Hi ,
How to check the time taken by the mcuboot to boot the controller(MCUBOOT Boot time) .
Hi ,
Could you clarify what you meant by "controller" ?
One easy way of measuring the booting time to turn on an GPIO pin when the device finish booting. You can use a logic analyzer or oscilloscope to measure the time when you press the reset button (or power button) until the time the GPIO pin is turned on.
i meant to say , mcuboot boot up time for nrf52dk_nrf52832 board. there is requirement that i need to have boot time as much as less as possible. so that is why am wondering how can i reduce it, kindly suggest.
I don't think there is much you can do reduce that. You can think of turn off any logging on MCUBoot. But I don't it would have any significant effect.
Do you think that it's an issue with your current boot time ? Could you try to measure it ?
Yes actually , to check boot up time i have modified the mcuboot main.c as below and i was testing. am getting around 413 ms. which is too large as compared to my requirement. so that is why am curious to know what is the minimum boot up time , for nrf52832 board.
ZEPHYR_BOOT_LOG_STOP(); int64_t timestamp = k_uptime_get(); //added to check time BOOT_LOG_INF("Bootloader running time: %d",timestamp); //added to check time do_boot(&rsp);
regards,
shikamaru
Hi Shikamaru,
I can see the same booting time here. From my understanding it's the time it take for the kernel to start the 32kHz crystal. Zephyr will wait until the crystal is ready.
If you try this:
