SDK Version: 1.9.1
Tool Chain Version: 1.9.1
Cortex Debug Extension Version: v1.4.4
I'm unable to debug my nRF9160 project using VSCode Debugger Extension. The same project can be debugged with zero issues using Segger Embedded Studio. This leads me to believe there is something not working with the VSCode Debugger.
I'm using a custom board whose definition is derived from nRF9160DK devicetree and configurations in V1.8.0. So I have three images in the build - MCUBoot (immutable), SPM, and Application.
The following log is obtained when the issue occurred.
Debug Console
Cortex-Debug: VSCode debugger extension version 1.5.1 git(89a84bd). Usaage info: https://github.com/Marus/cortex-debug#usage Warn: d:/Projects\TCP\Pallet\Source\Gateway\gateway_app\build_dbg\zephyr\merged.hex is not an ELF file format. Some features won't work -- Globals, Locals, disassembly, etc.Launching GDB: "c:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\arm-none-eabi-gdb.exe" -q --interpreter=mi2 "d:/Projects\\TCP\\Pallet\\Source\\Gateway\\gateway_app\\build_dbg\\zephyr\\merged.hex" IMPORTANT: Set "showDevDebugOutput": "raw" in "launch.json" to see verbose GDB transactions here. Very helpful to debug issues or report problems Launching gdb-server: "C:\\Program Files (x86)\\SEGGER\\JLink\\JLinkGDBServerCL.exe" -singlerun -nogui -if swd -port 50000 -swoport 50001 -telnetport 50002 -device nRF9160_xxAA -select usb=51017929 -rtos "C:\\Program Files (x86)\\SEGGER\\JLink\\GDBServer\\RTOSPlugin_Zephyr.dll" Please check TERMINAL tab (gdb-server) for output from C:\Program Files (x86)\SEGGER\JLink\JLinkGDBServerCL.exe WARNING: Cortex-Debug will deprecate use of GDB version 8 after July 2022. Please upgrade to version 9+ Reading symbols from d:/Projects\TCP\Pallet\Source\Gateway\gateway_app\build_dbg\zephyr\merged.hex... (No debugging symbols found in d:/Projects\TCP\Pallet\Source\Gateway\gateway_app\build_dbg\zephyr\merged.hex) 0x00000440 in ?? () Program stopped, probably due to a reset and/or halt issued by debugger add symbol table from file "d:/Projects/TCP/Pallet/Source/Gateway/gateway_app/build_dbg/zephyr/zephyr.elf" (y or n) [answered Y; input not from terminal] Reading symbols from d:/Projects/TCP/Pallet/Source/Gateway/gateway_app/build_dbg/zephyr/zephyr.elf... add symbol table from file "d:/Projects/TCP/Pallet/Source/Gateway/gateway_app/build_dbg/mcuboot/zephyr/zephyr.elf" (y or n) [answered Y; input not from terminal] Reading symbols from d:/Projects/TCP/Pallet/Source/Gateway/gateway_app/build_dbg/mcuboot/zephyr/zephyr.elf... add symbol table from file "d:/Projects/TCP/Pallet/Source/Gateway/gateway_app/build_dbg/spm/zephyr/zephyr.elf" (y or n) [answered Y; input not from terminal] Reading symbols from d:/Projects/TCP/Pallet/Source/Gateway/gateway_app/build_dbg/spm/zephyr/zephyr.elf...
Debug Terminal
[2022-06-08T00:36:10.214Z] SERVER CONSOLE DEBUG: onBackendConnect: gdb-server session connected. You can switch to "DEBUG CONSOLE" to see GDB interactions. "C:\\Program Files (x86)\\SEGGER\\JLink\\JLinkGDBServerCL.exe" -singlerun -nogui -if swd -port 50000 -swoport 50001 -telnetport 50002 -device nRF9160_xxAA -select usb=51017929 -rtos "C:\\Program Files (x86)\\SEGGER\\JLink\\GDBServer\\RTOSPlugin_Zephyr.dll" SEGGER J-Link GDB Server V7.58b Command Line Version JLinkARM.dll V7.58b (DLL compiled Nov 16 2021 15:00:10) Command line: -singlerun -nogui -if swd -port 50000 -swoport 50001 -telnetport 50002 -device nRF9160_xxAA -select usb=51017929 -rtos C:\Program Files (x86)\SEGGER\JLink\GDBServer\RTOSPlugin_Zephyr.dll -----GDB Server start settings----- GDBInit file: none GDB Server Listening port: 50000 SWO raw output listening port: 50001 Terminal I/O port: 50002 Accept remote connection: localhost only Generate logfile: off Verify download: off Init regs on start: off Silent mode: off Single run mode: on Target connection timeout: 0 ms ------J-Link related settings------ J-Link Host interface: USB J-Link script: none J-Link settings file: none ------Target related settings------ Target device: nRF9160_xxAA Target interface: SWD Target interface speed: 4000kHz Target endian: little Connecting to J-Link... J-Link is connected. Firmware: J-Link V11 compiled Nov 16 2021 11:59:06 Hardware: V11.00 S/N: 51017929 Feature(s): GDB Checking target voltage... Target voltage: 2.72 V Listening on TCP/IP port 50000 Connecting to target... Connected to target Waiting for GDB connection...Connected to 127.0.0.1 Reading all registers Read 4 bytes @ address 0x00000440 (Data = 0x4B21B57F) Read 2 bytes @ address 0x00000440 (Data = 0xB57F) Loading RTOS plugin: C:\Program Files (x86)\SEGGER\JLink\GDBServer\RTOSPlugin_Zephyr.dll... RTOS plugin (API v1.1) loaded successfully RTOS plugin: Loaded Received symbol: _kernel (0x200151C8) Received symbol: _kernel_openocd_offsets (0x00035858) Received symbol: z_sys_post_kernel (0x20015392) All mandatory symbols successfully loaded. Read 4 bytes @ address 0x00000440 (Data = 0x4B21B57F) All mandatory symbols successfully loaded. Read 4 bytes @ address 0x00000440 (Data = 0x4B21B57F) All mandatory symbols successfully loaded. Received monitor command: halt Halting target CPU... ...Target halted (PC = 0x00000440) Received monitor command: reset Resetting target Downloading 16096 bytes @ address 0x00000000 Downloading 4932 bytes @ address 0x00003EE0 Downloading 16128 bytes @ address 0x00008000 Downloading 16352 bytes @ address 0x0000BF00 Downloading 288 bytes @ address 0x0000FEE0 Downloading 16176 bytes @ address 0x00010000 Downloading 16128 bytes @ address 0x00013F30 Downloading 16048 bytes @ address 0x00017E30 Downloading 16016 bytes @ address 0x0001BCE0 Downloading 1168 bytes @ address 0x0001FB70 Downloading 16144 bytes @ address 0x00020000 Downloading 15920 bytes @ address 0x00023F10 Downloading 15952 bytes @ address 0x00027D40 Downloading 15968 bytes @ address 0x0002BB90 Downloading 1552 bytes @ address 0x0002F9F0 Downloading 15984 bytes @ address 0x00030000 Downloading 16240 bytes @ address 0x00033E70 Downloading 16256 bytes @ address 0x00037DE0 Downloading 6448 bytes @ address 0x0003BD60 Comparing flash [....................] Done. Writing register (PC = 0x 0) Received monitor command: reset Resetting target Read 4 bytes @ address 0x00000000 (Data = 0x20011388) Read 2 bytes @ address 0x00000000 (Data = 0x1388) Reading 64 bytes @ address 0x0000BCC0 Read 2 bytes @ address 0x00000440 (Data = 0xB57F) Read 2 bytes @ address 0x00012310 (Data = 0xB538) Read 2 bytes @ address 0x0000BCE4 (Data = 0xB508) Reading register (MSP = 0x20011388) Reading register (PSP = 0x 0) Reading register (PRIMASK = 0x 0) Reading register (BASEPRI = 0x 0) Reading register (FAULTMASK = 0x 0) Reading register (CONTROL = 0x 0) Reading register (FPSCR = 0x 0) Reading register (s0 = 0x 0) Reading register (s1 = 0x 0) Reading register (s2 = 0x 0) Reading register (s3 = 0x 0) Reading register (s4 = 0x 0) Reading register (s5 = 0x 0) Reading register (s6 = 0x 0) Reading register (s7 = 0x 0) Reading register (s8 = 0x 0) Reading register (s9 = 0x 0) Reading register (s10 = 0x 0) Reading register (s11 = 0x 0) Reading register (s12 = 0x 0) Reading register (s13 = 0x 0) Reading register (s14 = 0x 0) Reading register (s15 = 0x 0) Reading register (s16 = 0x 0) Reading register (s17 = 0x 0) Reading register (s18 = 0x 0) Reading register (s19 = 0x 0) Reading register (s20 = 0x 0) Reading register (s21 = 0x 0) Reading register (s22 = 0x 0) Reading register (s23 = 0x 0) Reading register (s24 = 0x 0) Reading register (s25 = 0x 0) Reading register (s26 = 0x 0) Reading register (s27 = 0x 0) Reading register (s28 = 0x 0) Reading register (s29 = 0x 0) Reading register (s30 = 0x 0) Reading register (s31 = 0x 0) Reading register (d0 = 0x 0) Reading register (d1 = 0x 0) Reading register (d2 = 0x 0) Reading register (d3 = 0x 0) Reading register (d4 = 0x 0) Reading register (d5 = 0x 0) Reading register (d6 = 0x 0) Reading register (d7 = 0x 0) Reading register (d8 = 0x 0) Reading register (d9 = 0x 0) Reading register (d10 = 0x 0) Reading register (d11 = 0x 0) Reading register (d12 = 0x 0) Reading register (d13 = 0x 0) Reading register (d14 = 0x 0) Reading register (d15 = 0x 0) Reading register (MSP_S = 0x20011388) Reading register (MSPLIM_S = 0x 0) Reading register (PSP_S = 0x 0) Reading register (PSPLIM_S = 0x 0) Reading register (MSP_NS = 0x 0) Reading register (MSPLIM_NS = 0x 0) Reading register (PSP_NS = 0x2000F780) Reading register (PSPLIM_NS = 0x 0) Reading register (CONTROL_S = 0x 0) Reading register (FAULTMASK_S = 0x 0) Reading register (BASEPRI_S = 0x 0) Reading register (PRIMASK_S = 0x 0) Reading register (CONTROL_NS = 0x 0) Reading register (FAULTMASK_NS = 0x 0) Reading register (BASEPRI_NS = 0x 0) Reading register (PRIMASK_NS = 0x 0) Setting breakpoint @ address 0x00000440, Size = 2, BPHandle = 0x0001 Setting breakpoint @ address 0x0000BCE4, Size = 2, BPHandle = 0x0002 Setting breakpoint @ address 0x00012310, Size = 2, BPHandle = 0x0003 Starting target CPU... ...Breakpoint reached @ address 0x00000440 Parsed thread 655765532, next=0 Reading all registers Read register 0 (4 bytes) from DLL: 04000000 Read register 1 (4 bytes) from DLL: 00000000 Read register 2 (4 bytes) from DLL: 01000000 Read register 3 (4 bytes) from DLL: A44F0000 Read register 4 (4 bytes) from DLL: AD220000 Read register 5 (4 bytes) from DLL: 20000000 Read register 6 (4 bytes) from DLL: 88EB0020 Read register 7 (4 bytes) from DLL: 00000000 Read register 8 (4 bytes) from DLL: 00000000 Read register 9 (4 bytes) from DLL: 00000000 Read register 10 (4 bytes) from DLL: 00000000 Read register 11 (4 bytes) from DLL: 00000000 Read register 12 (4 bytes) from DLL: 50050020 Read register 13 (4 bytes) from DLL: 80130120 Read register 14 (4 bytes) from DLL: C9220000 Read register 15 (4 bytes) from DLL: 40040000 Read register 16 (4 bytes) from DLL: 00000069 Removing breakpoint @ address 0x00000440, Size = 2 Removing breakpoint @ address 0x0000BCE4, Size = 2 Removing breakpoint @ address 0x00012310, Size = 2
I tried debugging one of sample, "nRF9160/AT Client", and the same custom board can be debugged fine.
Seeing how SDK V2.0.0 onwards no longer support Segger, I would like to sort this issue out once and for all before migrating to V2.0.0.
