nRF52811 on u-blox BMD-360 module: Failed to load readback protection status: async task failure for id: 4040685450 msg: JLINKARM_DLL_ERROR
Our project is based on the "ble_app_template" example with added BLE custom profile.
We have been developing our software on the u-blox "BMD-300 evaluation board 320-00050" without any major issue on the debugging/programming side. We have now our PCB manufactured with some brand new BMD-360 modules soldered on them and now we have some readback protection issues with the exact same code that didn't show any problem on the u-blox EVK, which is supposed to have the exact same module.
The u-blox EVK has its own programmer/debugger which doesn't have an easy debugger output so I use the J-Link debugger from the nRF52840-DK (PCA10056 2.0.1 2020.43 683503066) I have. Connection is done through the P20 connector (the 0.1in/2.54mm one) with VTG connected to VDD_nRF and GND connected to GND_DETECT.
The is what I was able to do so far:
  • Program the S112 softdevice with nRF Programmer v2.3.3 utility
  • Read the flash to make sure the softdevice has been programmed correctly
  • Program the application code with Keil µVision
Now the chip is supposed to run but it doesn't: BLE is not advertising and UART debug is not printing anything. Please note that I flashed the exact same .hex file without recompiling on the u-blox EVK and the code is running just fine.
This is what I can do then:
  • To have the debugger working and recognizing the MCU I often need to disconnected and re-connect the USB cable several times. Sometimes to get it to work I must connect the nRF52840-DK debugger and then connect the target nRF52811 TAG-CONNECT cable to have it recognized by Keil
  • Launch "nrfjprog --recover" to erase the uicr register but this also erases the flash code, leaving me with a chip I must re-program
  • Keil sometimes prompts me that the chip is secured and I need to un-secure it to proceed. If I answer YES, it erases the whole flash as wel as the UICR
Would it be possible that I have a different hardware version of the nRF52811, other than the one that is on the u-blox EVK ?
What could I do to sort this issue out ?
Even if this readback protection is enabled, why would that prevent the application programmed on the MCU from starting correctly ?
Thanks in advance for your help.
Best regards
