I am trying to run the sample code for the BME680 sensor over I2C.
I am using the sample code as is; the only modification is my overlay file to define the I2C pins as below.
&i2c0 { compatible = "nordic,nrf-twim"; status = "okay"; sda-pin = <17>; scl-pin = <20>; clock-frequency = <I2C_BITRATE_STANDARD>; bme680@76 { compatible = "bosch,bme680"; reg = <0x76>; label = "BME680"; }; };
when i try to build, I get a whole host of errors......
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/toolchain/gcc.h:62:36: error: static assertion failed: "Devicetree node /soc/i2c@40003000 must have exactly one of the sda-pin and sda-gpios properties set. Note: you can use /delete-property/ to delete properties." 62 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG) | ^~~~~~~~~~~~~~ /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/soc/arm/nordic_nrf/nrf52/../soc_nrf_common.h:85:2: note: in expansion of macro 'BUILD_ASSERT' 85 | BUILD_ASSERT( \ | ^~~~~~~~~~~~ /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/drivers/i2c/i2c_nrfx_twim.c:328:2: note: in expansion of macro 'NRF_DT_PSEL_CHECK_EXACTLY_ONE' 328 | NRF_DT_PSEL_CHECK_EXACTLY_ONE(I2C(idx), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/drivers/i2c/i2c_nrfx_twim.c:371:1: note: in expansion of macro 'I2C_NRFX_TWIM_DEVICE' 371 | I2C_NRFX_TWIM_DEVICE(0); | ^~~~~~~~~~~~~~~~~~~~ /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/toolchain/gcc.h:62:36: error: static assertion failed: "Devicetree node /soc/i2c@40003000 must have exactly one of the scl-pin and scl-gpios properties set. Note: you can use /delete-property/ to delete properties." 62 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG) | ^~~~~~~~~~~~~~ /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/soc/arm/nordic_nrf/nrf52/../soc_nrf_common.h:85:2: note: in expansion of macro 'BUILD_ASSERT' 85 | BUILD_ASSERT( \ | ^~~~~~~~~~~~ /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/drivers/i2c/i2c_nrfx_twim.c:331:2: note: in expansion of macro 'NRF_DT_PSEL_CHECK_EXACTLY_ONE' 331 | NRF_DT_PSEL_CHECK_EXACTLY_ONE(I2C(idx), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/drivers/i2c/i2c_nrfx_twim.c:371:1: note: in expansion of macro 'I2C_NRFX_TWIM_DEVICE' 371 | I2C_NRFX_TWIM_DEVICE(0); | ^~~~~~~~~~~~~~~~~~~~ ninja: build stopped: subcommand failed.
Rod
