I want to use the external flash memory MX25R6435F to run my code which has a big size on my arduino nano 33 ble but I'am a newbie and I don't find supports that can help me,
Is that possible and should I add some configuration ?
I don't see any external memory ICs on in the schematics: https://docs.rs-online.com/9208/A700000006519068.pdf. Have you connected it via the pin headers?
Vidar
Yes I want to use the pin headers to use the external flash memory MX25R6435F
If you have already connected the flash IC to your board, then the next step I would suggest is to try the JEDEC SPI-NOR Sample to verify if you are able to interface with the chip (if the connections are good, etc).
Below is a devicetree overlay you can use to add support for the macronix flash (can be placed in /spi_flash/boards along with the other board specific config/overlay files).
And config file to enable the QSPI driver:
Thank you for your answer, but I want to use "nRF5" vs code or Segger without zephyr, is that possible?
Yes, you can try the QSPI Example from nRF5 SDK 17.1.0 instead then.
