Currently working Project + SAADC
HI All!
I am having an issue when I add the SAADC to my working project. I added all the required files and enabled the sdk_config.h file exactly the same as of original SAADC example config file.
I also tried to SAADC_ENABLED 0, as there was one solution in the nrf forum . but the same errors as shown in the attached image.
I got the following errors as shown in the image, which shows me that there is no nrfx_saadc.h file. Can you please help me in this regard?
I also attached the project file in .zip format. i am using nrf52820/33. You can compile it with pca10100e.
Building ‘ble_app_uart_pca10100e_s140’ from solution ‘ble_app_uart_pca10100e_s140’ in configuration ‘Release’
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/thumb_crt0.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_log_backend_rtt.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_log_backend_serial.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_log_default_backends.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_log_frontend.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_log_str_formatter.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/app_button.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/app_error.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/app_error_handler_gcc.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/app_error_weak.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/app_fifo.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/app_scheduler.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/app_timer2.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/app_uart_fifo.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/app_util_platform.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/drv_rtc.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/hardfault_implementation.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_assert.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_atfifo.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_atflags.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_atomic.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_balloc.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_fprintf.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_fprintf_format.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_memobj.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_pwr_mgmt.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_ringbuf.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_section_iter.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_sortlist.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_strerror.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/retarget.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/ses_startup_nrf52820.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/ses_startup_nrf_common.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/system_nrf52820.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/boards.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_drv_clock.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_drv_uart.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrfx_atomic.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrfx_clock.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrfx_gpiote.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrfx_prs.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrfx_uart.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrfx_uarte.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_drv_twi.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrfx_twi.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrfx_twim.o' is up to date
  C:/Nordic_Semi/nRF5_SDK_17.1.0_ddde560/nRF5_SDK_17.1.0_ddde560/examples/My projects Practice Modules/Coded-phy-nrf52820_Pheri_TLV493D_V1/pca10100e/s140/config/sdk_config.h (19.06.2022 17:49:42) is newer than Output/Release/Obj/ble_app_uart_pca10100e_s140/nrfx_saadc.o (19.06.2022 17:14:14).
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/bsp.o' is up to date
  Compiling ‘nrfx_saadc.c’
    nrfx_saadc.h
    nrfx_saadc.c
    'SAADC_RESOLUTION_VAL_8bit' undeclared here (not in a function)
    'SAADC_RESOLUTION_VAL_10bit' undeclared here (not in a function)
    'SAADC_RESOLUTION_VAL_12bit' undeclared here (not in a function)
    'SAADC_RESOLUTION_VAL_14bit' undeclared here (not in a function)
    'SAADC_CH_PSELP_PSELP_NC' undeclared here (not in a function)
    'SAADC_CH_PSELP_PSELP_AnalogInput0' undeclared here (not in a function); did you mean 'COMP_PSEL_PSEL_AnalogInput0'?
    'SAADC_CH_PSELP_PSELP_AnalogInput1' undeclared here (not in a function); did you mean 'COMP_PSEL_PSEL_AnalogInput1'?
    'SAADC_CH_PSELP_PSELP_AnalogInput2' undeclared here (not in a function); did you mean 'COMP_PSEL_PSEL_AnalogInput2'?
    'SAADC_CH_PSELP_PSELP_AnalogInput3' undeclared here (not in a function); did you mean 'COMP_PSEL_PSEL_AnalogInput3'?
    'SAADC_CH_PSELP_PSELP_AnalogInput4' undeclared here (not in a function); did you mean 'COMP_PSEL_PSEL_AnalogInput0'?
    'SAADC_CH_PSELP_PSELP_AnalogInput5' undeclared here (not in a function); did you mean 'COMP_PSEL_PSEL_AnalogInput0'?
    'SAADC_CH_PSELP_PSELP_AnalogInput6' undeclared here (not in a function); did you mean 'COMP_PSEL_PSEL_AnalogInput0'?
    'SAADC_CH_PSELP_PSELP_AnalogInput7' undeclared here (not in a function); did you mean 'COMP_PSEL_PSEL_AnalogInput0'?
    'SAADC_CH_PSELP_PSELP_VDD' undeclared here (not in a function)
    'SAADC_OVERSAMPLE_OVERSAMPLE_Bypass' undeclared here (not in a function)
    'SAADC_OVERSAMPLE_OVERSAMPLE_Over2x' undeclared here (not in a function)
    'SAADC_OVERSAMPLE_OVERSAMPLE_Over4x' undeclared here (not in a function)
    'SAADC_OVERSAMPLE_OVERSAMPLE_Over8x' undeclared here (not in a function)
    'SAADC_OVERSAMPLE_OVERSAMPLE_Over16x' undeclared here (not in a function)
    'SAADC_OVERSAMPLE_OVERSAMPLE_Over32x' undeclared here (not in a function)
    'SAADC_OVERSAMPLE_OVERSAMPLE_Over64x' undeclared here (not in a function)
    'SAADC_OVERSAMPLE_OVERSAMPLE_Over128x' undeclared here (not in a function)
    'SAADC_OVERSAMPLE_OVERSAMPLE_Over256x' undeclared here (not in a function)
    'SAADC_CH_CONFIG_RESP_Bypass' undeclared here (not in a function)
    'SAADC_CH_CONFIG_RESP_Pulldown' undeclared here (not in a function)
    'SAADC_CH_CONFIG_RESP_Pullup' undeclared here (not in a function)
    'SAADC_CH_CONFIG_RESP_VDD1_2' undeclared here (not in a function)
    'SAADC_CH_CONFIG_GAIN_Gain1_6' undeclared here (not in a function)
    'SAADC_CH_CONFIG_GAIN_Gain1_5' undeclared here (not in a function)
    'SAADC_CH_CONFIG_GAIN_Gain1_4' undeclared here (not in a function)
    'SAADC_CH_CONFIG_GAIN_Gain1_3' undeclared here (not in a function)
    'SAADC_CH_CONFIG_GAIN_Gain1_2' undeclared here (not in a function)
    'SAADC_CH_CONFIG_GAIN_Gain1' undeclared here (not in a function)
    'SAADC_CH_CONFIG_GAIN_Gain2' undeclared here (not in a function)
    'SAADC_CH_CONFIG_GAIN_Gain4' undeclared here (not in a function)
    'SAADC_CH_CONFIG_REFSEL_Internal' undeclared here (not in a function)
    'SAADC_CH_CONFIG_REFSEL_VDD1_4' undeclared here (not in a function)
    'SAADC_CH_CONFIG_TACQ_3us' undeclared here (not in a function)
    'SAADC_CH_CONFIG_TACQ_5us' undeclared here (not in a function)
    'SAADC_CH_CONFIG_TACQ_10us' undeclared here (not in a function)
    'SAADC_CH_CONFIG_TACQ_15us' undeclared here (not in a function)
    'SAADC_CH_CONFIG_TACQ_20us' undeclared here (not in a function)
    'SAADC_CH_CONFIG_TACQ_40us' undeclared here (not in a function)
    'SAADC_CH_CONFIG_MODE_SE' undeclared here (not in a function)
    nrfx_saadc.h
    nrfx_saadc.c
    'SAADC_CH_CONFIG_MODE_Diff' undeclared here (not in a function)
    'SAADC_CH_CONFIG_BURST_Disabled' undeclared here (not in a function)
    'SAADC_CH_CONFIG_BURST_Enabled' undeclared here (not in a function)
    nrfx_glue.h
    nrfx.h
    nrfx_saadc.c
    unknown type name 'NRF_SAADC_Type'
    in definition of macro 'offsetof'
    nrfx_saadc.h
    nrfx_saadc.c
    'SAADC_INTENSET_STARTED_Msk' undeclared here (not in a function); did you mean 'SPIM_INTENSET_STARTED_Msk'?
    'SAADC_INTENSET_END_Msk' undeclared here (not in a function); did you mean 'AAR_INTENSET_END_Msk'?
    'SAADC_INTENSET_DONE_Msk' undeclared here (not in a function); did you mean 'CLOCK_INTENSET_DONE_Msk'?
    'SAADC_INTENSET_RESULTDONE_Msk' undeclared here (not in a function); did you mean 'AAR_INTENSET_RESOLVED_Msk'?
    'SAADC_INTENSET_CALIBRATEDONE_Msk' undeclared here (not in a function); did you mean 'USBD_INTENSET_EP0DATADONE_Msk'?
    'SAADC_INTENSET_STOPPED_Msk' undeclared here (not in a function); did you mean 'QDEC_INTENSET_STOPPED_Msk'?
    'SAADC_INTENSET_CH0LIMITH_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH0LIMITL_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH1LIMITH_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH1LIMITL_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH2LIMITH_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH2LIMITL_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH3LIMITH_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH3LIMITL_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH4LIMITH_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH4LIMITL_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH5LIMITH_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH5LIMITL_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH6LIMITH_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH6LIMITL_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH7LIMITH_Msk' undeclared here (not in a function)
    'SAADC_INTENSET_CH7LIMITL_Msk' undeclared here (not in a function)
    'NRF_SAADC' undeclared (first use in this function); did you mean 'NRF_SAADC_H_'?
    each undeclared identifier is reported only once for each function it appears in
    'SAADC_CH_LIMIT_LOW_Pos' undeclared (first use in this function)
    'SAADC_CH_LIMIT_LOW_Msk' undeclared (first use in this function)
    'SAADC_CH_LIMIT_HIGH_Pos' undeclared (first use in this function)
    'SAADC_CH_LIMIT_HIGH_Msk' undeclared (first use in this function)
    'SAADC_ENABLE_ENABLE_Enabled' undeclared (first use in this function); did you mean 'AAR_ENABLE_ENABLE_Enabled'?
    'SAADC_ENABLE_ENABLE_Pos' undeclared (first use in this function); did you mean 'AAR_ENABLE_ENABLE_Pos'?
    'SAADC_ENABLE_ENABLE_Disabled' undeclared (first use in this function); did you mean 'AAR_ENABLE_ENABLE_Disabled'?
    'SAADC_SAMPLERATE_MODE_Timers' undeclared (first use in this function)
    'SAADC_SAMPLERATE_MODE_Pos' undeclared (first use in this function)
    'SAADC_SAMPLERATE_CC_Pos' undeclared (first use in this function)
    'SAADC_SAMPLERATE_MODE_Msk' undeclared (first use in this function)
    'SAADC_SAMPLERATE_MODE_Task' undeclared (first use in this function)
    'SAADC_CH_CONFIG_RESP_Pos' undeclared (first use in this function)
    'SAADC_CH_CONFIG_RESP_Msk' undeclared (first use in this function)
    'SAADC_CH_CONFIG_RESN_Pos' undeclared (first use in this function)
    'SAADC_CH_CONFIG_RESN_Msk' undeclared (first use in this function)
    'SAADC_CH_CONFIG_GAIN_Pos' undeclared (first use in this function)
    'SAADC_CH_CONFIG_GAIN_Msk' undeclared (first use in this function)
    'SAADC_CH_CONFIG_REFSEL_Pos' undeclared (first use in this function)
    'SAADC_CH_CONFIG_REFSEL_Msk' undeclared (first use in this function)
    'SAADC_CH_CONFIG_TACQ_Pos' undeclared (first use in this function)
    'SAADC_CH_CONFIG_TACQ_Msk' undeclared (first use in this function)
    'SAADC_CH_CONFIG_MODE_Pos' undeclared (first use in this function); did you mean 'GPIOTE_CONFIG_MODE_Pos'?
    'SAADC_CH_CONFIG_MODE_Msk' undeclared (first use in this function); did you mean 'GPIOTE_CONFIG_MODE_Msk'?
    'SAADC_CH_CONFIG_BURST_Pos' undeclared (first use in this function)
    'SAADC_CH_CONFIG_BURST_Msk' undeclared (first use in this function)
    nrfx.h
    nrfx_saadc.c
    'SAADC_IRQn' undeclared (first use in this function); did you mean 'ADC_IRQn'?
    in definition of macro 'NRFX_IRQ_PRIORITY_SET'
    in definition of macro 'NRFX_IRQ_DISABLE'
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/bsp_btn_ble.o' is up to date
  ../../../main.c (19.06.2022 18:22:34) is newer than Output/Release/Obj/ble_app_uart_pca10100e_s140/main.o (19.06.2022 17:14:16).
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/SEGGER_RTT.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/SEGGER_RTT_Syscalls_SES.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/SEGGER_RTT_printf.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/ble_advdata.o' is up to date
  Compiling ‘main.c’
    nrfx_saadc.h
    nrf_drv_saadc.h
    main.c
    nrfx_saadc.h
    nrf_drv_saadc.h
    main.c
    sdk_common.h
    ble_advdata.h
    main.c
    nrfx_saadc.h
    nrf_drv_saadc.h
    main.c
    'Sample_Buffer_Len' undeclared (first use in this function)
    passing argument 2 of 'nrf_drv_saadc_init' from incompatible pointer type [-Wincompatible-pointer-types]
    main.c
    expected 'nrfx_saadc_event_handler_t' {aka 'void (*)(const nrfx_saadc_evt_t *)'} but argument is of type 'void (*)(nrfx_saadc_evt_t *)'
    'm_buffer_pool' undeclared (first use in this function)
    passing argument 2 of 'ble_nus_data_send' from incompatible pointer type [-Wincompatible-pointer-types]
    main.c
    expected 'uint8_t *' {aka 'unsigned char *'} but argument is of type 'unsigned char (*)[]'
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/ble_advertising.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/ble_conn_params.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/ble_conn_state.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/ble_link_ctx_manager.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/ble_srv_common.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_ble_gatt.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_ble_qwr.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/utf.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/ble_nus.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_sdh.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_sdh_ble.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/nrf_sdh_soc.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/Loading_Events.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/Timers.o' is up to date
  'Output/Release/Obj/ble_app_uart_pca10100e_s140/Tlv493d.o' is up to date
Build failed
Coded-phy-nrf52820_Pheri_TLV493D_V1.zip
thanks in advance! for the help!
