Configuration Pin in open-drain output - Low State unexpected
I would like to declare my pin in output open-drain, so i use this configuration
static void gpio_cfg_output_open_collector(uint32_t pin_number)
    nrf_gpio_cfg(
    pin_number,
    NRF_GPIO_PIN_DIR_OUTPUT,
    NRF_GPIO_PIN_INPUT_DISCONNECT,
    NRF_GPIO_PIN_NOPULL,
    NRF_GPIO_PIN_S0D1,							               // Standard '0', disconnect '1'.
    NRF_GPIO_PIN_NOSENSE);
My issue is when i declare my pin, I have an unexpected low state that occur, is this normal?
I tried to configure with pullup, but same behavior.
    gpio_cfg_output_open_collector(PIN_1); // pin goes high to down
    gpio_cfg_output_open_collector(PIN_2); // pin goes high to down
    nrf_gpio_pin_set(PIN_1);
    nrf_gpio_pin_set(PIN_2);
Are my configuration correct ?
I would like to keep the high state during the configuration because a low state provoke a reset on a module not expected.
I'm using a NRF52840 and the S140 v6.1.0
Thanks and best regards,
Julien
