Tutorial on Connection Encryption
I have not found a lot of information on connection encryption. I want to use a preprogrammed Long Term Key in my mesh that is then used to establish subsequent connections. How would I start with this?
And very important: i can not use the device manager. (partly because it does not support peripheral and central at the same time and partly because I think it is too big for what I need it.)
The message sequence charts did not help me much and I have not found any example that explains security in detail. Neither did I find a tutorial or anything else. Where do I start?
Marius
    Thanks, I'll read your response in detail tomorrow. In the meantime I've just managed to get something running. Here's what I do:
     - Central and Peripheral connect and start an unencrypted connection.
     - The Central calls sd_ble_gap_encrypt with an ediv(keyid?) of 0 and an 8 byte random number
     - The Peripheral receives the BLE_GAP_EVT_SEC_INFO_REQUEST and calls sd_ble_gap_sec_info_reply with its key (which is the same)
     - Both sides receive the BLE_GAP_EVT_CONN_SEC_UPDATE
    I've set the auth property of both keys to 1.
    Now, did I encrypt this connection successfully?
    (I've also implemented the method with the events and functions that you've mentioned but there were quite a few parameters in there that I was just guessing, so I tested this method instead)
    As for the tutorial, it would be nice to have an explanation of most of the parameters, the API documentation is not extensive enough. Most of that stuff is documented somewhere in the BLE spec, but it would be nice if you could provide references for how the procedures as a whole work. Just link to some other online resources.
  • I've just converted my comment to an answer, but sadly, this does not move the subcomments under this answer, so the comments are still under the Answer of Hung Bui. As a summary, both solutions did work for me and were able to encrypt the connection with security mode 1, level 3.
    This answer is less implementation effor for what I need it.
