nRF52 start advertising in timeout callback
I am waking nRF52805 up from SYSOFF by an accelerometer, after which I want to wait for a second and then start advertising for a short period.
All is working fine, expect when I try to create an app timer for this delay.
Timer is started and working fine. Only when I try to start advertising from within the timer callback, advertising is not started and NRF_LOG_INFO is also not displayed.
I tried changing the RTC interrupt priority to a lower level (7) but this does not make any difference.
How can I work around this issue? Many thanks!
void timeout_callback(void* p_context)
    UNUSED_PARAMETER(p_context);
    NRF_LOG_INFO("start advertising\n");
    NRF_LOG_FLUSH();
    advertising_start(false);
 * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_app_template_main main.c
 * @ingroup ble_sdk_app_template
 * @brief Template project main file.
 * This file contains a template for creating a new application. It has the code necessary to wakeup
 * from button, advertise, get a connection restart advertising on disconnect and if no new
 * connection created go back to system-off mode.
 * It can easily be used as a starting point for creating a new application, the comments identified
 * with 'YOUR_JOB' indicates where and how you can customize.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdm.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "fds.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "bma400.h"
#include "bma400_twi.h"
#include "nrf_drv_twi.h"
#include "nrf_power.h"
#include "nrf_drv_gpiote.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define INT_1_PIN                       12
#define DEVICE_NAME                     "Qing dice"                             /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "Sophisti"                              /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                350                                     /**< The advertising interval in ms*/
#define APP_ADV_NUM                     10                                       /**< Number of advertisements.*/
//3x adv. 500ms interval
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
/* YOUR_JOB: Declare all services structure your application is using
 *  BLE_XYZ_DEF(m_xyz);
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
static void advertising_start(bool erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_disconnect_on_sec_failure(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    // Create timers.
    /* YOUR_JOB: Create any timers to be used by the application.
                 Below is an example of how to create a timer.
                 For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                 one.
       ret_code_t err_code;
       err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
       APP_ERROR_CHECK(err_code); */
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
static void gap_params_init(int8_t appearance)
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(appearance);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the YYY Service events.
 * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
 * @details This function will be called for all YY Service events which are passed to
 *          the application.
 * @param[in]   p_yy_service   YY Service structure.
 * @param[in]   p_evt          Event received from the YY Service.
static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                       ble_yy_service_evt_t * p_evt)
    switch (p_evt->evt_type)
        case BLE_YY_NAME_EVT_WRITE:
            APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
            // No implementation needed.
    /* YOUR_JOB: Add code to initialize the services used by the application.
       ble_xxs_init_t                     xxs_init;
       ble_yys_init_t                     yys_init;
       // Initialize XXX Service.
       memset(&xxs_init, 0, sizeof(xxs_init));
       xxs_init.evt_handler                = NULL;
       xxs_init.is_xxx_notify_supported    = true;
       xxs_init.ble_xx_initial_value.level = 100;
       err_code = ble_bas_init(&m_xxs, &xxs_init);
       // Initialize YYY Service.
       memset(&yys_init, 0, sizeof(yys_init));
       yys_init.evt_handler                  = on_yys_evt;
       yys_init.ble_yy_initial_value.counter = 0;
       err_code = ble_yy_service_init(&yys_init, &yy_init);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for starting timers.
APP_TIMER_DEF(timeout_id);
void start_timeout(void)
    app_timer_start(timeout_id, APP_TIMER_TICKS(1000), NULL);
    NRF_LOG_INFO("timeout started\n");
    NRF_LOG_FLUSH();
void stop_timeout(void)
    app_timer_stop(timeout_id);
    NRF_LOG_INFO("timeout stopped\n");
    NRF_LOG_FLUSH();
    NRF_LOG_FLUSH();
static void application_timers_start(void)
    err_code = app_timer_create(&timeout_id, APP_TIMER_MODE_SINGLE_SHOT, timeout_callback);
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
        case BLE_ADV_EVT_IDLE:
            NRF_LOG_INFO("Done. sleep mode");
            NRF_LOG_FLUSH();
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
    ret_code_t err_code = NRF_SUCCESS;
            NRF_LOG_INFO("Disconnected.");
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
    ble_advertising_init_t init;
    uint32_t interval = (APP_ADV_INTERVAL*1.6);
    uint32_t timeout  = (APP_ADV_INTERVAL*APP_ADV_NUM)/10;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.config.ble_adv_fast_interval = interval;
    init.config.ble_adv_fast_timeout  = timeout;
static void log_init(void)
        nrf_pwr_mgmt_run();
void advertising_restart(void)
    ret_code_t ret = ble_advertising_restart_without_whitelist(&m_advertising);
    APP_ERROR_CHECK(ret);
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV,m_advertising.adv_handle,-20);   //set advertising power to -40dbm    Supported tx_power values: -40dBm, -20dBm, -16dBm, -12dBm, -8dBm, -4dBm, 0dBm, +3dBm and +4dBm.
void in_pin_handler(nrfx_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    if (pin == 12) {
    // interrupt detected while on
    // do something if needed
static void gpio_init(void)
    //Initialize gpiote module
    //Configure sense input pin to enable wakeup and interrupt on button press.
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(false);        //Configure to generate interrupt and wakeup on pin signal low. "false" means that gpiote will use the PORT event, which is low power, i.e. does not add any noticable current consumption (<<1uA). Setting this to "true" will make the gpiote module use GPIOTE->IN events which add ~8uA for nRF52 and ~1mA for nRF51.
    //in_config.pull = NRF_GPIO_PIN_PULLDOWN;                                           //Configure pullup for input pin to prevent it from floting. Pin is pulled down when button is pressed on nRF5x-DK boards, see figure two in http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf52/dita/nrf52/development/dev_kit_v1.1.0/hw_btns_leds.html?cp=2_0_0_1_4
    err_code = nrf_drv_gpiote_in_init(INT_1_PIN, &in_config, in_pin_handler);           //Initialize the pin with interrupt handler in_pin_handler
    nrf_drv_gpiote_in_event_enable(INT_1_PIN, true);                                    //Enable event and interrupt for the wakeup pin
    APP_ERROR_CHECK(err_code);                                                          //Check potential error
/* Earth's gravity in m/s^2 */
#define GRAVITY_EARTH     (9.80665f)
/* 39.0625us per tick */
#define SENSOR_TICK_TO_S  (0.0000390625f)
static float lsb_to_ms2(int16_t accel_data, uint8_t g_range, uint8_t bit_width)
    float accel_ms2;
    int16_t half_scale;
    half_scale = 1 << (bit_width - 1);
    accel_ms2 = (GRAVITY_EARTH * accel_data * g_range) / half_scale;
    return accel_ms2;
/**@brief Function for application main entry.
    // Initialize.
    nrf_power_dcdcen_set(true);
    log_init();
    timers_init();
    power_management_init();
    gpio_init();
    struct bma400_dev bma;
    int8_t rslt = 0;
    uint16_t int_status;
    struct bma400_sensor_data accel;
    struct bma400_sensor_conf accel_settin[2] = { { 0 } };
    struct bma400_int_enable int_en;
    struct bma400_device_conf dev_settings[2];
    rslt = bma400_interface_init(&bma, BMA400_I2C_INTF);      //initialization of I2C interface for BMA400
    bma400_check_rslt("bma400_interface_init", rslt);
    rslt = bma400_soft_reset(&bma);                           //reset all registers
    bma400_check_rslt("bma400_soft_reset", rslt);
    rslt = bma400_init(&bma);
    bma400_check_rslt("bma400_init", rslt);
    accel_settin[0].type = BMA400_GEN1_INT;
    accel_settin[1].type = BMA400_ACCEL;
    rslt = bma400_set_power_mode(BMA400_MODE_NORMAL, &bma);
    bma400_check_rslt("bma400_set_power_mode", rslt);
    rslt = bma400_get_sensor_conf(accel_settin, 2, &bma);
    bma400_check_rslt("bma400_get_sensor_conf", rslt);
    //set inactivity threshold to 0x3F = 63LSBs = 63LSBs * 8mg/LSB = 504mg (can be fine-tuned). So the threshold zone is    +/-504mg
    accel_settin[0].param.gen_int.gen_int_thres     =   0x03F;
    //set MSB of Gen1 to 0x00
    //set LSB of Gen1 interrupt duration to 0x0C = 12LSBs = 12 * 10ms =120ms (can be fine-tuned).
    //This corresponds to about 7cm height freefall. H=0.5 * g * t^2 = 0.5 * 9.81m/s^2 *(0.12s)^2
    accel_settin[0].param.gen_int.gen_int_dur       =   0x0A;
    //enable X/Y/Z axis for interrupt evaluation.
    accel_settin[0].param.gen_int.axes_sel          =   BMA400_AXIS_XYZ_EN;
    //Gen1 interrupt engine data source is acc_filt2 which is fixed 100Hz ODR or 10ms   time interval.
    accel_settin[0].param.gen_int.data_src          =   BMA400_DATA_SRC_ACCEL_FILT_2;
    //select inactivity detection which means the interrupt will be generated with in the positive and negative threshold zone
    accel_settin[0].param.gen_int.criterion_sel     =   BMA400_INACTIVITY_INT;
    //Select AND logic meaning that when all enabled axes enter the threshold zone simultaneously an interrupt will be generated
    accel_settin[0].param.gen_int.evaluate_axes     =   BMA400_ALL_AXES_INT;
    //Manual update and hysteresis 0mg
    accel_settin[0].param.gen_int.ref_update        =   BMA400_UPDATE_MANUAL;
    accel_settin[0].param.gen_int.hysteresis        =   BMA400_HYST_0_MG;
    accel_settin[0].param.gen_int.int_thres_ref_x   =   0; //  set X axis reference to 0mg
    accel_settin[0].param.gen_int.int_thres_ref_y   =   0; //  set Y axis reference to 0mg
    accel_settin[0].param.gen_int.int_thres_ref_z   =   0; //  set Z axis reference to 0mg
    accel_settin[0].param.gen_int.int_chan          =   BMA400_INT_CHANNEL_1;
    accel_settin[1].param.accel.odr = BMA400_ODR_200HZ;
    accel_settin[1].param.accel.range = BMA400_RANGE_4G;
    accel_settin[1].param.accel.data_src = BMA400_DATA_SRC_ACCEL_FILT_1;
    accel_settin[1].param.accel.osr = BMA400_ACCEL_OSR_SETTING_0;
    /* Set the desired configurations to the sensor */
    rslt = bma400_set_sensor_conf(accel_settin, 2, &bma);
    bma400_check_rslt("bma400_set_sensor_conf", rslt);
    int_en.type = BMA400_GEN1_INT_EN;
    int_en.conf = BMA400_ENABLE;
    rslt = bma400_enable_interrupt(&int_en, 1, &bma);
    bma400_check_rslt("bma400_enable_interrupt", rslt);
    dev_settings[0].type = BMA400_INT_PIN_CONF;
    dev_settings[0].param.int_conf.int_chan = BMA400_INT_CHANNEL_1;
    dev_settings[0].param.int_conf.pin_conf = BMA400_INT_PUSH_PULL_ACTIVE_0;
    rslt = bma400_set_device_conf(dev_settings, 1, &bma);
    bma400_check_rslt("bma400_set_device_conf", rslt);
    printf("Show activity on x y z axes of the board\n");
    NRF_LOG_INFO("started\n");
    NRF_LOG_FLUSH();
    struct bma400_sensor_data data;
    bma400_get_accel_data(BMA400_DATA_ONLY, &data, &bma);
    float t, x, y, z;
    uint8_t side = 0;
    /* 12-bit accelerometer at range 2G */
    x = lsb_to_ms2(data.x, 2, 12);
    y = lsb_to_ms2(data.y, 2, 12);
    z = lsb_to_ms2(data.z, 2, 12);
    printf("Gravity-x : %.2f\t   Gravity-y : %.2f\t  Gravity-z :  %.2f\t", x, y, z);
    if      (x >= -5  && x <= 5   /* x =  00 */   &&      y >= -5  && y <= 5   /* y =  00 */    &&     z >=  5  && z <=  10  /* z =  10 */)   side = 1;
    else if (x >= -5  && x <= 5   /* x =  00 */   &&      y >=  5  && y <= 10  /* y =  10 */    &&     z >= -5  && z <=  5   /* z =  00 */)   side = 2;
    else if (x >=  5  && x <= 10  /* x =  10 */   &&      y >= -5  && y <= 5   /* y =  00 */    &&     z >= -5  && z <=  5   /* z =  00 */)   side = 3;
    else if (x >= -10 && x <= -5  /* x = -10 */   &&      y >= -5  && y <= 5   /* y =  00 */    &&     z >= -5  && z <=  5   /* z =  00 */)   side = 4;
    else if (x >= -5  && x <= 5   /* x =  00 */   &&      y >= -10 && y <= -5  /* y = -10 */    &&     z >= -5  && z <=  5   /* z =  00 */)   side = 5;
    else if (x >= -5  && x <= 5   /* x =  00 */   &&      y >= -5  && y <= 5   /* y =  00 */    &&     z >= -10 && z <= -5   /* z = -10 */)   side = 6;
    printf("    side: %d\n", side);
    ble_stack_init();
    gap_params_init(side);
    gatt_init();
    advertising_init();
    services_init();
    conn_params_init();
    peer_manager_init();
    application_timers_start();
    start_timeout();
        for (;;)
        idle_state_handle();
