In the datasheet of nRF52832, typical internal pull up resistance is 13Kohm. Can we check the internal pull up resistance in the code and can we change the internal pull up resistance in the code?
If you wish to use a resistance different from the internal pull up, then you can use an external pull - up resistance. It's not possible to change the internal pull - up resistance via code.
Priyanka
