Help with basic implementation of UART
I am working on developing a BLE peripheral FW (Reader) with NRF52840 using nRF Connect SDK 2.0.0. The Reader has two MCU, one is BLE MCU and other is the main Control MCU.
I have implemented my custom BLE service in the BLE FW.
Some data that i received from BLE Client i have to send to Main MCU using UART and also Some data that i receive on UART from Control MCU i have to send to BLE Client probably.
Which is the easiest method to achieve this from a sample ?
I have read the peripheral_uart example, but that seems to be more complex than what i need. It implements every data on UART to BLE Client.
Also, i am not much clear the steps to configure, init and use UART functions.
I am reading through samples and responses from devzone since 2 days, but havent got a good understanding on how to start yet.
Please help.
  • Hello .. any help ? I need to get this to work asap.
    I have reference from peripheral_lpuart example and use it in my project as :
    LOG_MODULE_REGISTER(uart);
    const struct device *lpuart = DEVICE_DT_GET(DT_NODELABEL(lpuart));
    int uart_init(void)
    	if (!device_is_ready(lpuart))
    		printk("LPUART device not ready\n");
    		return -ENODEV;
    	uart_irq_callback_user_data_set(lpuart, uart_irq_handler, NULL);
    	uart_irq_rx_enable(lpuart);
    	while (1)
    		uart_irq_tx_enable(lpuart);
    		k_sleep(K_MSEC(500));
    		uart_poll_out(lpuart, 0xff);
    		k_sleep(K_MSEC(100));
    static void uart_irq_handler(const struct device *dev, void *context)
    	uint8_t buf[] = {1, 2, 3, 4, 5};
    	if (uart_irq_tx_ready(dev))
    		(void)uart_fifo_fill(dev, buf, sizeof(buf));
    		uart_irq_tx_disable(dev);
    	if (uart_irq_rx_ready(dev))
    		uint8_t buf[10];
    		int len = uart_fifo_read(dev, buf, sizeof(buf));
    		if (len)
    			printk("read %d bytes\n", len);
    I am not able to understand how do i use it ? Can you explain .. the flow of these UART API and Tx and Rx. What triggers what ?
    I have used interrupt based uart.
    I have my high level Application functions: Datalnit, SendData and ReceiveData in nRF52840 code to be used for UART.
    uart_init i am calling inside DataInit.
    What shall i write inside SendData and ReceiveData from uart code i posted.
    Thanks.
  • Hello Deep,
    Unfortunately I will have to get back to you on this next week.
    Though note that we have several examples on UART ( Low power uart, peripheral uart, and central uart), as well as a section on UART in our DevAcademy.
    Elfving
  • Hello again Deep, I hope you've had a nice weekend.
    When it comes to what to start with you could for instance base your BLE MCU on the central_uart sample. To get an understanding of the sample and UART API I would generally recommend the DevAcademy and the sample documentation, though you can of course ask here as well.
    Have you gotten any further since last week?
    Elfving
