twi_scanner for nRF52840DK + nRF Connect SDK
Hello!
I have a nRF52840DK with a custom board. I have installed nRF 1.9.1. I have read about the twi_scanner but I don't find that code in my installation! Did I do anything wrong? How can I develop a twi_scanner for my nRF Connect environment?
David.
  • Hi there!
    Moving forward, I have compiled a version that seems to work (initially). However, I get stuck:
    - I execute a successful nrfx_twim_xfer(&i2c_instance, &xdesc, 0)
    - My evt_handler doesn't get invoked
    - nrfx_twim_is_busy(&i2c_instance) is always true
    So i cannot invoke nrfx_twim_xfer any more.
    As this is a twim_scanner it is very likely that the address I'm polling doesn't belong to any device (so nobody will never reply), so, my questions:
    1. If I poll an address with no device, will the library stay on busy forever?
    2. Is there a way to check for a timeout, clear the busy state and run more transfers?
    David.
    Have you remembered to enable the interrupts by calling IRQ_DIRECT_CONNECT() and irq_enable() in your init routine?
    Something like this:
    	IRQ_DIRECT_CONNECT(SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQn, 0, nrfx_twim_0_irq_handler, 0);
    	irq_enable(SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQn);
    The callback handler won't be invoked if this hasn't been done already.
    regards
    Jared
  • Hi Jared:
    No, I didn't know it. I will try later and come back here.
    Thank you,
    David.
  • Thank you Jared, it worked; my event handler is now being invoked and the device is not busy any more.
    David.
