Panic, when playing music
Hi
I have build a sample project nRF5430_audio for nRF5340 Auido DK(two DK, one for gateway, one for headset), following the guide:nRF5340 Audio — nRF Connect SDK 2.0.99 documentation (nordicsemi.com)
build the project:
python buildprog.py -c both -b debug -d both -p
add following to prj.conf
CONFIG_SW_CODEC_SBC=y
CONFIG_AUDIO_SOURCE_USB=y
CONFIG_TRANSPORT_CIS=y
after streaming for a while,the headset will panic:
HL [00:08:42.849,517] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
HL [00:08:44.309,600] <wrn> audio_datapath: Invalid sdu_ref_us delta (9983) - Estimating sdu_ref_us
HL [00:08:53.321,838] <wrn> sw_codec_select: PCM samples dropped
HL [00:08:53.321,868] <err> audio_datapath: Decoded audio has wrong size
HL [00:08:53.321,868] <err> audio_datapath: ERR_CHK Err_code: [-140] @ line: 815
HL [00:08:53.321,868] <err> os: r0/a1: 0x00000003 r1/a2: 0x00000003 r2/a3: 0x00000002
HL [00:08:53.321,899] <err> os: r3/a4: 0x20001e10 r12/ip: 0x00000002 r14/lr: 0x00017b85
HL [00:08:53.321,899] <err> os: xpsr: 0x41000000
HL [00:08:53.321,899] <err> os: s[ 0]: 0x00000000 s[ 1]: 0x00000000 s[ 2]: 0x00000000 s[ 3]: 0x00000000
HL [00:08:53.321,899] <err> os: s[ 4]: 0x00000000 s[ 5]: 0x00000000 s[ 6]: 0x00000000 s[ 7]: 0x00000000
HL [00:08:53.321,929] <err> os: s[ 8]: 0x00000000 s[ 9]: 0x00000000 s[10]: 0x00000000 s[11]: 0x00000000
HL [00:08:53.321,929] <err> os: s[12]: 0x00000000 s[13]: 0x00000000 s[14]: 0x00000000 s[15]: 0xffffffff
HL [00:08:53.321,929] <err> os: fpscr: 0x200002f0
HL [00:08:53.321,960] <err> os: Faulting instruction address (r15/pc): 0x0000651c
HL [00:08:53.321,960] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
HL [00:08:53.321,960] <err> os: Current thread: 0x20001688 (AUDIO DATAPATH)
HL [00:08:53.321,960] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
so, i think there is a bug, is any patch for it?
thanks
Parents Reply
  • Great, that is good news! :)
    Then I suppose the dropped frames over that time is nothing to worry about - frames may be dropped unexpectedly from time to time due to RF noise or changes in the physical environment, but as long as it only happens as seldomly as it does in this case it should be no problem at all.
    Thank you for sharing the test results with me nevertheless!
    Please do not hesitate to open another ticket if you should encounter any other issues or questions in the future.
    Good luck with your developing! :)
    Karl
