Mcuboot reboots back to old image
I work on a project that required a sector in flash to store some information hence I changed the partition in the pm_static.yml file and the dts file (although I guess this has no effect when using MCUboot).
The problems I have encountered is the following:
  • Flashing a firmware (A) that uses the new partition, it is not possible to downgrade to a firmware (B) using the old partition. The downgrade is succesful but the system reboots after a few seconds and reverts the image back to (A).
  • Flashing a firmware (B) that uses the old partition, it is possible to upgrade and stay on a firmware (A) that uses the new partition. Doing another upgrade to a firmware (C) that uses the same "new" partition reverts the image back to firmware (A).
I'm calling boot_write_img_confirmed at startup and has not seen any firmware reverts before changing the partition.
  • settings_storage:
      address: 0xfa000
      end_address: 0xfd000
      placement:
        before:
        - user_storage
      region: flash_primary
    user_storage:
      address: 0xfd000
      end_address: 0x100000
      placement:
        before:
        - end
    Old static file
  • settings_storage:
      address: 0xf9000
      end_address: 0xfc000
      placement:
        before:
        - uptime_storage
    uptime_storage:
      address: 0xfc000
      placement:
        before:
        - user_storage
    user_storage:
      address: 0xfd000
      placement:
        before:
        - end
    New static file
  • Could you upload the complete generated pm output you get after buliding the old (B), and the new (A) image? You can find the output in <application>\build\partitions.yml.
  • (A)
    EMPTY_0:
      address: 0xf8000
      end_address: 0xf9000
      placement:
        after:
        - mcuboot_secondary
    app:
      address: 0xc200
      end_address: 0x82000
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0xc000
      end_address: 0xc200
      placement:
        align:
          start: 0x1000
        before:
        - mcuboot_primary_app
    mcuboot_primary:
      address: 0xc000
      orig_span: &id001
      - app
      - mcuboot_pad
      sharers: 0x1
      span: *id001
    mcuboot_primary_app:
      address: 0xc200
      orig_span: &id002
      - app
      span: *id002
    mcuboot_secondary:
      address: 0x82000
      end_address: 0xf8000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x1000
        align_next: 0x1000
      share_size:
      - mcuboot_primary
    settings_storage:
      address: 0xf9000
      placement:
        before:
        - uptime_storage
    sram_primary:
      address: 0x20000000
      end_address: 0x20040000
      region: sram_primary
    uptime_storage:
      address: 0xfc000
      placement:
        before:
        - user_storage
    user_storage:
      address: 0xfd000
      placement:
        before:
        - end
    (B)
    app:
      address: 0xc200
      end_address: 0x83000
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0xc000
      end_address: 0xc200
      placement:
        align:
          start: 0x1000
        before:
    mcuboot_primary:
      address: 0xc000
      orig_span: &id001
      - mcuboot_pad
      - app
      sharers: 0x1
      span: *id001
      address: 0xc200
      orig_span: &id002
      - app
      span: *id002
    mcuboot_secondary:
      address: 0x83000
      end_address: 0xfa000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x1000
        align_next: 0x1000
      share_size:
      - mcuboot_primary
    settings_storage:
      address: 0xfa000
      placement:
        before:
        - user_storage
    sram_primary:
      address: 0x20000000
    user_storage:
      address: 0xfd000
      placement:
        before:
        - end
  • It is not recommended to change the partitions between updates, since mcuboot will still use the old partitions sizes and positions. I can see that the allocated size for the application image is larger for the new build (A) compared to the old build (B) (you can see that mcuboot_primary/secondary has the size 0x76000 in A, and the size 0x77000 in B). Maybe that would cause some issues? I can also see that some other partitions has changed start position.
    However, it is hard to say what's causing it.
    My understanding of the above statement is that MCUboot is able to validate image B and swap it with A, but when booting into B it reboots and swaps back.
    Maybe a fault is happening during the init phase, before image B is able to run boot_write_img_confirmed() (does not confirm itself), and due to CONFIG_RESET_ON_FATAL_ERROR=y, the program resets, swaps back and boots into image A (since B is not confirmed). Could enable UART or RTT logging and set CONFIG_LOG=y in image B and see if you get any info about why it resets?
    Simon
