Using pstorage along with the mesh
I've read several of the questions on here related to pstorage, including one poster who had trouble running it in conjunction with the mesh. I decided to take my PCA10031 dongle and program it with the mesh template example using the latest SDK (8.1) and S110 SoftDevice. Then, using the pstorage examples, I attempted to do a clear, store, and load. I simply cannot get this to work. My shortened code is below. Neither the callback or the sys_evt_dispatch() function is called. I was somewhat successful with previous attempts (on my own hardware), but it would take 20+ seconds before the first call to the callback was made. Can anyone please give me some clues? (Note that I am not doing BLE advertising - only running the mesh by itself - the template example). I am using the latest mesh from this past week. I am using Keil 5.14. Optimization level 0.
Thanks in advance. -s
static int pstorage_flag = false;
void rbc_mesh_event_handler(rbc_mesh_event_t* evt)
  switch (evt->event_type)
    case RBC_MESH_EVENT_TYPE_CONFLICTING_VAL:
    case RBC_MESH_EVENT_TYPE_NEW_VAL:
    case RBC_MESH_EVENT_TYPE_UPDATE_VAL:
    case RBC_MESH_EVENT_TYPE_INITIALIZED:
void example_cb_handler(pstorage_handle_t * handle, uint8_t op_code,
        uint32_t result, uint8_t * p_data, uint32_t data_len)
  switch (op_code)
    case PSTORAGE_LOAD_OP_CODE:
    case PSTORAGE_STORE_OP_CODE:
    case PSTORAGE_CLEAR_OP_CODE:
      if (result == NRF_SUCCESS)
        pstorage_flag = true;
static void sys_evt_dispatch(uint32_t sys_evt)
  pstorage_sys_event_handler(sys_evt);
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
static uint8_t my_buffer[32];
static pstorage_handle_t m_p_example_id;
static uint8_t dummy_data[16] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15 };
  SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_75_PPM, rbc_mesh_sd_irq_handler);
  rbc_mesh_init_params_t init_params;
  init_params.access_addr = 0xA541A68F;
  init_params.adv_int_ms = 100;
  init_params.channel = 38;
  init_params.handle_count = 1;
  init_params.packet_format = RBC_MESH_PACKET_FORMAT_ORIGINAL;
  init_params.radio_mode = RBC_MESH_RADIO_MODE_BLE_1MBIT;
  uint32_t error_code;
  error_code = rbc_mesh_init(init_params);
  APP_ERROR_CHECK(error_code);
  error_code = rbc_mesh_value_enable(1);
  error_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
  error_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
  pstorage_module_param_t p_example_param;
  p_example_param.block_size  = 0x10;
  p_example_param.block_count = 60;
  p_example_param.cb          = example_cb_handler;
  error_code = pstorage_init();
  error_code = pstorage_register (&p_example_param, &m_p_example_id);
  uint16_t dummy_block = 0;
  uint16_t dummy_size = 16;
  uint16_t dummy_offset = 0;
  pstorage_handle_t p_block_id;
  error_code = pstorage_block_identifier_get(&m_p_example_id, dummy_block, &p_block_id);
  error_code = pstorage_clear(&p_block_id, 60 * 16);
  while (pstorage_flag == false) {  }
  error_code = pstorage_store(&p_block_id, dummy_data, dummy_size, dummy_offset);
  while (pstorage_flag == 0) {  }
  error_code = pstorage_load(my_buffer, &p_block_id, dummy_size, dummy_offset);
  while (true)
    sd_app_evt_wait();
  • Hi, sorry I haven't seen this post until now!
    It's been a few days since you posted this, but in case you haven't found the solution yet, here it is:
    The last parameter of your call to SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_75_PPM, rbc_mesh_sd_irq_handler); is the scheduler function the softdevice handler should use. Since we supply it with the default rbc_mesh-scheduler function (which consumes our events!), the softdevice handler will simply pass all events to the mesh, which will promptly ignore them. If you change the call to SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_75_PPM, NULL);, the softdevice handler will use its own internal scheduler, which does call your assigned event handlers!
    Confirmed working on today's release (v0.6.9) of the mesh, but let me know if you have any further issues.
    Also, if you have any different issues in the future, you are more likely to get a fast response if you report the issue directly on the github project page :)
