Thingy 52 Mesh - Node and Bridge Communication Error
I need assistance in nordic thingy52 ble communication. I am using node and bridge code from the https://github.com/NordicPlayground/Nordic-Thingy52-mesh-demo
If I burn the precompiles node and bridge code it works fine.
When I try to compile the code in the segger studio it compiles fine just give one warning which is the following.
taking address of packed member of 'struct <anonymous>' may result in an unaligned pointer value [-Waddress-of-packed-member]
Does this error cause ble communication configuration issues?
When both node and bridge code are running it does not communicate with each other and gives the following error.
when I turn on the first node the following error shows up when I debugged the bridge.
:INFO:===== Thingy mesh demo bridge started! =====
:INFO:Init:
m_ble         :INFO:on_adv_evt: BLE_ADV_EVT_FAST
MAC addr-> f1:81:bc:e3:31:a2
m_ui          :INFO:Mode: BLE_UIS_LED_MODE_BREATHE
<t:        746>, nrf_mesh_sdk.c,  153, Initializing softdevice
<t:        750>, nrf_mesh_sdk.c,  163, Initializing mesh stack
<t:        785>, nrf_mesh_sdk.c,  171, Enabling mesh stack
<t:        792>, main.c,  281, Setting up access layer and models
<t:     375876>, provisioner.c,  379, Local provisioning link established
<t:     377364>, provisioner.c,  365, Using static authentication
<t:     455878>, provisioner.c,  374, Static authentication data provided
<t:     469138>, main.c,  397, Provisioning complete. Adding address 0x0100.
<t:     469150>, provisioner.c,  181, Getting composition data
<t:     472259>, provisioner.c,  334, Local provisioning link closed
<t:    1452207>, main.c,  383, Configuration of device 0 failed
When I turn on the second node the same goes for it it fails the configuration as shown below
<t:    8101565>, provisioner.c,  379, Local provisioning link established
<t:    8102485>, provisioner.c,  365, Using static authentication
<t:    8113585>, provisioner.c,  374, Static authentication data provided
<t:    8191313>, main.c,  397, Provisioning complete. Adding address 0x0101.
<t:    8191323>, provisioner.c,  181, Getting composition data
<t:    8195791>, provisioner.c,  334, Local provisioning link closed
<t:    9174380>, main.c,  383, Configuration of device 0 failed
Please suggest as I am unable to proceed with any further development.
Thanks
  • Hello Muhammed,
    I will have to get back to you on this.
    But note that this is a very old example, and mainly meant as a demonstration of what is possible. Even if you were to develop something using the nRF5 SDK for Mesh (now that the nRF Connect SDK is what is recommended), you would have to use version 1.0.1 of the Mesh SDK here. That is old. I even see that the required repo Nordic-Thingy52-FW is deprecated.
    The samples that are listed on infocenter and developer.nordicsemi is what is mainly supported.
    What version of Thingy52 are you using?
    Elfving
    I am using v1.1.0 of thingy52.
    I understand regarding the depreciation but is there anything you can suggest now in this scenario when we have this issue, how should we go as all other things are looking good and some time the thingy52 get program fine and works fine but some time it just do not repond and the above message occurs.
    I some time have in mind that my boards are faulty but when the pre compiled application worked well then I moved to ask expert opinion here.
  • Hello again,
    So when you use the precompiled hex files, everything is fine? Even the communication between the node and bridge? Then it sounds like it would be better to work on something that is not deprecated.
    Have you had a look at this demo? It is a bit similar, but newer, and all the source material are provided in a zip file.
    Elfving
