I am working on firmware for a custom board with an nRF9160. Specifically, I'm trying to get FOTA updates working, using the provided library functions for it. I had no issues running the sample FOTA update application on an nRF9160DK. I'm using essentially the same procedure as the sample on my custom board's program: submitting a work item when a signal is received, and calling fota_download_start when the work callback is received.
It seems that, after download_client_start is called, the at_cmd thread runs before the download_client thread, as it has higher priority. The at_cmd thread calls recv, getting the first fragment. Then when the download_client thread is given a chance to call recv, there's no more data to receive and the function doesn't return until timing out. I am not sure if this is the intended sequence of events, or something is going wrong. Does it seem like this would be a configuration issue?
The headers and first few bytes of the file get printed through the notification handler. Using the debugger to inspect the AT cmd buffer, I can see that the http headers and fragment are present (printing stops on the first zero byte of course). This is what I was seeing logged in the terminal earlier:
[00:08:28.451,416] <inf> download_client: Configuring socket timeout (120 s)
[00:08:28.455,535] <inf> download_client: Connecting to <our website>
[00:11:26.418,762] <inf> download_client: Downloading: firmware?version=0.0.1 [0]
[00:11:29.493,225] <dbg> at_monitor.at_monitor_task: AT notif: +CSCON: 0
[00:11:29.497,222] <dbg> at_monitor.at_monitor_task: Dispatching to 0x2edb5
[00:11:29.501,403] <dbg> at_monitor.at_monitor_task: AT notif: +CSCON: 1
[00:11:29.505,371] <dbg> at_monitor.at_monitor_task: Dispatching to 0x2edb5
[00:11:29.509,582] <dbg> at_monitor.at_monitor_task: AT notif: +CSCON: 0
[00:11:29.513,549] <dbg> at_monitor.at_monitor_task: Dispatching to 0x2edb5
HTTP/1.1 206 Partial Content
Content-Length: 1024
Content-Type: application/octet-stream4
Content-Range: bytes 0-1023/228839
Accept-Ranges: bytes
Server: Microsoft-IIS/10.0
Content-Disposition: attachment; filename=app_update.bin; filename*=UTF-8''app_update.bin
X-Powered-By: ASP.NET
Date: Thu, 16 Jun 2022 17:09:51 GMT
=¸ó[00:11:57.741,607] <err> at_cmd: AT message empty
[00:12:02.742,248] <err> at_cmd: AT socket recv failed with err 104
Now, I'm getting this error instead of the AT cmd ones:
[00:03:43.071,319] <err> download_client: Error in recv(), errno 116
