Software ACK failed in NRF24LE1.
Hi all,
I tried to implement a software ACK between two NRF24LE1 devices, but failed. In my tick_interrupt_ISR, I send a frame from device_A to device_B, and I want to wait for the ACK from device_B still in the tick_interrupt_ISR. To the detail, there is a flag variable in RF_IRQ(RF ISR), if a new RF frame is received, it will be set. And then the code in tick_interrupt_ISR will read the flag variable and check the received RF data, to determine whether it is a wanted ACK frame.
The simplified RF_IRQ ISR code is shown below:
void RF_IRQ(void) interrupt INTERRUPT_RFIRQ
  uint8_t irq_flags;
  irq_flags = hal_nrf_get_clear_irq_flags();// Read and clear IRQ flags from radio
  switch(irq_flags)
	// If data received
	case (1 << (uint8_t)HAL_NRF_RX_DR):
	    // Read payload
        while(!hal_nrf_rx_fifo_empty())
			hal_nrf_read_rx_payload(RX_buffer);
	    // Flush RX FIFO
	    hal_nrf_flush_rx();
	    radio_receive_ready = true;       //The flag is set here!!!
        LED3 = ~LED3;
	// If Transmission success
    case (1 << (uint8_t)HAL_NRF_TX_DS):
       radio_send_busy = false;
    // Transmission failed (maximum re-transmits)
    case (1 << (uint8_t)HAL_NRF_MAX_RT):
       hal_nrf_flush_tx();
The simplified tick ISR is shown below:
void rtc2_isr(void) interrupt INTERRUPT_TICK
	RTC2CON &= 0xfe;	//Disable RTC2 function 1111 1110
    TX_buffer[7] = 0x12;	//control data to device_B
	RF_Send(TX_buffer, RF_PLOAD_WIDTH);	//Send a control frame to device_B
       //Try to wait the ACK here
//        while(!radio_receive_ready );         // line121
    if( radio_receive_ready == true)
         LED4 = ~LED4;    //The LED4 never changed status!!!
My test results are shown below:
  1. If "line121" is commented out, the LED3 always changes each time I send a frame, but LED4 never changes;
  2. If "line121" is NOT commented, the device seems to be gotten stuck, and BOTH LED3 & LED4 never changes. The tick interrupt has a lower priority than RF interrupt, and I wonder if the interrupt nesting error happend.
Could you please help me analyze this problem, thanks in advance!
Best Regards, Junma
