delay after SPIS uninit
Due to shortage of pins SPI CS is reconfigured as GPIO while SPI is not used. Soft device is not used.
Problem is the delay that is needed after nrfx_spis_uninit call.
Is it possible to check some register to know if uninit is already finished to avoid delay function? 1ms is a quite long period of time to be in delay (it looks that 500us in not enough).
static void spis_generate_irq (void){
  nrfx_spis_uninit(&spis);
  nrfx_coredep_delay_us(1000); // magic delay is necesary
  nrf_gpio_cfg( APP_SPIS_CS_PIN,
                NRF_GPIO_PIN_DIR_OUTPUT,
                NRF_GPIO_PIN_INPUT_DISCONNECT,
                NRF_GPIO_PIN_PULLUP,
                NRF_GPIO_PIN_H0D1,
                NRF_GPIO_PIN_NOSENSE);
  nrf_gpio_pin_write(APP_SPIS_CS_PIN, 0);
  nrfx_coredep_delay_us(100);
  nrf_gpio_pin_write(APP_SPIS_CS_PIN, 1);
Parents Reply
  • Hello
    I've asked about this internally, and was informed this was expected to work without a delay as the product specification states this:
    When the peripheral is disabled, the pins will behave as regular GPIOs and use the configuration in their respective OUT bit field and PIN_CNF[n] register.
    Can you please check the contents of NRF_SPISx->PSEL.MISO/MOSI/SCK/CSN after nrfx_spis_uninit?
    And then NRF_P<number of port>->PIN_CNF[number of pin in port] after configuring GPIO?
    -Einar
