Hi.
I'm trying to add a SPM partition to my project. Like another project i did in the past, i followed this guide: https://devzone.nordicsemi.com/guides/nrf-connect-sdk-guides/b/software/posts/using-a-custom-secure-partition-manager-wtih-your-application
I had problems while building my project so I decided to use the same example that can be downloaded in the guide. However, i get an error when i build it. I have not modified the example.
I'm using an nRF5340DK and I'm building using Visual Studio Code and nRF Connect SDK v1.9.1. I'm building the non-secure module (application) with this build configuration:
- Board: nrf5340dk_nrf5340_cpuapp_ns
- Configuration: prj.conf
Project zip: sample_custom_spm_1_4_0.zip
CMakeError.log obtained after building:
Compiling the C compiler identification source file "CMakeCCompilerId.c" failed.
Compiler: E:/Programs/Nordic/v1.9.1/toolchain/opt/bin/arm-none-eabi-gcc.exe
Build flags:
Id flags:
The output was:
1
e:/programs/nordic/v1.9.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: e:/programs/nordic/v1.9.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/lib\libc.a(lib_a-exit.o): in function `exit':
exit.c:(.text.exit+0x2c): undefined reference to `_exit'
collect2.exe: error: ld returned 1 exit status
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
Build flags:
Id flags:
The output was:
1
Terminal when i try to build the project:
> Executing task: nRF Connect: Generate config nrf5340dk_nrf5340_cpuapp_ns for c:\Nordic\custom_spm_app\application <
Building application
west build --build-dir c:\Nordic\custom_spm_app\application\build c:\Nordic\custom_spm_app\application --pristine --board nrf5340dk_nrf5340_cpuapp_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE"
Including boilerplate (Zephyr base): E:/Programs/Nordic/v1.9.1/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/Nordic/custom_spm_app/application
-- Zephyr version: 2.7.99 (E:/Programs/Nordic/v1.9.1/zephyr), build: v2.7.99-ncs1-1
-- Found Python3: E:/Programs/Nordic/v1.9.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
-- Board: nrf5340dk_nrf5340_cpuapp_ns
-- Cache files will be written to: E:/Programs/Nordic/v1.9.1/zephyr/.cache
-- Found dtc: E:/Programs/Nordic/v1.9.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (e:/Programs/Nordic/v1.9.1/toolchain/opt)
-- Found BOARD.dts: E:/Programs/Nordic/v1.9.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_ns.dts
-- Generated zephyr.dts: C:/Nordic/custom_spm_app/application/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Nordic/custom_spm_app/application/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Nordic/custom_spm_app/application/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Nordic/custom_spm_app/application/build/zephyr/dts.cmake
Parsing E:/Programs/Nordic/v1.9.1/zephyr/Kconfig
Loaded configuration 'E:/Programs/Nordic/v1.9.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_ns_defconfig'
Merged configuration 'C:/Nordic/custom_spm_app/application/prj.conf'
Configuration saved to 'C:/Nordic/custom_spm_app/application/build/zephyr/.config'
Kconfig header saved to 'C:/Nordic/custom_spm_app/application/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: E:/Programs/Nordic/v1.9.1/toolchain/opt/bin/arm-none-eabi-gcc.exe
Skipping building of spm
CMake Warning at E:\Programs\Nordic\v1.9.1\nrf\samples\CMakeLists.txt:49 (message):
NOTE: SPM is not built from source, and the firmware use secure entry
functions. However, the configured library file is not found.
Ensure that the configuration 'ARM_ENTRY_VENEERS_LIB_NAME'
points to the .a file (default 'spm/libspmsecureentries.a')
generated alongside the flashed or merged SPM hex file
Changed board to secure nrf5340dk_nrf5340_cpuapp (NOT NS)
=== child image spm - begin ===
loading initial cache file C:/Nordic/custom_spm_app/application/build/spm/child_image_preload.cmake
-- Application: C:/Nordic/custom_spm_app/spm_module/zephyr/spm
-- Found BOARD.dts: E:/Programs/Nordic/v1.9.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: C:/Nordic/custom_spm_app/application/build/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Nordic/custom_spm_app/application/build/spm/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Nordic/custom_spm_app/application/build/spm/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Nordic/custom_spm_app/application/build/spm/zephyr/dts.cmake
Loaded configuration 'E:/Programs/Nordic/v1.9.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/Nordic/custom_spm_app/spm_module/zephyr/spm/prj.conf'
Merged configuration 'E:/Programs/Nordic/v1.9.1/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/Nordic/custom_spm_app/application/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Nordic/custom_spm_app/application/build/spm/zephyr/.config'
Kconfig header saved to 'C:/Nordic/custom_spm_app/application/build/spm/zephyr/include/generated/autoconf.h'
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Nordic/custom_spm_app/application/build/spm
=== child image spm - end ===
CMake Warning at E:\Programs\Nordic\v1.9.1\nrf\cmake\partition_manager.cmake:58 (message):
One or more child image is not configured to be built from source.
However, there is no static configuration provided to the partition
manager. Please provide a static configuration as described in the
'Scripts -> Partition Manager -> Static configuration' chapter in the
documentation. Without this information, the build system is not able to
place the image correctly in flash.
E:\Programs\Nordic\v1.9.1\zephyr\cmake\app\boilerplate.cmake:678 (include)
E:\Programs\Nordic\v1.9.1\zephyr\share\zephyr-package\cmake\ZephyrConfig.cmake:24 (include)
E:\Programs\Nordic\v1.9.1\zephyr\share\zephyr-package\cmake\ZephyrConfig.cmake:35 (include_boilerplate)
c:\Nordic\custom_spm_app\application\build\CMakeLists.txt:12 (find_package)
File "E:/Programs/Nordic/v1.9.1/nrf/scripts/partition_manager.py", line 1938, in <module>
main()
File "E:/Programs/Nordic/v1.9.1/nrf/scripts/partition_manager.py", line 1006, in main
pm_config = load_reqs(args.input_files)
File "E:/Programs/Nordic/v1.9.1/nrf/scripts/partition_manager.py", line 675, in load_reqs
raise PartitionError(
__main__.PartitionError: Conflicting configuration found for 'C:/Nordic/custom_spm_app/application/build/spm/modules/nrf/subsys/partition_manager/pm.yml.trustzone' value for key 'sram_secure' differs. val1: {'region': 'sram_primary', 'span': ['pcd_sram']} val2: {'span': [], 'region': 'sram_primary'}
CMake Error at E:\Programs\Nordic\v1.9.1\nrf\cmake\partition_manager.cmake:274 (message):
Partition Manager failed, aborting. Command:
E:/Programs/Nordic/v1.9.1/toolchain/opt/bin/python.exe;E:/Programs/Nordic/v1.9.1/nrf/scripts/partition_manager.py;--input-files;C:/Nordic/custom_spm_app/application/build/spm/zephyr/include/generated/pm.yml;C:/Nordic/custom_spm_app/application/build/spm/modules/nrf/subsys/partition_manager/pm.yml.trustzone;C:/Nordic/custom_spm_app/application/build/zephyr/include/generated/pm.yml;C:/Nordic/custom_spm_app/application/build/modules/nrf/subsys/partition_manager/pm.yml.trustzone;--regions;sram_primary;otp;flash_primary;--output-partitions;C:/Nordic/custom_spm_app/application/build/partitions.yml;--output-regions;C:/Nordic/custom_spm_app/application/build/regions.yml;--sram_primary-size;0x80000;--sram_primary-base-address;0x20000000;--sram_primary-placement-strategy;complex;--sram_primary-dynamic-partition;sram_primary;--otp-size;764;--otp-base-address;0xff8100;--otp-placement-strategy;start_to_end;--flash_primary-size;0x100000;--flash_primary-base-address;0x0;--flash_primary-placement-strategy;complex;--flash_primary-device;NRF_FLASH_DRV_NAME
See also "C:/Nordic/custom_spm_app/application/build/CMakeFiles/CMakeOutput.log".
See also "C:/Nordic/custom_spm_app/application/build/CMakeFiles/CMakeError.log".
FATAL ERROR: command exited with status 1: 'e:\Programs\Nordic\v1.9.1\toolchain\opt\bin\cmake.EXE' '-DWEST_PYTHON=e:\Programs\Nordic\v1.9.1\toolchain\opt\bin\python.exe' '-Bc:\Nordic\custom_spm_app\application\build' '-Sc:\Nordic\custom_spm_app\application' -GNinja -DBOARD=nrf5340dk_nrf5340_cpuapp_ns -DNCS_TOOLCHAIN_VERSION:STRING=NONE
The terminal process terminated with exit code: 1.
