Scan in a Single Channel
As mentioned in this post: devzone.nordicsemi.com/.../
the struct ble_gap_adv_params_t --> ble_gap_adv_ch_mask_t give the option to turn any advertising channel OFF. I tested this approach and could advertise on only one channel.
The problem that I found was in scanning for this packet. When I'm using 3 channels for advertising, the scanning program is ALWAYS able to pick the advertising packet. But when I'm using 1 channel for advertising it misses some. Is there any way to program the scanning so that it only looks on a single channel? Can this problem be due to values of scan interval and scan window (I'm setting them equal to continuously scan)?
In the description of ble_gap_adv_ch_mask_t (infocenter.nordicsemi.com/index.jsp it says "Channel mask for RF channels used in advertising and scanning". But I could only found a place in the ble_gap_adv_params_t to pass it, and ble_gap_scan_params_t doesn't have this field.
So how can we set this feature for scan mode?
Parents Reply
  • I included the handler you posted. Off course there was no sys_evt_dispatch() in the Observer example, and I added it similar to the Timeslot Tutorial (devzone.nordicsemi.com/.../) with also the pstorage_sys_event_handler(sys_evt). Right now it works with S110 SDK 9 and the softdevice_handler.c included, but still not with S130. If it helps, the errors and warnings that I had to correct after using SDK 9 were all in nrf_adv_conn.c: 1- sd_ble_gatts_sys_attr_set and sd_ble_gap_sec_params_reply: missing 1 argument (passed NULL). 2- Used BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED for ble_adv_data.flags. 3- ble_gap_bond_params: one additional assignment.
