nRF 52840 thread application stops at otSysProcessDrivers on Fanstel BT840
I am working on BLE+Thread multiprotocol and took ble_thread_swi_template as a base code. I am using nRF5_SDK_for_Thread_and_Zigbee_v4.1.0_32ce5f8. My development hardware is Fanstel BT840. I am using softdevice - s140_nrf52_7.0.1_softdevice.
When I run the template example, the thread gets up but suddenly stops working.
When debugged I found that - When this function - otSysProcessDrivers(mp_ot_instance); is called inside thread_process(), the application suddenly stops.
void thread_process(void)
    ASSERT(mp_ot_instance != NULL);
    otTaskletsProcess(mp_ot_instance);
I also have made internal clock related changes for BT 840: https://devzone.nordicsemi.com/f/nordic-q-a/58956/softdevice-not-working-on-bt840-based-custom-board
#define NRF_SDH_CLOCK_LF_SRC 0
#define NRF_SDH_CLOCK_LF_RC_CTIV 16
#define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
#define NRF_SDH_CLOCK_LF_ACCURACY 1
This same example works on nRF Development Kit but does not work on BT840. I was wondering how does the underlying hardware affecting the thread operation? Kindly let me know if there is any information on this.
Thanks in Advance,
Rajendra
  • This is my main function. The while loop stops printing LOG messages after 2-3 seconds.
    When I comment out otSysProcessDrivers(mp_ot_instance); it keeps on printing LOG messages
    //////////// main function
    log_init();
    scheduler_init();
    timers_init();
    // init Thread stack
    thread_instance_init();
    thread_coap_init();
    NRF_LOG_MSG("\nThread init complete");
    uint32_t loop_cnt = 0;
    uint32_t cnt = 0;
    while (true)
      thread_process(); // calling this function causes issue
      app_sched_execute();
        thread_sleep();
      //// just to check if main is running all the time.
      loop_cnt++;
      if(loop_cnt == 100)
        cnt++;
        NRF_LOG_MSG("\nloop cnt:%d", cnt);
        loop_cnt = 0;
    This is the memory map from linker file, I am using default ld file -ble_thread_swi_template_gcc_nrf52.ld from SDK examples.
    MEMORY
      FLASH (rx) : ORIGIN = 0x27000, LENGTH = 0xd5000
      RAM (rwx) : ORIGIN = 0x20002ae8, LENGTH = 0x3d518
      ot_flash_data (r) : ORIGIN = 0xfc000, LENGTH = 0x4000
    As mentioned above, I have already made clock related changes:
    Clock setting required for Thread:
    CLOCK_CONFIG_LF_SRC 0
    CLOCK_CONFIG_LF_CAL_ENABLED 1
    Clock setting required for Bluetooth:
    I have not debugged inside otSysProcessDrivers yet, may be that would help me. Any quick reference on debugging into openthread?
    Rajendra
  • If you use a mobile application, for example the nRF Connect for Mobile, can you see that your Bluetooth Low Energy is advertising? Will it also advertise if you call otSysProcessDrivers?
    See our tutorial on Debugging with Segger Embedded Studio.
    Sigurd Hellesvik
  • I switched to 'simple_coap_client' from ble_thread_swi_template and switched to 'Fanstel BT840 DK' from my custom board.
    I did this to check if there is any issue with softdevice stack on my custom board. The same issue still persists.
    Now it is clear that Thread stack(SDK:nRF5_SDK_for_Thread_and_Zigbee_v4.1.0_32ce5f8) has some issue running on BT840.
    Rajendra
  • Hi Rajendra,
    Did you test what I suggested in my previous answer?
    Sigurd Hellesvik
  • Hi Sigurd,
    Here in 'ble_thread_swi_template' either THREAD or BLE is running. When BLE is running it runs well. I can see advertising messages, I can connect and disconnect from 'nRF Connect for Mobile'. The issue arises when I switch from BLE to THREAD by calling - 'switch_ble_to_thread()'.
    When I am in THREAD I do not see any advertising messages since BLE is OFF(BLE deinit was called during switching). I also checked in 'nRF5_SDK_for_Thread_and_Zigbee_2.0.0_29775ac' and found that THREAD works well with this SDK
    Here is the summary of the working SDKs.
    SDK OPENTHREAD-VERSION WORKS ON NRF52840-DK? WORKS ON BT840-DK?
    nRF5_SDK_for_Thread_v0.10.0_e1c3d11 OPENTHREAD/g6a15261b-dirty; NRF52840; Jun 29 2017 09:15:02 Yes Yes
    nRF5_SDK_for_Thread_and_Zigbee_2.0.0_29775ac OPENTHREAD/g591ec62; NRF52840; Sep 19 2018 11:42:29 Yes Yes
    nrf5sdkforthreadandzigbeev300d310e71 OPENTHREAD/20180926-00501-g23ff1015; NRF52840; Mar 25 2019 13:04:52 Yes Yes
    nrf5sdkforthreadandzigbeev3209fade31 OPENTHREAD/20180926-00632-g2279ef61; NRF52840; May 23 2019 20:44:20 Yes Yes
    nRF5_SDK_for_Thread_and_Zigbee_v4.1.0_32ce5f8 OPENTHREAD/20191113-00534-gc6a258e3; NRF52840; Apr  5 2020 21:51:18 Yes No
    nrf5_sdk_for_thread_and_zigbee_v4.2.0_af27f76 OPENTHREAD/20191113-00534-gc6a258e3; NRF52840; Apr  5 2020 21:51:18 Yes No
    Best Regards,
    Rajendra
