problem in checking logs and led status in nrf5340 custom board
hi, i am using a cutom board based on nrf5340 mcu , so, while setting it up i am facing the problem in checking logs and led status.
i am uisng the nrf5340dk board to build and flash the code using jlink in our cutom board of nrf5340,
so, when i am using a simple code blinky given in samples and did changes to see logs and led status on our custom board, it's providing desired results.
but,
when i am using code of zigbee light bulb or switch , which is given in the examples of sdk , and did changes according to see logs and led status, it builds and flashed in the custom board but niether led blinking nor any logs shown on rtt viewer.
so, i m not getting clue why is this happening , attaching both code below.
 * @brief Simple Zigbee light bulb implementation.
#include <zephyr/types.h>
#include <zephyr.h>
#include <device.h>
#include <soc.h>
#include <drivers/pwm.h>
#include <logging/log.h>
#include <dk_buttons_and_leds.h>
#include <settings/settings.h>
#include <devicetree.h>
#include <drivers/gpio.h>
#include "SEGGER_RTT.h"
#include <zboss_api.h>
#include <zboss_api_addons.h>
#include <zb_mem_config_med.h>
#include <zigbee/zigbee_app_utils.h>
#include <zigbee/zigbee_error_handler.h>
#include <zigbee/zigbee_zcl_scenes.h>
#include <zb_nrf_platform.h>
#define RUN_STATUS_LED                  DK_LED1
#define RUN_LED_BLINK_INTERVAL          1000
/* Device endpoint, used to receive light controlling commands. */
#define HA_DIMMABLE_LIGHT_ENDPOINT      10
/* Version of the application software (1 byte). */
#define BULB_INIT_BASIC_APP_VERSION     01
/* Version of the implementation of the Zigbee stack (1 byte). */
#define BULB_INIT_BASIC_STACK_VERSION   10
/* Version of the hardware of the device (1 byte). */
#define BULB_INIT_BASIC_HW_VERSION      11
/* Manufacturer name (32 bytes). */
#define BULB_INIT_BASIC_MANUF_NAME      "Nordic"
/* Model number assigned by manufacturer (32-bytes long string). */
#define BULB_INIT_BASIC_MODEL_ID        "Dimable_Light_v0.1"
/* First 8 bytes specify the date of manufacturer of the device
 * in ISO 8601 format (YYYYMMDD). The rest (8 bytes) are manufacturer specific.
#define BULB_INIT_BASIC_DATE_CODE       "20200329"
/* Type of power sources available for the device.
 * For possible values see section 3.2.2.2.8 of ZCL specification.
#define BULB_INIT_BASIC_POWER_SOURCE    ZB_ZCL_BASIC_POWER_SOURCE_DC_SOURCE
/* Describes the physical location of the device (16 bytes).
 * May be modified during commisioning process.
#define BULB_INIT_BASIC_LOCATION_DESC   "Office desk"
/* Describes the type of physical environment.
 * For possible values see section 3.2.2.2.10 of ZCL specification.
#define BULB_INIT_BASIC_PH_ENV          ZB_ZCL_BASIC_ENV_UNSPECIFIED
/* LED indicating that light switch successfully joind Zigbee network. */
#define ZIGBEE_NETWORK_STATE_LED        DK_LED3
/* LED immitaing dimmable light bulb - define for informational
 * purposes only.
#define BULB_LED                        DK_LED4
/* Button used to enter the Bulb into the Identify mode. */
#define IDENTIFY_MODE_BUTTON            DK_BTN4_MSK
/* Use onboard led4 to act as a light bulb.
 * The app.overlay file has this at node label "pwm_led3" in /pwmleds.
#define PWM_DK_LED4_NODE                DT_NODELABEL(pwm_led3)
/* Nordic PWM nodes don't have flags cells in their specifiers, so
 * this is just future-proofing.
#define FLAGS_OR_ZERO(node) \
	COND_CODE_1(DT_PHA_HAS_CELL(node, pwms, flags), \
		    (DT_PWMS_FLAGS(node)), (0))
#if DT_NODE_HAS_STATUS(PWM_DK_LED4_NODE, okay)
/* Get the defines from overlay file. */
#define PWM_DK_LED4_CTLR                DT_PWMS_CTLR(PWM_DK_LED4_NODE)
#define PWM_DK_LED4_CHANNEL             DT_PWMS_CHANNEL(PWM_DK_LED4_NODE)
#define PWM_DK_LED4_FLAGS               FLAGS_OR_ZERO(PWM_DK_LED4_NODE)
#else
#error "Choose supported PWM driver"
/* Led PWM period, calculated for 50 Hz signal - in microseconds. */
#define LED_PWM_PERIOD_US               (USEC_PER_SEC / 50U)
#ifndef ZB_ROUTER_ROLE
#error Define ZB_ROUTER_ROLE to compile router source code.
//------------------cutom board led definition------
const struct device *dev0;
LOG_MODULE_REGISTER(app, LOG_LEVEL_INF);
/* Main application customizable context.
 * Stores all settings and static values.
typedef struct {
	zb_zcl_basic_attrs_ext_t         basic_attr;
	zb_zcl_identify_attrs_t          identify_attr;
	zb_zcl_scenes_attrs_t            scenes_attr;
	zb_zcl_groups_attrs_t            groups_attr;
	zb_zcl_on_off_attrs_t            on_off_attr;
	zb_zcl_level_control_attrs_t     level_control_attr;
} bulb_device_ctx_t;
/* Zigbee device application context storage. */
static bulb_device_ctx_t dev_ctx;
/* Pointer to PWM device controlling leds with pwm signal. */
static const struct device *led_pwm_dev;
ZB_ZCL_DECLARE_IDENTIFY_ATTRIB_LIST(
	identify_attr_list,
	&dev_ctx.identify_attr.identify_time);
ZB_ZCL_DECLARE_GROUPS_ATTRIB_LIST(
	groups_attr_list,
	&dev_ctx.groups_attr.name_support);
ZB_ZCL_DECLARE_SCENES_ATTRIB_LIST(
	scenes_attr_list,
	&dev_ctx.scenes_attr.scene_count,
	&dev_ctx.scenes_attr.current_scene,
	&dev_ctx.scenes_attr.current_group,
	&dev_ctx.scenes_attr.scene_valid,
	&dev_ctx.scenes_attr.name_support);
ZB_ZCL_DECLARE_BASIC_ATTRIB_LIST_EXT(
	basic_attr_list,
	&dev_ctx.basic_attr.zcl_version,
	&dev_ctx.basic_attr.app_version,
	&dev_ctx.basic_attr.stack_version,
	&dev_ctx.basic_attr.hw_version,
	dev_ctx.basic_attr.mf_name,
	dev_ctx.basic_attr.model_id,
	dev_ctx.basic_attr.date_code,
	&dev_ctx.basic_attr.power_source,
	dev_ctx.basic_attr.location_id,
	&dev_ctx.basic_attr.ph_env,
	dev_ctx.basic_attr.sw_ver);
/* On/Off cluster attributes additions data */
ZB_ZCL_DECLARE_ON_OFF_ATTRIB_LIST(
	on_off_attr_list,
	&dev_ctx.on_off_attr.on_off);
ZB_ZCL_DECLARE_LEVEL_CONTROL_ATTRIB_LIST(
	level_control_attr_list,
	&dev_ctx.level_control_attr.current_level,
	&dev_ctx.level_control_attr.remaining_time);
ZB_HA_DECLARE_DIMMABLE_LIGHT_CLUSTER_LIST(
	dimmable_light_clusters,
	basic_attr_list,
	identify_attr_list,
	groups_attr_list,
	scenes_attr_list,
	on_off_attr_list,
	level_control_attr_list);
ZB_HA_DECLARE_DIMMABLE_LIGHT_EP(
	dimmable_light_ep,
	HA_DIMMABLE_LIGHT_ENDPOINT,
	dimmable_light_clusters);
ZB_HA_DECLARE_DIMMABLE_LIGHT_CTX(
	dimmable_light_ctx,
	dimmable_light_ep);
/**@brief Callback for button events.
 * @param[in]   button_state  Bitmask containing buttons state.
 * @param[in]   has_changed   Bitmask containing buttons
 *                            that have changed their state.
static void button_changed(uint32_t button_state, uint32_t has_changed)
	zb_ret_t zb_err_code;
	/* Calculate bitmask of buttons that are pressed
	 * and have changed their state.
	uint32_t buttons = button_state & has_changed;
	if (buttons & IDENTIFY_MODE_BUTTON) {
		/* Check if endpoint is in identifying mode,
		 * if not put desired endpoint in identifying mode.
		if (dev_ctx.identify_attr.identify_time ==
		    ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE) {
			LOG_INF("Bulb put in identifying mode");
			zb_err_code = zb_bdb_finding_binding_target(
				HA_DIMMABLE_LIGHT_ENDPOINT);
			ZB_ERROR_CHECK(zb_err_code);
		} else {
			LOG_INF("Cancel F&B target procedure");
			zb_bdb_finding_binding_target_cancel();
/**@brief Function for initializing additional PWM leds. */
static void pwm_led_init(void)
	led_pwm_dev = DEVICE_DT_GET(PWM_DK_LED4_CTLR);
	if (!device_is_ready(led_pwm_dev)) {
		LOG_ERR("Error: PWM device %s is not ready",
			led_pwm_dev->name);
/**@brief Function for initializing LEDs and Buttons. */
static void configure_gpio(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		LOG_ERR("Cannot init buttons (err: %d)", err);
	err = dk_leds_init();
	if (err) {
		LOG_ERR("Cannot init LEDs (err: %d)", err);
	pwm_led_init();
/**@brief Sets brightness of bulb luminous executive element
 * @param[in] brightness_level Brightness level, allowed values 0 ... 255,
 *                             0 - turn off, 255 - full brightness.
static void light_bulb_set_brightness(zb_uint8_t brightness_level)
	uint32_t pulse = brightness_level * LED_PWM_PERIOD_US / 255U;
	if (pwm_pin_set_usec(led_pwm_dev, PWM_DK_LED4_CHANNEL,
			     LED_PWM_PERIOD_US, pulse, PWM_DK_LED4_FLAGS)) {
		LOG_ERR("Pwm led 4 set fails:\n");
		return;
/**@brief Function for setting the light bulb brightness.
 * @param[in] new_level   Light bulb brightness value.
static void level_control_set_value(zb_uint16_t new_level)
	LOG_INF("Set level value: %i", new_level);
	ZB_ZCL_SET_ATTRIBUTE(
		ZB_ZCL_CLUSTER_ID_LEVEL_CONTROL,
		ZB_ZCL_CLUSTER_SERVER_ROLE,
		ZB_ZCL_ATTR_LEVEL_CONTROL_CURRENT_LEVEL_ID,
		(zb_uint8_t *)&new_level,
		ZB_FALSE);
	/* According to the table 7.3 of Home Automation Profile Specification
	 * v 1.2 rev 29, chapter 7.1.3.
	if (new_level == 0) {
		zb_uint8_t value = ZB_FALSE;
			ZB_ZCL_CLUSTER_ID_ON_OFF,
			ZB_ZCL_ATTR_ON_OFF_ON_OFF_ID,
			&value,
			ZB_FALSE);
	} else {
		zb_uint8_t value = ZB_TRUE;
			&value,
			ZB_FALSE);
	light_bulb_set_brightness(new_level);
/**@brief Function for turning ON/OFF the light bulb.
 * @param[in]   on   Boolean light bulb state.
static void on_off_set_value(zb_bool_t on)
	LOG_INF("Set ON/OFF value: %i", on);
		(zb_uint8_t *)&on,
		ZB_FALSE);
	if (on) {
			dev_ctx.level_control_attr.current_level);
	} else {
		light_bulb_set_brightness(0U);
/**@brief Function for initializing all clusters attributes.
static void bulb_clusters_attr_init(void)
	/* Basic cluster attributes data */
	dev_ctx.basic_attr.zcl_version   = ZB_ZCL_VERSION;
	dev_ctx.basic_attr.app_version   = BULB_INIT_BASIC_APP_VERSION;
	dev_ctx.basic_attr.stack_version = BULB_INIT_BASIC_STACK_VERSION;
	dev_ctx.basic_attr.hw_version    = BULB_INIT_BASIC_HW_VERSION;
	/* Use ZB_ZCL_SET_STRING_VAL to set strings, because the first byte
	 * should contain string length without trailing zero.
	 * For example "test" string wil be encoded as:
	 *   [(0x4), 't', 'e', 's', 't']
	ZB_ZCL_SET_STRING_VAL(
		BULB_INIT_BASIC_MANUF_NAME,
		ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_MANUF_NAME));
		BULB_INIT_BASIC_MODEL_ID,
		ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_MODEL_ID));
		BULB_INIT_BASIC_DATE_CODE,
		ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_DATE_CODE));
	dev_ctx.basic_attr.power_source = BULB_INIT_BASIC_POWER_SOURCE;
		BULB_INIT_BASIC_LOCATION_DESC,
		ZB_ZCL_STRING_CONST_SIZE(BULB_INIT_BASIC_LOCATION_DESC));
	dev_ctx.basic_attr.ph_env = BULB_INIT_BASIC_PH_ENV;
	/* Identify cluster attributes data. */
		ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE;
	/* On/Off cluster attributes data. */
	dev_ctx.on_off_attr.on_off = (zb_bool_t)ZB_ZCL_ON_OFF_IS_ON;
	dev_ctx.level_control_attr.current_level =
		ZB_ZCL_LEVEL_CONTROL_LEVEL_MAX_VALUE;
	dev_ctx.level_control_attr.remaining_time =
		ZB_ZCL_LEVEL_CONTROL_REMAINING_TIME_DEFAULT_VALUE;
		(zb_uint8_t *)&dev_ctx.on_off_attr.on_off,
		ZB_FALSE);
		(zb_uint8_t *)&dev_ctx.level_control_attr.current_level,
		ZB_FALSE);
/**@brief Callback function for handling ZCL commands.
 * @param[in]   bufid   Reference to Zigbee stack buffer
 *                      used to pass received data.
static void zcl_device_cb(zb_bufid_t bufid)
	zb_uint8_t cluster_id;
	zb_uint8_t attr_id;
	zb_zcl_device_callback_param_t  *device_cb_param =
		ZB_BUF_GET_PARAM(bufid, zb_zcl_device_callback_param_t);
	LOG_INF("%s id %hd", __func__, device_cb_param->device_cb_id);
	/* Set default response value. */
	device_cb_param->status = RET_OK;
	switch (device_cb_param->device_cb_id) {
	case ZB_ZCL_LEVEL_CONTROL_SET_VALUE_CB_ID:
		LOG_INF("Level control setting to %d",
			device_cb_param->cb_param.level_control_set_value_param
				.new_value);
				.new_value);
	case ZB_ZCL_SET_ATTR_VALUE_CB_ID:
		cluster_id = device_cb_param->cb_param.
			     set_attr_value_param.cluster_id;
		attr_id = device_cb_param->cb_param.
			  set_attr_value_param.attr_id;
		if (cluster_id == ZB_ZCL_CLUSTER_ID_ON_OFF) {
			uint8_t value =
				device_cb_param->cb_param.set_attr_value_param
				.values.data8;
			LOG_INF("on/off attribute setting to %hd", value);
			if (attr_id == ZB_ZCL_ATTR_ON_OFF_ON_OFF_ID) {
				on_off_set_value((zb_bool_t)value);
		} else if (cluster_id == ZB_ZCL_CLUSTER_ID_LEVEL_CONTROL) {
			uint16_t value = device_cb_param->cb_param.
				      set_attr_value_param.values.data16;
			LOG_INF("level control attribute setting to %hd",
				value);
			if (attr_id ==
			    ZB_ZCL_ATTR_LEVEL_CONTROL_CURRENT_LEVEL_ID) {
				level_control_set_value(value);
		} else {
			/* Other clusters can be processed here */
			LOG_INF("Unhandled cluster attribute id: %d",
				cluster_id);
		if (zcl_scenes_cb(bufid) == ZB_FALSE) {
			device_cb_param->status = RET_ERROR;
	LOG_INF("%s status: %hd", __func__, device_cb_param->status);
/**@brief Zigbee stack event handler.
 * @param[in]   bufid   Reference to the Zigbee stack buffer
 *                      used to pass signal.
void zboss_signal_handler(zb_bufid_t bufid)
	/* Update network status LED. */
	zigbee_led_status_update(bufid, ZIGBEE_NETWORK_STATE_LED);
	/* No application-specific behavior is required.
	 * Call default signal handler.
	ZB_ERROR_CHECK(zigbee_default_signal_handler(bufid));
	/* All callbacks should either reuse or free passed buffers.
	 * If bufid == 0, the buffer is invalid (not passed).
	if (bufid) {
		zb_buf_free(bufid);
void main(void)
//-------------------------custom board-----------
        dev0= device_get_binding("GPIO_1");
        gpio_pin_configure(dev0,11,GPIO_OUTPUT);
	int blink_status = 0;
	int err;
	LOG_INF("Starting ZBOSS Light Bulb example");
	/* Initialize */
	configure_gpio();
	err = settings_subsys_init();
	if (err) {
		LOG_ERR("settings initialization failed");
	/* Register callback for handling ZCL commands. */
	ZB_ZCL_REGISTER_DEVICE_CB(zcl_device_cb);
	/* Register dimmer switch device context (endpoints). */
	ZB_AF_REGISTER_DEVICE_CTX(&dimmable_light_ctx);
	bulb_clusters_attr_init();
	level_control_set_value(dev_ctx.level_control_attr.current_level);
	/* Initialize ZCL scene table */
	zcl_scenes_init();
	/* Settings should be loaded after zcl_scenes_init */
	err = settings_load();
	if (err) {
		LOG_ERR("settings loading failed");
	/* Start Zigbee default thread */
	zigbee_enable();
	LOG_INF("ZBOSS Light Bulb example started");
	while (1) {
		//dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
                  SEGGER_RTT_WriteString(0, "Hello World!\n");
                  gpio_pin_set_raw(dev0,11,0);
		  k_msleep(1000);
                  //k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
 * Blinky code
#include <zephyr.h>
#include <device.h>
void main(void)
	while (1) {
                gpio_pin_set_raw(dev0,11,0); // led on
	         	k_msleep(2000);
                gpio_pin_set_raw(dev0, 11, 1); //led off
                k_msleep(4000);
