_CHAN_MAX=1
    +# CONFIG_LC3_ENC_CHAN_MAX=1
    diff --git a/applications/nrf5340_audio/prj.conf b/applications/nrf5340_audio/prj.conf
    index d11231555..9c40681a9 100644
    --- a/applications/nrf5340_audio/prj.conf
    +++ b/applications/nrf5340_audio/prj.conf
    @@ -40,7 +40,7 @@ CONFIG_BT_PER_ADV=y
     CONFIG_BT_ISO_UNICAST=y
     CONFIG_BT_ISO_BROADCASTER=y
     CONFIG_BT_ISO_SYNC_RECEIVER=y
    +CONFIG_SW_CODEC_SBC=y
     # Temporary, enable the following to meet BT_ISO dependencies
     CONFIG_BT_OBSERVER=y
     CONFIG_BT_PERIPHERAL=y
    (END)
    Full log:
    *** Booting Zephyr OS build v3.0.99-ncs1  ***
    HL [00:00:00.250,885] <inf> audio_sync_timer: Audio sync timer initialized
    HL [00:00:00.251,068] <dbg> nrf5340_
                                        HL [00:00:00.251,129] <dbg> nrf5340_audio_dk_nrf5340_cpuapp: remoteproc_mgr_boot: Network MCU released.
    HL [00:00:00.255,889] <inf> fw_info:
             nRF5340 Audio nRF5340 Audio DK cpuapp
             FW Version: 0.5.99
             Cmake run : Mon Jun 06 17:36:32 2022
    HL [00:00:00.255,889] <inf> fw_info: ------- DEBUG BUILD -------
             HEADSET left device
    HL [00:00:00.266,479] <inf> board_version: Compatible board/HW version found: 1.0.0
    HL [00:00:00.330,902] <wrn> bt_hci_core: Controller to host flow control not supported
    HL [00:00:00.458,831] <inf> ble: MAC: D9:D0:F0:B6:A9:84 (random)
    HL [00:00:00.459,045] <inf> ble: Controller version: 3269
    HL [00:00:00.537,902] <wrHL [00:00:06.640,838] <inf> streamctrl: BLE evt connected
    HL [00:00:06.640,869] <inf> streamctrl: BLE evt link ready
    HL [00:00:15.631,134] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:00:15.632,110] <wrn> audio_datapath: Data received, total underruns: 9
    HL [00:00:15.731,140comp state: LOCKED
    HL [00:00:16.200,531] <inf> audio_datapath: Pres comp state: MEAS
    HL [00:00:16.310,516] <inf> audio_datapath: Pres comp state: WAIT
    HL [0atapath: Pres comp state: INIT
    HL [00:00:16.380,523] <inf> audio_datapath: Pres comp state: MEAS
    HL [00:00:16.490,539] <inf> audio_datapath: Pres comp state: LOCKED
    HL [00:00:21.500,762] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
    HL [00:00:30.311,187] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
    HL [00:00:31.641,235] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
    HL [00:00:31.741,241] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
    HL [00:00:33.061,309] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
    HL [00:00:36.111,450] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
    HL [00:00:40.931,671] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
    HL [00:00:40.981,689] <wrn> audio_datapath: Invalid sd_us
    HL [00:00:41.061,676] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
    HL [00:00:41.471,710] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
    HL [00:00:41.981,719] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
    HL [00:00:42.291,748] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
    HL [00:00:46.491,943] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
    HL [00:00:47.091,979] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
    HL [00:00:47.124,481] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
    HL PCM samples dropped
    HL [00:00:47.124,542] <err> audio_datapath: Decoded audio has wrong size
    HL [00:00:47.124,542] <err> audio_datapath: ERR_CHK Err_code: [-140] @ line: 833
    HL [00:00:47.124,572] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000006  r2/a3:  0x00000005
    HL [00:00:47.124,572] <err> os: r3/a4:  0x20001dd0 r12/ip:  0x00000002 r14/lr:  0x000177ed
    HL [00:00:47.124,572] <err> os:  xpsr:  0x41000000
    HL [00:00:47.124,572] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
    HL [00:00:47.124,603] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
    HL [00:00:47.124,603] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
    HL [00:00:47.124,603] <err> os: s[12]:  0x00000000  s[13]:  0xffffffff  s[14]:  0x00000000  s[15]:  0x47.124,603] <err> os: fpscr:  0xffffffff
    HL [00:00:47.124,633] <err> os: Faulting instruction address (r15/pc): 0x00006104
    HL [00:00:47.124,6: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
    HL [00:00:47.124,633] <err> os: Current thread: 0x20001648 (AUDIO DATAPATH)
    HL [00:00:47.124,664] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
