I am using the light_bulb sample from NCS v2.0.0 with an nRF52840 DK board. I changed prj.conf to enable Warning traces from ZBOSS:
+# Enable traces on UART_1 (P1.02) @ 115200bps
+CONFIG_ZIGBEE_ENABLE_TRACES=y
+CONFIG_ZBOSS_TRACE_MASK=0x0003
+CONFIG_ZBOSS_TRACE_LOG_LEVEL_WRN=y
+CONFIG_ZBOSS_TRACE_BINARY_LOGGING=y
+CONFIG_ZBOSS_TRACE_LOGGER_DEVICE_NAME="UART_1"
I added test code to the app to verify that the correct loglevel setting was being applied and that the filters are working as intended:
extern int zb_trace_check(zb_uint_t level, zb_uint_t mask);
LOG_INF("TRACE: %d: %d %d %d %d %d", g_trace_level,
zb_trace_check(0, 1),
zb_trace_check(1, 1),
zb_trace_check(2, 1),
zb_trace_check(3, 1),
zb_trace_check(4, 1));
zb_trace_check(0, 0x100),
zb_trace_check(1, 0x100),
zb_trace_check(2, 0x100),
zb_trace_check(3, 0x100),
zb_trace_check(4, 0x100));
The output was:
I: TRACE: 2: 1 1 1 0 0
I: TRACE: 2: 0 0 0 0 0
Unfortunately this still generates a massive amount of binary log data on UART1. All of these look to be extremely mundane operations that hardly merit the Warning loglevel:
2022-06-09 16:23:23,115 RAW [de,ad,0e,02,9a,00,3d,07,18,00,77,02,06,00,00,00]
2022-06-09 16:23:23,115 ts=009a m=0x0002 lev=1 zb_buf_begin_func:631 data=[06,00,00,00]
2022-06-09 16:23:23,115 RAW [de,ad,0e,02,9a,00,3e,07,18,00,17,05,06,00,00,00]
2022-06-09 16:23:23,115 ts=009a m=0x0002 lev=1 zb_buf_get_status_func:1303 data=[06,00,00,00]
2022-06-09 16:23:23,115 RAW [de,ad,0e,02,9a,00,3f,07,18,00,1e,05,00,00,00,00]
2022-06-09 16:23:23,115 ts=009a m=0x0002 lev=1 zb_buf_get_status_func:1310 data=[00,00,00,00]
2022-06-09 16:23:23,120 RAW [de,ad,0e,02,9a,00,40,07,18,00,a1,02,06,00,00,00]
2022-06-09 16:23:23,120 ts=009a m=0x0002 lev=1 zb_buf_len_func:673 data=[06,00,00,00]
2022-06-09 16:23:23,120 RAW [de,ad,0e,02,9a,00,41,07,18,00,a1,02,06,00,00,00]
2022-06-09 16:23:23,121 RAW [de,ad,0e,02,9a,00,42,07,18,00,77,02,06,00,00,00]
2022-06-09 16:23:23,121 ts=009a m=0x0002 lev=1 zb_buf_begin_func:631 data=[06,00,00,00]
2022-06-09 16:23:23,121 RAW [de,ad,0e,02,9a,00,43,07,18,00,17,05,06,00,00,00]
2022-06-09 16:23:23,121 ts=009a m=0x0002 lev=1 zb_buf_get_status_func:1303 data=[06,00,00,00]
2022-06-09 16:23:23,136 RAW [de,ad,0e,02,9a,00,44,07,18,00,1e,05,00,00,00,00]
For instance, zb_buf_get_tail_func() is logging at the Error level even when no errors are occurring.
The reason why I worry about this is because I'm trying to capture information about an actual ZBOSS failure, and there is so much data coming out of this UART that it's dropping/corrupting frames.
I see similar issues when using other trace masks too.
