Running MPU accelerometer example in nRF52840 DK using VS Code.
I am using nRF52840 DK and I run my project using VS Code.
I wanted to run MPU 6050 accelerometer example for my DK. Below are my configuration I had setup for running the example.
Vcc of sensor ----> VDD of nRF52840DK
GND  sensor -----> GND of DK
SCL of sensor ----> P0.27 of DK
SDA of sensor-----> P0.26 of DK
I loaded the MPU6050 example application in VS Code and I created the 'nrf52840dk_nrf52840.overlay' for the board and below is the content for the overlay
// To get started, press Ctrl+Space to bring up the completion menu and view the available nodes.
// For more help, browse the DeviceTree documentation at https://docs.zephyrproject.org/latest/guides/dts/index.html
&i2c0 {
	status = "okay";
	sda-pin = < 27 >;
	scl-pin = < 26 >;
    clock-frequency = <I2C_BITRATE_STANDARD>;
    /* The I2C address could be one of two, here 0x76 is assumed */
	mpu6050@68 {
		compatible = "invensense,mpu6050";
		reg = <0x68>;
		status = "okay";
		label = "MPU6050";
		int-gpios = <&gpio0 11 GPIO_ACTIVE_HIGH>;
&spi0 {
	status = "disabled";
Below given is the code from the example,
 * Copyright (c) 2019 Nordic Semiconductor ASA
#include <zephyr.h>
#include <device.h>
#include <drivers/sensor.h>
#include <stdio.h>
static const char *now_str(void)
	static char buf[16]; /* ...HH:MM:SS.MMM */
	uint32_t now = k_uptime_get_32();
	unsigned int ms = now % MSEC_PER_SEC;
	unsigned int s;
	unsigned int min;
	unsigned int h;
	now /= MSEC_PER_SEC;
	s = now % 60U;
	now /= 60U;
	min = now % 60U;
	now /= 60U;
	h = now;
	snprintf(buf, sizeof(buf), "%u:%02u:%02u.%03u",
		 h, min, s, ms);
	return buf;
static int process_mpu6050(const struct device *dev)
	struct sensor_value temperature;
	struct sensor_value accel[3];
	struct sensor_value gyro[3];
	int rc = sensor_sample_fetch(dev);
	if (rc == 0) {
		rc = sensor_channel_get(dev, SENSOR_CHAN_ACCEL_XYZ,
					accel);
	if (rc == 0) {
		rc = sensor_channel_get(dev, SENSOR_CHAN_GYRO_XYZ,
					gyro);
	if (rc == 0) {
		rc = sensor_channel_get(dev, SENSOR_CHAN_AMBIENT_TEMP,
					&temperature);
	if (rc == 0) {
		printf("[%s]:%g Cel\n"
		       "  accel %f %f %f m/s/s\n"
		       "  gyro  %f %f %f rad/s\n",
		       now_str(),
		       sensor_value_to_double(&temperature),
		       sensor_value_to_double(&accel[0]),
		       sensor_value_to_double(&accel[1]),
		       sensor_value_to_double(&accel[2]),
		       sensor_value_to_double(&gyro[0]),
		       sensor_value_to_double(&gyro[1]),
		       sensor_value_to_double(&gyro[2]));
	} else {
		printf("sample fetch/get failed: %d\n", rc);
	return rc;
#ifdef CONFIG_MPU6050_TRIGGER
static struct sensor_trigger trigger;
static void handle_mpu6050_drdy(const struct device *dev,
				const struct sensor_trigger *trig)
	int rc = process_mpu6050(dev);
	if (rc != 0) {
		printf("cancelling trigger due to failure: %d\n", rc);
		(void)sensor_trigger_set(dev, trig, NULL);
		return;
#endif /* CONFIG_MPU6050_TRIGGER */
void main(void)
	const char *const label = DT_LABEL(DT_INST(0, invensense_mpu6050));
	const struct device *mpu6050 = device_get_binding(label);
	if (!mpu6050) {
		printf("Failed to find sensor %s\n", label);
		return;
	trigger = (struct sensor_trigger) {
		.type = SENSOR_TRIG_DATA_READY,
		.chan = SENSOR_CHAN_ALL,
	if (sensor_trigger_set(mpu6050, &trigger,
			       handle_mpu6050_drdy) < 0) {
		printf("Cannot configure trigger\n");
		return;
	printk("Configured for triggered sampling.\n");
	while (!IS_ENABLED(CONFIG_MPU6050_TRIGGER)) {
		int rc = process_mpu6050(mpu6050);
		if (rc != 0) {
		k_sleep(K_SECONDS(2));
	/* triggered runs with its own thread after exit */
I was able to successfully build and flash the application in my DK, However the sensor was unable to detect it.
Following is the error message from the terminal
"Failed to find sensor MPU6050"
