I am facing the following issue:
I am using the blinky sample of Zephyr to control the output of a pin. When this pin is any of the LED pins of nrf5340dk, the output is the expected one (voltage is either 0 or 3volts depending on the status of the pin). When I am using any other pin (I tried with some other P0 and P1 pins) the voltage is not changing as expected.
I even used the voltage flags (3P3 and 5P3) and changed the ACTIVE state of the pin, but nothing worked. I also checked that the gpio_pin_set function was returning 0 (successful).
Could you please help with this?
