Avoid connection of nearby devices with same firmware with each other (NRF52833).
Hi Everyone,
               I am working on NRF52833. I have developed code for our project. Now in this project the phone app will connect with the device using BLE for which I have implemented Pairing mechanism. When I load the firmware into the device and try to connect it via NRF connect app, the device asks for pairing. In code I have defined static Key. So when I put that static key in the pairing of phone, my NRFconnect app is able to connect to the device successfully.
Now I am having 2 devices( Device A & Device B). The same firmware is loaded into these 2 NRF52833 devices. Both the devices turned ON. What I am observing is device A and device B gets connected to each other and the devices goes into some restart mechanism. I don't want any connectivity between device A and device B. This is creating issue for me. Even though I have implemented pairing mechanism but these devices seem to connect each other without any pairing activity. How can I avoid this?? I have attached my main.c file below:-
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_freertos.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "FreeRTOS.h"
#include "task.h"
#include "timers.h"
#include "semphr.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "ble_dfu.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_clock.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_power.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "product_config.h"
#include "ble_lender.h"
#include "ble_borrower.h"
#include "task_led_button.h"
#include "task_lender.h"
#include "task_borrower.h"
#include "task_system.h"
#include "task_psf_comm.h"
#include "device_storage.h"
#include "nrf_drv_gpiote.h"
#include "battery.h"
#include "version.h"
#include "lender.h"
#include "borrower.h"
#include "psf_comm.h"
#include "nrf_drv_twi.h"
#include "psf_i2c.h"
#include "bq24292i.h"
#include "max17211_i2c.h"
#define DEVICE_NAME                         LE_DEVICE_NAME                            /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME                   "Target"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_BLE_OBSERVER_PRIO               3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG                1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL                    5000 //300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                    18000//18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define RTC_INTERVAL                        1000                                    /**< RTC interval (ms). */
#define MIN_BATTERY_LEVEL                   81                                      /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL                   100                                     /**< Maximum simulated battery level. */
#define MIN_CONN_INTERVAL                   MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL                   MSEC_TO_UNITS(300, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY                       0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                    MSEC_TO_UNITS(5000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY      5000                                    /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY       30000                                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT        3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                      1                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                      0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_DISPLAY_ONLY                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE              7                                      /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                           0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define OSTIMER_WAIT_FOR_QUEUE              2                                       /**< Number of ticks to wait for the timer queue to be ready */
#define DEVICEID_SIZE           16
uint8_t device_id[DEVICEID_SIZE+1] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
extern uint8_t adv_led_button;
extern uint8_t led_on_duration;
extern uint8_t led_grn_pwr_active;
extern uint8_t led_grn_pwr_state;
int8_t rssi;
static char app_fw_version[32];
uint8_t rclr_data_buf[256] = {0};
uint8_t rcbr_data_buf[256] = {0};
uint16_t rclr_data_cnt = 0;
uint16_t rcbr_data_cnt = 0;
BLE_RCLR_DEF(m_rclr, NRF_SDH_BLE_TOTAL_LINK_COUNT);                  /**< BLE R3charge lender service instance. */
BLE_RCBR_DEF(m_rcbr, NRF_SDH_BLE_TOTAL_LINK_COUNT);                  /**< BLE R3charge borrower service instance. */
BLE_BAS_DEF(m_bas);                                                 /**< Battery service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
////////////Added for bonding///////////
// Static passkey
#define STATIC_PASSKEY    "123456"
static ble_opt_t    m_static_pin_option;
uint8_t passkey[] = STATIC_PASSKEY;
static uint16_t m_conn_handle         = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static ble_uuid_t m_adv_uuids[] =                                   /**< Universally unique service identifiers. */
   // {BLE_UUID_RCLR_SERVICE, BLE_UUID_TYPE_VENDOR_BEGIN},
    {BLE_UUID_RCBR_SERVICE, BLE_UUID_TYPE_VENDOR_BEGIN}
static void advertising_config_get(ble_adv_modes_config_t * p_config)
    memset(p_config, 0, sizeof(ble_adv_modes_config_t));
    p_config->ble_adv_fast_enabled  = true;
    p_config->ble_adv_fast_interval = APP_ADV_INTERVAL;
    p_config->ble_adv_fast_timeout  = APP_ADV_DURATION;
static void disconnect(uint16_t conn_handle, void * p_context)
    UNUSED_PARAMETER(p_context);
    ret_code_t err_code = sd_ble_gap_disconnect(conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    if (err_code != NRF_SUCCESS)
        NRF_LOG_WARNING("Failed to disconnect connection. Connection handle: %d Error: %d", conn_handle, err_code);
        NRF_LOG_DEBUG("Disconnected connection handle %d", conn_handle);
static TimerHandle_t m_rtc_timer;                               /**< Definition of battery timer. */
#if NRF_LOG_ENABLED
static TaskHandle_t m_logger_thread;                                /**< Definition of Logger thread. */
static void advertising_start(void * p_erase_bonds);
static void nrf_nvmc_write_word(uint32_t address, uint32_t value);
ble_rclr_t * get_rclr_service(void)
    return &m_rclr;
ble_rcbr_t * get_rcbr_service(void)
    return &m_rcbr;
uint16_t get_conn_handle(void)
    return m_conn_handle;
uint8_t * get_rclr_rcv_buffer(void)
    return rclr_data_buf;
uint16_t get_rclr_rcv_cnt(void)
    return rclr_data_cnt;
uint8_t * get_rcbr_rcv_buffer(void)
    return rcbr_data_buf;
uint16_t get_rcbr_rcv_cnt(void)
    return rcbr_data_cnt;
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    bool delete_bonds = false;
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id) {
        //..advertising_start(&delete_bonds);
        advertising_start(false);
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
 *        in Battery Service.
void battery_level_update(void)
    ret_code_t err_code;
    uint8_t  battery_level;
    battery_level = battery_get_percentage(); /* Update TODO */
    err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
    if ((err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != NRF_ERROR_BUSY) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
uint32_t rtc_val = 0;
uint32_t get_system_rtc(void)
    return rtc_val;
/**@brief Function for handling the RTC event
 * @details This function will be called each time the RTC timer expires.
 * @param[in] xTimer Handler to the timer that called this function.
 *                   You may get identifier given to the function xTimerCreate using pvTimerGetTimerID.
static void rtc_timeout_handler(TimerHandle_t xTimer)
    UNUSED_PARAMETER(xTimer);
    rtc_val++;
static StaticTimer_t xRTCTimer;
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    // Create timers.
    m_rtc_timer = xTimerCreateStatic("RTC",
                                     RTC_INTERVAL,
                                     pdTRUE,
                                     NULL,
                                     rtc_timeout_handler,
                                     &xRTCTimer);
    /* Error checking */
    if (NULL == m_rtc_timer) {
        APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    //commented for adding device id.
    //err_code = sd_ble_gap_device_name_set(&sec_mode,
    //                                      (const uint8_t *)DEVICE_NAME,
    //                                      strlen(DEVICE_NAME));
#ifdef USE_DEVICEID_ON_SRDATA
#else
    uint8_t basename_size = strlen(DEVICE_NAME);
    uint8_t devicename[DEVICEID_SIZE+1+basename_size+1];
    memcpy(&devicename[0], (const uint8_t *)DEVICE_NAME, basename_size);
    devicename[basename_size] = '-';
    memcpy(&devicename[basename_size+1], device_id, DEVICEID_SIZE);
    memset(&devicename[basename_size+1+DEVICEID_SIZE], 0x00, 1);
                                          (const uint8_t *)devicename,
                                          strlen(devicename));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
    ////////Added for bonding ///////////
    m_static_pin_option.gap_opt.passkey.p_passkey = &passkey[0];
    err_code =  sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
/**@brief Function for initializing the GATT module. */
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    APP_ERROR_HANDLER(nrf_error);
static void rclr_data_handler(ble_rclr_evt_t * p_evt)
    if (p_evt->type == BLE_RCLR_EVT_RX_DATA) {
        uint32_t err_code;
        if(p_evt->params.rx_data.length < sizeof(rclr_data_buf)) {
            memset(rclr_data_buf, 0, sizeof(rclr_data_buf));
            memcpy(rclr_data_buf, p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
            rclr_data_cnt = p_evt->params.rx_data.length;
            /* Inform lender Task we have a command */
            lender_task_queue_event(LENDER_TASK_EVT_SETTING_CMD);
    } else if(p_evt->type == BLE_RCLR_EVT_NOTIF_ENABLED) {
        /* Inform lender Task notifications have begun */
        lender_task_queue_event(LENDER_TASK_EVT_NOTIF_EN);
static void rcbr_data_handler_new(ble_rcbr_evt_t * p_evt)
    psf_comm_task_evt_t evt;
    if (p_evt->type == BLE_RCBR_EVT_RX_DATA) {
        uint32_t err_code;
        if(p_evt->params.rx_data.length < MAX_FRAME_PAYLOAD_SIZE) {
            evt.evt_id = PSF_COMM_TASK_EVT_PSF_DATA;
            evt.length = p_evt->params.rx_data.length;
            memcpy(evt.payload, p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
            psf_comm_task_queue_event(&evt);
    } else if(p_evt->type == BLE_RCBR_EVT_NOTIF_ENABLED) {
        /* Inform Toilet Task notifications have begun */
        // toilet_task_queue_event(TOILET_TASK_EVT_NOTIF_EN);
static void rcbr_data_handler(ble_rcbr_evt_t * p_evt)
        uint32_t err_code;
        if(p_evt->params.rx_data.length < sizeof(rcbr_data_buf)) {
            memset(rcbr_data_buf, 0, sizeof(rcbr_data_buf));
            memcpy(rcbr_data_buf, p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
            rcbr_data_cnt = p_evt->params.rx_data.length;
            /* Inform borrower Task we have a command */
            borrower_task_queue_event(BORROWER_TASK_EVT_SETTING_CMD);
        /* Inform borrower Task notifications have begun */
        borrower_task_queue_event(BORROWER_TASK_EVT_NOTIF_EN);
 * @details Initialize the Heart Rate, Battery and Device Information services.
    ble_rclr_init_t    rclr_init;
    ble_rcbr_init_t    rcbr_init;
    ble_bas_init_t     bas_init;
    ble_dis_init_t     dis_init;
    uint8_t            body_sensor_location;
    // Initialize Battery Service.
    memset(&bas_init, 0, sizeof(bas_init));
    // Here the sec level for the Battery Service can be changed/increased.
    bas_init.bl_rd_sec        = SEC_OPEN;
    bas_init.bl_cccd_wr_sec   = SEC_OPEN;
    bas_init.bl_report_rd_sec = SEC_OPEN;
    bas_init.evt_handler          = NULL;
    bas_init.support_notification = true;
    bas_init.p_report_ref         = NULL;
    bas_init.initial_batt_level   = 100;
    err_code = ble_bas_init(&m_bas, &bas_init);
    // Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
    ble_srv_ascii_to_utf8(&dis_init.model_num_str, (char *)DEVICE_MODEL_NUM);
    ble_srv_ascii_to_utf8(&dis_init.serial_num_str, (char *)device_id);
    ble_srv_ascii_to_utf8(&dis_init.hw_rev_str, (char *)DEVICE_HW_VER);
    ble_srv_ascii_to_utf8(&dis_init.fw_rev_str, (char *)app_fw_version);
    dis_init.dis_char_rd_sec = SEC_OPEN;
    err_code = ble_dis_init(&dis_init);
    // Initialize RCLR- LENDER Service
    memset(&rclr_init, 0, sizeof(rclr_init));
    rclr_init.data_handler = rclr_data_handler;
    err_code = ble_rclr_init(&m_rclr, &rclr_init);
   // Initialize RCBR - BORROWER Service
    memset(&rcbr_init, 0, sizeof(rcbr_init));
    rcbr_init.data_handler = rcbr_data_handler;
    err_code = ble_rcbr_init(&m_rcbr, &rcbr_init);
/**@brief   Function for starting application timers.
 * @details Timers are run after the scheduler has started.
static void application_timers_start(void)
    // Start application timers.
    if (pdPASS != xTimerStart(m_rtc_timer, OSTIMER_WAIT_FOR_QUEUE)) {
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
 * @param[in]   p_evt   Event received from the Connection Parameters Module.
    if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) {
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for initializing the Connection Parameters module. */
    //err_code = bsp_indication_set(BSP_INDICATE_IDLE);
    //APP_ERROR_CHECK(err_code);
    //// Prepare wakeup buttons.
    //err_code = bsp_btn_ble_sleep_mode_prepare();
    //// Go to system-off mode (this function will not return; wakeup will cause a reset).
    //err_code = sd_power_system_off();
    uint32_t err_code;
    switch (ble_adv_evt) {
    case BLE_ADV_EVT_FAST:
        NRF_LOG_INFO("Fast advertising.");
    case BLE_ADV_EVT_IDLE:
       // sleep_mode_enter();
    char        passkey[BLE_GAP_PASSKEY_LEN + 1];
    uint16_t    role = ble_conn_state_role(m_conn_handle);
    pm_handler_secure_on_connection(p_ble_evt);
    uint32_t err_code;
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt; //$$ new
    switch (p_ble_evt->header.evt_id) {
    case BLE_GAP_EVT_CONNECTED:
        NRF_LOG_INFO("Connected");
        adv_led_button =1;
        led_grn_pwr_active = 1;
        led_on_duration = get_system_rtc();
        let_btn_task_evt_t evt;
        evt.id = LED_TASK_EVT_PROCESS_LED_RC1;
        //led_btn_task_queue_event(evt);
        err_code = sd_ble_gap_rssi_start(p_ble_evt->evt.gap_evt.conn_handle,1,2); //$$ new
        APP_ERROR_CHECK(err_code); //$$ new
        NRF_LOG_INFO("Disconnected");
#if 1
            //NRF_LOG_INFO("%s: BLE_GAP_EVT_SEC_PARAMS_REQUEST", nrf_log_push(roles_str[role]));
        //case BLE_GAP_EVT_PASSKEY_DISPLAY:
        //    memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, BLE_GAP_PASSKEY_LEN);
        //    passkey[BLE_GAP_PASSKEY_LEN] = 0x00;
        //    NRF_LOG_INFO("%s: BLE_GAP_EVT_PASSKEY_DISPLAY: passkey=%s match_req=%d",
        //                 nrf_log_push(roles_str[role]),
        //                 nrf_log_push(passkey),
        //                 p_ble_evt->evt.gap_evt.params.passkey_display.match_request);
        //    if (p_ble_evt->evt.gap_evt.params.passkey_display.match_request)
        //        on_match_request(m_conn_handle, role);
        //    break;
            //char passkey[16 + 1];
            memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, 16);
            passkey[16] = 0;
            // Don't send delayed Security Request if security procedure is already in progress.
            //err_code = app_timer_stop(m_sec_req_timer_id);
            NRF_LOG_INFO("Passkey: %s", nrf_log_push(passkey));
        } break;
        case BLE_GAP_EVT_AUTH_KEY_REQUEST:
           // NRF_LOG_INFO("%s: BLE_GAP_EVT_AUTH_KEY_REQUEST", nrf_log_push(roles_str[role]));
        case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
            //NRF_LOG_INFO("%s: BLE_GAP_EVT_LESC_DHKEY_REQUEST", nrf_log_push(roles_str[role]));
         case BLE_GAP_EVT_AUTH_STATUS:
             //NRF_LOG_INFO("%s: BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                          //p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                          //p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                          //p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                          //*((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                          //*((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
    case BLE_GAP_EVT_PHY_UPDATE_REQUEST: {
        ble_gap_phys_t const phys = {
            .rx_phys = BLE_GAP_PHY_AUTO,
            .tx_phys = BLE_GAP_PHY_AUTO,
    case BLE_GATTC_EVT_TIMEOUT:
    case BLE_GATTS_EVT_TIMEOUT:
    case BLE_GAP_EVT_RSSI_CHANGED:
         rssi = p_ble_evt->evt.gap_evt.params.rssi_changed.rssi;
        // NRF_LOG_INFO("RSSI: %d", p_ble_evt->evt.gap_evt.params.rssi_changed.rssi);
        // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @param[in]   event   Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
    switch (event) {
    case BSP_EVENT_SLEEP:
        sleep_mode_enter();
    case BSP_EVENT_DISCONNECT:
        if (err_code != NRF_ERROR_INVALID_STATE) {
    case BSP_EVENT_WHITELIST_OFF:
        if (m_conn_handle == BLE_CONN_HANDLE_INVALID) {
/**@brief Function for handling events from the GATT library. */
//void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
//    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
//        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
//        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
//    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
//                  p_gatt->att_mtu_desired_central,
//                  p_gatt->att_mtu_desired_periph);
/**@brief Function for the Peer Manager initialization. */
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    //err_code = pm_register(pm_evt_handler);
/**@brief Clear bond information from persistent storage. */
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
/**@brief Function for initializing the Advertising functionality. */
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = false;//..
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.advdata.uuids_more_available.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_more_available.p_uuids  = m_adv_uuids;
    init.srdata.name_type = BLE_ADVDATA_FULL_NAME;
static void log_init(void)
   // ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get); //..snehal
/**@brief Function for starting advertising. */
    bool erase_bonds = *(bool*)p_erase_bonds;
    if (erase_bonds) {
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
    } else {
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/* configSUPPORT_STATIC_ALLOCATION is set to 1, so the application must provide an
implementation of vApplicationGetIdleTaskMemory() to provide the memory that is
used by the Idle task. */
void vApplicationGetIdleTaskMemory( StaticTask_t **ppxIdleTaskTCBBuffer,
                                    StackType_t **ppxIdleTaskStackBuffer,
                                    uint32_t *pulIdleTaskStackSize )
    /* If the buffers to be provided to the Idle task are declared inside this
    function then they must be declared static - otherwise they will be allocated on
    the stack and so not exists after this function exits. */
    static StaticTask_t xIdleTaskTCB;
    static StackType_t uxIdleTaskStack[ configMINIMAL_STACK_SIZE ];
    /* Pass out a pointer to the StaticTask_t structure in which the Idle task's
    state will be stored. */
    *ppxIdleTaskTCBBuffer = &xIdleTaskTCB;
    /* Pass out the array that will be used as the Idle task's stack. */
    *ppxIdleTaskStackBuffer = uxIdleTaskStack;
    /* Pass out the size of the array pointed to by *ppxIdleTaskStackBuffer.
    Note that, as the array is necessarily of type StackType_t,
    configMINIMAL_STACK_SIZE is specified in words, not bytes. */
    *pulIdleTaskStackSize = configMINIMAL_STACK_SIZE;
/* configSUPPORT_STATIC_ALLOCATION and configUSE_TIMERS are both set to 1, so the
application must provide an implementation of vApplicationGetTimerTaskMemory()
to provide the memory that is used by the Timer service task. */
void vApplicationGetTimerTaskMemory( StaticTask_t **ppxTimerTaskTCBBuffer,
                                     StackType_t **ppxTimerTaskStackBuffer,
                                     uint32_t *pulTimerTaskStackSize )
    /* If the buffers to be provided to the Timer task are declared inside this
    static StaticTask_t xTimerTaskTCB;
    static StackType_t uxTimerTaskStack[ configTIMER_TASK_STACK_DEPTH ];
    /* Pass out a pointer to the StaticTask_t structure in which the Timer
    task's state will be stored. */
    *ppxTimerTaskTCBBuffer = &xTimerTaskTCB;
    /* Pass out the array that will be used as the Timer task's stack. */
    *ppxTimerTaskStackBuffer = uxTimerTaskStack;
    /* Pass out the size of the array pointed to by *ppxTimerTaskStackBuffer.
    configTIMER_TASK_STACK_DEPTH is specified in words, not bytes. */
    *pulTimerTaskStackSize = configTIMER_TASK_STACK_DEPTH;
void vApplicationMallocFailedHook( void )
    NRF_LOG_INFO("Malloc Failed");
void vApplicationStackOverflowHook(xTaskHandle *pxTask, signed char *pcTaskName )
    for( ;; );
#if NRF_LOG_ENABLED
/**@brief Thread for handling the logger.
 * @details This thread is responsible for processing log entries if logs are deferred.
 *          Thread flushes all log entries and suspends. It is resumed by idle task hook.
 * @param[in]   arg   Pointer used for passing some arbitrary information (context) from the
 *                    osThreadCreate() call to the thread.
static void logger_thread(void * arg)
    UNUSED_PARAMETER(arg);
    while (1) {
        NRF_LOG_FLUSH();
        vTaskSuspend(NULL); // Suspend myself
#endif //NRF_LOG_ENABLED
/**@brief A function which is hooked to idle task.
 * @note Idle hook must be enabled in FreeRTOS configuration (configUSE_IDLE_HOOK).
void vApplicationIdleHook( void )
#if NRF_LOG_ENABLED
    vTaskResume(m_logger_thread);
/**@brief Function for initializing the clock.
static void clock_init(void)
    ret_code_t err_code = nrf_drv_clock_init();
#define LOGGER_TASK_STACK_SIZE 512
#define LOGGER_TASK_PRIORITY   1
/* Structure that will hold the TCB of the task being created. */
StaticTask_t xLoggerTaskBuffer;
/* Buffer that the task being created will use as its stack.  Note this is
an array of StackType_t variables.  The size of StackType_t is dependent on
the RTOS port. */
StackType_t xLoggerStack[ LOGGER_TASK_STACK_SIZE ];
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
/**@brief Function for application main entry.
    bool erase_bonds;
    uint32_t APPPROTECT_reg;
    bool status;
    // Initialize modules.
    log_init();
    clock_init();
    // Do not start any interrupt that uses system functions before system initialisation.
    // The best solution is to start the OS before any other initalisation.
#if NRF_LOG_ENABLED
    // Start execution.
    m_logger_thread = xTaskCreateStatic(logger_thread, "LOGGER", sizeof(xLoggerStack) / sizeof(xLoggerStack[0]), NULL, LOGGER_TASK_PRIORITY, xLoggerStack, &xLoggerTaskBuffer);
    if (m_logger_thread == NULL) {
NRF_LOG_INFO("TESTING NEW FIRMWARE");
   if(NRF_BLE_APPROTECT_ENABLE)
         APPPROTECT_reg = NRF_UICR->APPROTECT;
         NRF_LOG_INFO("APPROTECT REG VAL IS %x",APPPROTECT_reg);
        if (NRF_UICR->APPROTECT == 0xFFFFFFFF)
            NRF_LOG_INFO("PROTECTING FIRMWARE...SETTING APPROTECT");
            nrf_nvmc_write_word((uint32_t)&(NRF_UICR->APPROTECT), 0xFFFFFF00);
            //NVIC_SystemReset();
      init_device_storage();
   // buttons_leds_init(&erase_bonds);
    // Activate deep sleep mode.
 //   SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
    memset(app_fw_version, 0, sizeof(app_fw_version));
    app_version_str(app_fw_version, sizeof(app_fw_version));
    mem_init();
   // lender_readSetting();
    // Configure and initialize the BLE stack.
    ble_stack_init();
    device_storage_init();
//    borrower_readSetting();
    borrower_load_settings();
    timers_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    application_timers_start();
    // Create a FreeRTOS task for the BLE stack.
    // The task will run advertising_start() before entering its loop.
    nrf_sdh_freertos_init(advertising_start, &erase_bonds);
    init_led_button_task();
    //init_device_storage();
    NRF_LOG_INFO("Device Starting");
    NRF_LOG_INFO("FW Version: %s", app_fw_version);
     // Start FreeRTOS scheduler.
    vTaskStartScheduler();
    for (;;) {
        APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
    // Enable write.
    NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen;
    __ISB();
    __DSB();
    *(uint32_t*)address = value;
    while (NRF_NVMC->READY == NVMC_READY_READY_Busy) {;}
    NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren;
    __ISB();
    __DSB();
uint32_t app_timer_cnt_get(void)
    return xTaskGetTickCount();
uint32_t app_timer_cnt_diff_compute(uint32_t   ticks_to,
                                    uint32_t   ticks_from)
    return ((ticks_to - ticks_from) & RTC_COUNTER_COUNTER_Msk);
I don't want the nearby devices with same firmware to connect to each other. Please help me on how to proceed further.
Thanks & Regards,
Snehal
  • Hi there,
    My understanding is that the device is only advertising, not scanning? So are they connecting to each other if both are acting as a GAP peripheral? Are you sure that it's the two nRF52833 that is connected? Could there be some other nearby advice which has already paired with the nRF52833?
    regards
    Jared
  • Hi Jared,
                 Thanks for your reply. I actually was testing wrong. The other central device was getting connected and not the 2 peripheral devices were connected to each other. In my current firmware I am able to connect only one mobile to my device. How can we connect multiple phone to one peripheral device? What changes are needed to be done?
    Thanks & Regards,
    Snehal.
    See the multi-peripheral example in the SDK. The most essential thing is that you adjust these configs in the sdk_config.h file:
    // <o> NRF_SDH_BLE_PERIPHERAL_LINK_COUNT - Maximum number of peripheral links.
    #ifndef NRF_SDH_BLE_PERIPHERAL_LINK_COUNT
    #define NRF_SDH_BLE_PERIPHERAL_LINK_COUNT 4
    // <o> NRF_SDH_BLE_CENTRAL_LINK_COUNT - Maximum number of central links.
    #ifndef NRF_SDH_BLE_CENTRAL_LINK_COUNT
    #define NRF_SDH_BLE_CENTRAL_LINK_COUNT 0
    // <o> NRF_SDH_BLE_TOTAL_LINK_COUNT - Total link count.
    // <i> Maximum number of total concurrent connections using the default configuration.
    #ifndef NRF_SDH_BLE_TOTAL_LINK_COUNT
    #define NRF_SDH_BLE_TOTAL_LINK_COUNT 4
    NRF_SDH_BLE_TOTAL_LINK_COUNT = NRF_SDH_BLE_PERIPHERAL_LINK_COUNT + NRF_SDH_BLE_CENTRAL_LINK_COUNT
    Also there is many threads on this topic in this forum, so I would suggest that you read through a couple of them.
    regards
    Jared
  • Hi Jared,
                I added the above configuration but the code is getting error message. It is showing error message at the following lines:
    how to solve this?
    Thanks & Regards,
    Snehal
  • You need to adjust the memory settings when increasing the link count. The log output from nrf_sdh_ble_enable() should tell you exactly what you should adjust it too. See this blog post.
    regards
    Jarred
