nrf_ble_scan fails to connect to devices that emit both connectable and non-connectable advertising packets
nrf5-sdk v16.0.0
If you use the nrf_ble_scan module to try and connect to a peripheral that emits both connectable and non-connectable advertising packets, the module does not check that the advertising report it receives is "connectable" before trying to initiate a connection.
If the device is currently only emitting non-connectable packets, the scanner tries to connect but will never succeed.
Attempts to stop and start the scan again fail.
sd_ble_nrf_ble_scan_start() (or whatever its called) just returns an invalid_state error until you explicitly call sd_ble_cancel_connect()
Seems like a bug to me, but the nrf_ble_scan module shouldn't attempt a connection to a non-connectable advertising packet in the first place.
Checked the latest v17.1.0 code, looks like the issue would still persist there as well.
    I took a look at the code, and I agree. There is no check to see if ble_gap_adv_report_type_t ::connectable is 0 or 1 before attempting to connect. Either add a timeout(NRF_BLE_SCAN_SCAN_DURATION non 0), or set  automatic connection(connect_if_match) flag to false, and do the connection attempt yourself and the ble_gap_adv_report_type_t ::connectable check, in the scan_evt_handler() when you get the event NRF_BLE_SCAN_EVT_FILTER_MATCH
