nRF Connect SDK support on segger Embedded studio
I installed nRF Connect SDK V2.0.0 using "NRF connect for Desktop"
Now I can't open nRF Connect SDK projects on segger embedded studio.
It showing only VS Code.
In DEVZONE recently I saw this (LINK) . here it mentioned like "Segger Embedded Studio is not supported for nRF Connect SDK anymore"
 It's real?
I don't want to change the IDE. anything need to change to use nRF Connect SDK on Segger embedded studio.
Best Regards
Bose
    It is true that the nRF Connect SDK v2.0.0 does not support the SEGGER IDE anymore, but you should be able to build with the SEGGER IDE using previous versions of the SDK, like v1.9.1, v1.9.0 and previous versions.
    But at present many are facing troubles doing this due to a bug and the only workaround at the moment is to uninstall SDK v2.0.0. A fix for this will be released in the future versions and you should be able to work with SES using any version before the v2.0.0.
    Priyanka
  • Thank you Priyanka for quick clarification.
