Connection terminated by remote user, why?
Dear All
I tried to connect to an apple device, it is successful but soon after that, it is disconnected with reason code 0x13 - terminated by remote user, I tried to change the connection parameters to its preference, and disconnection still happens . Here is the log file using nrf connection desktop as suggested by the post here connection parameters ,  sorry I accidently closed the ticket, so have to open a new discussion here. The MAC address of the device is AC233F8153CE, the connection/disconnection happens at the end of logs. Can someone have a look at it and let me know the reason please?
Thank you.
Ping
2022-06-14T11_22_34.031Z-log.txt
  • Probably easiest is to use e.g. nRF Connect Desktop BLE app, or nRF Connect for mobile app, connect to the device, and check out the services and UUIDs.
  • I am developing a central app - a generic one applies to all peripherals hopefully, so need to figure out what other centrals do in terms of findings all services and UUIDs - there must be a procedure/way for these centrals like nRF Connect to follow to find all services available from any peripheral without knowing its protocols already - am I right?
    Regards!
    Ping
  • You can use the bt_gatt_discover() API for that. From: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.1/zephyr/reference/bluetooth/gatt.html#generic-attribute-profile-gatt
    "Discover procedures can be initiated with the use of bt_gatt_discover() API which takes the bt_gatt_discover_params struct which describes the type of discovery. The parameters also serves as a filter when setting the uuid field only attributes which matches will be discovered, in contrast setting it to NULL allows all attributes to be discovered."
  • Hello, Sigurd
    Thank you for reply.
    I started from central BAS example, and call the following to do discovery.
    err = bt_gatt_dm_start(conn, BT_UUID_BAS, &discovery_cb, NULL);  //or NULL
    when I pass BT_UUID_BAS as uuid, the service it found is printed as below:
    The discovery procedure succeeded
    ATT[1]:     UUID: 0x2803    Handle: 0x0011    Value:
        Characteristic: 0x2a19    Properties: 0x0012
    ATT[2]:     UUID: 0x2a19    Handle: 0x0012    Value:
    ATT[3]:     UUID: 0x2902    Handle: 0x0013    Value:
        CCCD
    while when I pass NULL as uuid, following attributes are found - it is the mandatory Generic Attribute(0x1801) of the peripheral rather than BT_UUID_BAS.
    ATT[1]:     UUID: 0x2803    Handle: 0x0002    Value:
        Characteristic: 0x2a05    Properties: 0x0020
    ATT[2]:     UUID: 0x2a05    Handle: 0x0003    Value:
    ATT[3]:     UUID: 0x2902    Handle: 0x0004    Value:
        CCCD
    ATT[4]:     UUID: 0x2803    Handle: 0x0005    Value:
        Characteristic: 0x2b29    Properties: 0x000A
    ATT[5]:     UUID: 0x2b29    Handle: 0x0006    Value:
    ATT[6]:     UUID: 0x2803    Handle: 0x0007    Value:
        Characteristic: 0x2b2a    Properties: 0x0002
    ATT[7]:     UUID: 0x2b2a    Handle: 0x0008    Value:
    They are for same peripheral - the Nordic mouse one. I expect it to find all services include BT_UUID_BAS(0x180F) and another one 0x1812, and more. But it doesn't.
    Could you explain what I have done wrong please? how can I find all without knowing the UUID in advance please?
    Regards!
    Ping
  • Just noticed you suggest to call bt_gatt_discover() function , while in my example, I call bt_gatt_discover_start() function. The later pass more parameters down and allow calling a callback function afterwards.
    But what is the difference fundamentally? which one I should use ? do I need to call bt_gatt_discover_continue()?
    Regards!
    Ping
