Fatal error while adding 2Mbps PHY
Board: nRF52810
SoftDevice: s112
SDK version: 17.0.2
I'm trying to enable 2Mbps data rate. So I've added init.config.ble_adv_primary_phy   = BLE_GAP_PHY_2MBPS; in the advertising_init() function. But I'm getting fatal error in advertising_start() function.
How can I solve this issue and achieve 2 mbps data rate.
Thanks in advance.
  • Hi.
    Could you upload your entire advertising start() function?
    Do you have an error code from when it fails?
    Br,
    Joakim
    I'm just getting Fatal error msg.
    This is my advertising_start() function.
  • Thanks.
    Maybe you could also upload the ble_advertising_start() function?
    That was the function I was looking for. Sorry for the confusion.
    Br,
    Joakim
    No worries.
    This is my ble_advertising_start() function
    uint32_t ble_advertising_start(ble_advertising_t * const p_advertising,
                                   ble_adv_mode_t            advertising_mode)
        uint32_t ret;
        if (p_advertising->initialized == false)
        p_advertising->adv_mode_current = advertising_mode;
        memset(&p_advertising->peer_address, 0, sizeof(p_advertising->peer_address));
        if (  ((p_advertising->adv_modes_config.ble_adv_directed_high_duty_enabled) && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED_HIGH_DUTY))
            ||((p_advertising->adv_modes_config.ble_adv_directed_enabled)           && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED_HIGH_DUTY))
            ||((p_advertising->adv_modes_config.ble_adv_directed_enabled)           && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED))
            if (p_advertising->evt_handler != NULL)
                p_advertising->peer_addr_reply_expected = true;
                p_advertising->evt_handler(BLE_ADV_EVT_PEER_ADDR_REQUEST);
                p_advertising->peer_addr_reply_expected = false;
        p_advertising->adv_mode_current = adv_mode_next_avail_get(p_advertising, advertising_mode);
        // Fetch the whitelist.
        if ((p_advertising->evt_handler != NULL) &&
            (p_advertising->adv_mode_current == BLE_ADV_MODE_FAST || p_advertising->adv_mode_current == BLE_ADV_MODE_SLOW) &&
            (p_advertising->adv_modes_config.ble_adv_whitelist_enabled) &&
            (!p_advertising->whitelist_temporarily_disabled))
            p_advertising->whitelist_in_use         = false;
            p_advertising->whitelist_reply_expected = true;
            p_advertising->evt_handler(BLE_ADV_EVT_WHITELIST_REQUEST);
            p_advertising->whitelist_reply_expected = false;
        // Initialize advertising parameters with default values.
        memset(&p_advertising->adv_params, 0, sizeof(p_advertising->adv_params));
        p_advertising->adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
        // Use 1MBIT as primary phy if no phy was selected.
        if (phy_is_valid(&p_advertising->adv_modes_config.ble_adv_primary_phy))
            p_advertising->adv_params.primary_phy = p_advertising->adv_modes_config.ble_adv_primary_phy;
            p_advertising->adv_params.primary_phy = BLE_GAP_PHY_1MBPS;
        if (p_advertising->adv_modes_config.ble_adv_extended_enabled)
            // Use 1MBIT as secondary phy if no phy was selected.
            if (phy_is_valid(&p_advertising->adv_modes_config.ble_adv_secondary_phy))
                p_advertising->adv_params.secondary_phy = p_advertising->adv_modes_config.ble_adv_secondary_phy;
                p_advertising->adv_params.secondary_phy = BLE_GAP_PHY_1MBPS;
        p_advertising->adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
        // Set advertising parameters and events according to selected advertising mode.
        switch (p_advertising->adv_mode_current)
            case BLE_ADV_MODE_DIRECTED_HIGH_DUTY:
                ret = set_adv_mode_directed_high_duty(p_advertising, &p_advertising->adv_params);
            case BLE_ADV_MODE_DIRECTED:
                ret = set_adv_mode_directed(p_advertising, &p_advertising->adv_params);
            case BLE_ADV_MODE_FAST:
                ret = set_adv_mode_fast(p_advertising, &p_advertising->adv_params);
            case BLE_ADV_MODE_SLOW:
                ret = set_adv_mode_slow(p_advertising, &p_advertising->adv_params);
            case BLE_ADV_MODE_IDLE:
                p_advertising->adv_evt = BLE_ADV_EVT_IDLE;
        if (p_advertising->adv_mode_current != BLE_ADV_MODE_IDLE)
            ret = sd_ble_gap_adv_set_configure(&p_advertising->adv_handle, p_advertising->p_adv_data, &p_advertising->adv_params);
            if (ret != NRF_SUCCESS)
                return ret;
            ret = sd_ble_gap_adv_start(p_advertising->adv_handle, p_advertising->conn_cfg_tag);
                return ret;
            p_advertising->evt_handler(p_advertising->adv_evt);
        return NRF_SUCCESS;
