How shall i define Service Data in BLE Scan Response Data ?
This is the implemenatation spec for GATT server database (reader) firmware i am working on.
I have implemented advertisement packet using nRF Connect SDK latest.
Not sure how to declare 8-byte Service Data ?
I have the 8-byte value with me.
This is how i have implemented
            uint8_t reader_serial_number[8] = some value;
            const struct bt_data service_sd[] =
                BT_DATA_SVC_DATA16, 8, reader_serial_number
But in the mobile app it shows like
Service Data: UUID: first two bytes (flipped bytes) and Data: Last 6 bytes correct order
Not sure what is wrong. Please explain and correct my implementation.
Thanks.
  • Are you configuring this in the ad data or scan response data?
    Looking at other samples the could be something like this
                    BT_DATA_BYTES(BT_DATA_SVC_DATA16, 8, reader_serial_number);
  • In scan response Data.
    Your response has a syntax error.
  • Ok, i got it to work by trying various syntax
                    BT_DATA_BYTES(BT_DATA_SVC_DATA128, BT_UUID_SERVICE_VAL, reader_serial_number[0],
        reader_serial_number[1],
        reader_serial_number[2],
        reader_serial_number[3],
        reader_serial_number[4],
        reader_serial_number[5],
        reader_serial_number[6],
        reader_serial_number[7]),
    The field 'service data' has two propoerties to fill in : UUID and Data. UUID is same as Primary Service
