Unable to detect nRF9160 chip after flashing over JTAG via nRF9160-DK dev board
We have developed a prototype board based on the Thingy91 which contains both the nRF9160 and nRF52840 and many of the same connections.
However, after a few successful attempts to flash both chips via the VS Code Nordic extension, the nRF9160 has become unresponsive.
Using this same setup of nRF9160-DK to our PCBA via the JTAG connector, we have successfully connected to the nRF52840 on the faulty board; both chips on the Thingy91 and both chips on another of our prototype boards. I have listed the devices found on the faulty board and working prototype below:
Correct Faulty
When attempting to connect to the "J-Link" device presented by the faulty board in the programmer we receive the following error message:
"Unsupported device. The detected device could not be recognized as neither JLink device nor Nordic USB device."
Additionally, when attempting to "Erase and Flash" the faulty board we receive the following error message:
Flashing build to undefined
west flash -d c:\nordic\apps\hello_world\build --skip-rebuild -r nrfjprog --dev-id 960033515 --erase
-- west flash: using runner nrfjprog
-- runners.nrfjprog: mass erase requested
-- runners.nrfjprog: Flashing file: C:\nordic\apps\hello_world\build\zephyr\merged.hex
ERROR: Unable to connect to a debugger.
ERROR: The --family option given with the command (or the default from
ERROR: nrfjprog.ini) does not match the device connected.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 18: nrfjprog --program 'C:\nordic\apps\hello_world\build\zephyr\merged.hex' --chiperase --verify -f NRF91 --snr 960033515
The terminal process terminated with exit code: 18.
Any help would be appreciated.
  • Hey Markus,
    Thank-you for getting back to me. Since uploading the bootloader image to the nrf52840 we are no longer running into issues with finding the nrf9160 SoC.
    However, with the 91 running the hello_world example script and the 52 running the bootloader image we are seeing an average current draw of 2.44mA, an order of magnitude higher than the uA of current we expected when using your chips in low power mode with all peripherals disconnected.
    Please could you advise why this current is much higher than expected and how to mitigate it?
