Hi devzone,
I've had UART communication problems between nRF52 and a BG96 modem for a long time.
today I added a pull down resistance on the rx of the nRF52 and it works well but when I visualize the RX buffer the data is incorrect,
not yet are Ok #include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf_libuarte_async.h"
#include "nrf_drv_clock.h"
#include <bsp.h>
#include "nrf_log_ctrl.h"
#include "nrf_queue.h"
#include "nrf_delay.h"
#include "app_error.h"
#define MODEM_PWR_EN_GPIO_PORT (NRF_GPIO_PIN_MAP(1,4))
#define GPIO_PIN_RESET (0)
#define GPIO_PIN_SET (1)
#define SIZE_BUFFER_RX (512)
#define BG96_BOOT_TIME (5500U)
#define RX_SIZE (255)
unsigned char buffer_rx[SIZE_BUFFER_RX];
uint32_t numbre_data_received = 0;
char CMD_AT[] = "AT\r\n";
char CMD_ATI[] = "ATI\r\n";
char CMD_GNS[] = "AT+GSN\r\n";
char CMD_CSQ[] = "AT+CSQ\r\n";
char CMD_CMGF[] = "AT+CMGF=1\r\n";
char CMD_IPR[] = "AT+IPR=115200";
char CMD_STOR_CURRENT_SETTING_BDR[] = "AT&W\r\n";
char BAUD_RATE[] = "AT+IPR?\r\n";
typedef struct {
uint8_t * const queue; // constant pointer to normal data - pointer can't be changed once initialized
uint32_t tail;
uint32_t length;
const uint32_t maxsize; // constant maxsize - can't be changed once initialized
} ringbuf_u8_t;
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, RX_SIZE, 3);
static volatile bool m_resp_bg96_ok = false;
void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
//printf("Received a fault! id: 0x%08x, pc: 0x%08x, info: 0x%08x", id, pc, info);
bsp_board_leds_off();
for (;;)
nrf_delay_ms(200);
bsp_board_led_invert(0);
bsp_board_led_invert(1);
* @brief Function used to wakeup the MODEM
void sys_ctrl_bg96_power_on(void)
/* Reference: Quectel BG96 Hardware Design V1.4
* PWRKEY connected to MODEM_PWR_EN (inverse pulse)
* RESET_N connected to MODEM_RST (inverse)
* Turn ON module sequence
* PWRKEY PWR_EN modem_state
* init 0 1 OFF
* T=0 ms 1 0 OFF
* T1=30 ms 0 1 BOOTING
* T2=T1+500 ms 1 0 BOOTING
* T3=T1+4800 ms 1 0 RUNNING
/* First, turn OFF module in case it was not switched off correctly (can occur after
* a manual reset).
* Set PWR_EN to 0 at least 650ms
nrf_gpio_cfg_output(MODEM_PWR_EN_GPIO_PORT);
nrf_gpio_pin_write(MODEM_PWR_EN_GPIO_PORT, GPIO_PIN_SET);
nrf_delay_ms(700U);
nrf_gpio_pin_write(MODEM_PWR_EN_GPIO_PORT, GPIO_PIN_RESET);
nrf_delay_ms(1000U);
/* Power ON sequence */
/* Set PWR_EN to 1 (initial state) */
nrf_delay_ms(50U);
/* Set PWR_EN to 0 during at least 30ms as defined by Quectel */
nrf_delay_ms(30U);
/* Set PWR_EN to 1 during at least 500ms */
nrf_delay_ms(510U);
/* Set PWR_EN to 0 */
/* wait for Modem to complete its booting procedure */
/*"Waiting %d millisec for modem running...", BG96_BOOT_TIME)*/
nrf_delay_ms(BG96_BOOT_TIME);
/* ... done */
void send_command(char cmd[], uint16_t size)
ret_code_t err_code;
do {
err_code = nrf_libuarte_async_tx(&libuarte, cmd, size);
while (err_code == NRF_ERROR_BUSY);
nrf_delay_ms(400);
void uart_event_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
ret_code_t ret;
switch (p_evt->type)
case NRF_LIBUARTE_ASYNC_EVT_ERROR:
case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
if((unsigned char)*(p_evt->data.rxtx.p_data) != 0)
buffer_rx[numbre_data_received]=(unsigned char)*(p_evt->data.rxtx.p_data);
numbre_data_received++;
if( (buffer_rx[numbre_data_received - 2] == 0x0D) && ( buffer_rx[numbre_data_received - 1] == 0x0A))
char * find_BG96 = strstr((const char *)buffer_rx, (const char *)"BG96");
if( find_BG96 == NULL)
while(1)
bsp_board_led_invert(2);
nrf_delay_ms(500);
m_resp_bg96_ok = true;
if( numbre_data_received >= SIZE_BUFFER_RX )
memset(buffer_rx, 0, numbre_data_received);
printf("buffer_rx : %s\n",buffer_rx);
nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
bsp_board_led_invert(3);
sys_ctrl_bg96_power_on();
ret_code_t ret = nrf_drv_clock_init();
APP_ERROR_CHECK(ret);
ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
nrf_libuarte_async_config_t nrf_libuarte_async_config = {
.tx_pin = NRF_GPIO_PIN_MAP(1,2), //TX_PIN_NUMBER,
.rx_pin = NRF_GPIO_PIN_MAP(1,3), //RX_PIN_NUMBER,
.baudrate = NRF_UARTE_BAUDRATE_115200,
.parity = NRF_UARTE_PARITY_EXCLUDED,
.hwfc = NRF_UARTE_HWFC_DISABLED,
.timeout_us = 300, //200
.int_prio = APP_IRQ_PRIORITY_HIGH //APP_IRQ_PRIORITY_HIGH
err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
nrf_libuarte_async_enable(&libuarte);
nrf_delay_ms(1000); //1000
while(m_resp_bg96_ok != true)
send_command(CMD_ATI, strlen(CMD_ATI));
//send_command(CMD_IPR, sizeof(CMD_IPR));
//send_command(CMD_STOR_CURRENT_SETTING_BDR, sizeof(CMD_STOR_CURRENT_SETTING_BDR));
//send_command(BAUD_RATE, sizeof(BAUD_RATE));
while(true)
nrf_delay_ms(500);
on the logic analyzer and Ok in the sniffer UART with serial emulator port "tera term".
could you help me please, I've been stuck on this project for a long time .
Thank you .
Lora
