When using the distance measurement function newly added to the reference point by THE GNSS routine of NCS V2.0.0, it is found that each measurement has a deviation of 30 ~ 60m. What is the cause of the deviation and how to solve it
A deviation is to be expected, especially if the dilution of precision is high in the initial fix.
You can calculate the GDOP (by squaring tdop+pdop) as described here:
https://en.wikipedia.org/wiki/Dilution_of_precision_(navigation)
Here's the *dop members in the pvt frame:
And then add a limit for your wanted total DOP in your own application.
Easier alternative: You can let the GNSS run for a longer time period after getting a fix, by for instance filtering on the .accuracy field:
PS: also make sure you're not in low accuracy mode: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.0.0/nrfxlib/nrf_modem/doc/gnss_interface.html#low-accuracy-mode
Håkon
Is the range of deviations reasonable
If you are only tracking the bare minimum amount of satellites to obtain a fix, then yes.
Håkon
No problem, happy to help!
Håkon
