I'm writing my own UARTE library because I need some functionality not offered in the SDK. But I came across a hardware behaviour I can't explain.
In my understanding, the RXDRDY event is triggered when a byte is fully received in the RX pin (at the stop bit). Then, after the RX FIFO and DMA it will eventually be written to RAM.
My code, similarly to libuarte_async, uses a TIMER to detect when there is no more activity in RX and another TIMER to count the number of RXDRDY events, which should represent the number of bytes physically received at the RX pin.
The problem is, the number of RXDRDY events is sometimes not what I would expect. For instance, consider this trace:
At [1], the RXTO irq handler runs because the DMA transfer is complete. As you can see, 78 bytes were received up to that point. The RXD.AMOUNT register reads 76 and the RXDRDY count is 77. I would expect the RXDRDY count to be 78.
Then, at [2], the RXTO irq handler runs because the reception is stopped due to RX idle. At this point, the RXD.AMOUNT register reads 14 and the RXDRDY count is 13. I would expect the RXDRDY count to be 12.
In short, it looks like the RXDRDY event is not triggered when a byte is received at the RX pin.
Can you please shed some light on this behaviour?
